Old 09-02-2012, 01:51 PM   #841
AK Oldman
WANDRN
AK Oldman's Avatar
Oddometer: 249
My hands get extremely dry, particularly in low humidity climates, and the ends of my fingers and thumbs split open on me. I use super glue to hold the split closed. It works very well on minor cuts as well.
AK Oldman is offline   Reply With Quote
Old 09-02-2012, 02:19 PM   #842
ttpete
Rectum Non Bustibus
Oddometer: 6,162
Eastman Chemical originally developed cyanoacrylate adhesive (super glue) as a surgical adhesive. I remember my dad bringing home a bottle with Eastman 910 on the label.
2015 BMW R9T, 2010 Ducati 1098 Streetfighter S
2009 Kaw 650 Versys, 1967 Triumph 650 TT Special
Old 09-03-2012, 02:10 AM   #843
ManiZ
ManiZ's Avatar
Oddometer: 109
To maximize space utilization while minimizing damage to car doors, garage walls, floor-standing cabinets etc. buy some cheap swimming pool noodles, slice them lengthwise with carving knife or sharp blade and stick them to the surface to be protected or to the one to protect from using double-sided tape. Cheap and effective.
ManiZ is offline   Reply With Quote
Old 09-03-2012, 08:47 AM   #844
mfp4073
mfp4073's Avatar
Oddometer: 2,542
I keep one of those "medicated acne pad" containers next to my bathroom sink. You know, the kind that are marketed to teens with pimples. You know how you always get cleaned up, showered and then look in the mirror or at the back of your arm and find still another smudge of grease or dirt you missed. This stuff will clean you down to the skin and are just the right size for spot cleanup.
1974 BMW R90/6 Bettie #1, 04 Triumph Bonneville
Originally Posted by Martin Blank
loner, lonegunman, get it. That’s the whole point. I like the lifestyle, the image. Look a the way I dress.
Originally Posted by bgoodsoil View Post
Cavemen must've designed them shortly after inventing the wheel.
mfp4073 is offline   Reply With Quote
Old 09-03-2012, 04:02 PM   #845
FixerDave
KLR650 - XR200R
FixerDave's Avatar
Oddometer: 397
New Skin, available in the first-aid isle next to the tape in my local drugstore, works basically the same way without being dangerously nasty-sticky. Paint it on, and it fills in the cracks and does a not too bad a job at covering things up. It wears off by the end of the day. If you want to remove it, just paint more on (it's its own solvent) and wipe off. I pretty much use it every day. A while back, I nicked a finger in the shop... stupid wipe against a cotter pin that was way too sharp. It tore up the skin pretty good. I slapped some New Skin on (stung like hell), wrapped it in a bandage, and forgot about it. A few days later, when the bandage fell off, there was a lump of living skin sticking up... you know, a bit of that torn stuff that usually dies and falls off. Damn New Skin worked too well, kept that alive. It took a few days of trimming to nibble it back town to flush. The little 30mil bottle I picked up has lasted months. I'm sold on it.
In the shop, I've taken to taping my fingers up with cloth tape, again, from the first-aid isle. I run a strip of it out, hanging from above, and snip off a little section to cover the tip of a finger, then a longer section to wrap around it. I usually do 2 fingers and a thumb on each hand... the ones prone to cracking. I do this before they crack, pretty much every time I'm in the shop now. It only takes a minute to put on, and take off, and it works. Not particularly expensive either. Peeling the tape off at the end of shop-day leaves my fingertips the cleanest part of my hands... a little weird but after the hand cleaner, I don't have the under-nail, impossible to clean stains I used to get. The only problem is if you get into a lot of oils or solvents as it can turn the adhesive into goop. Hand cleaner deals with it, regular soap... not so good.
David...
FixerDave is offline   Reply With Quote
Old 09-03-2012, 08:46 PM   #846
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,744
^^^^ Go to Lee Valley and get some of their Worx hand soap. You can thank me later...!
And they even have dedicated finger tape.
http://www.leevalley.com/US/wood/pag...?p=64762&cat=1
Nice new store....in Victoria.
Have tools, will travel!
H96669 screwed with this post 09-03-2012 at 08:54 PM
Old 09-03-2012, 10:55 PM   #847
AK Oldman
WANDRN
AK Oldman's Avatar
Oddometer: 249
Originally Posted by FixerDave View Post
New Skin, available in the first-aid isle next to the tape in my local drugstore, works basically the same way without being dangerously nasty-sticky. ...David...
I have been using New Skin foro minor stuff for years. As bad as my fingers crack New Skin just isn't strong enough.
Old 09-04-2012, 08:45 AM   #848
scooteraug02
Dog Rancher
scooteraug02's Avatar
Oddometer: 4,567
When you are done in the shop and have to do some moving in the house.
They work great and save your back and carpet.
To clean your camelback water carrier use denture cleaner. Google it!
scooteraug02 is offline   Reply With Quote
Old 09-04-2012, 02:47 PM   #849
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 982
For picking up steel shavings and chips with a magnet without having to clean them all off the magnet afterward.
LINK
Ignore the thunder.
"If what you are doing isn't working, don't try harder, try different."
"Today I'm younger than I'm ever going to be, and I intend to act like it"
EvoLife is offline   Reply With Quote
Old 09-04-2012, 03:59 PM   #850
thisflatearth
2 wheel has been
thisflatearth's Avatar
Oddometer: 944
I almost turned around with the camera when the thunder cracked. The spring breaking off the garage door was even scarier, glad we were outside the door when it happened.
Take Evolifes advise with a grain of salt as he is the harbinger of death
thisflatearth is offline   Reply With Quote
Old 09-04-2012, 05:05 PM   #851
EvoLife
Evolving.....Slowly
EvoLife's Avatar
Oddometer: 982
I haven't seen that look on your face, or laughed that hard in a long time.
His garage door didn't want to stay up by it's self, so while I was there I suggested we take some slack out of the spring cables. While doing it he even commented how he should add safety cables to the springs in case they break.
As we are leaving he closes the garage door and a few seconds later we hear the spring snap and slam into the other side of the door right where he's standing. It is just like anything else we do. What can go wrong will.
Old 09-06-2012, 12:15 PM   #852
STUFF2C
We Ain't Left Yet!!
STUFF2C's Avatar
Oddometer: 3,071
Utter Butter- the real thing for dairy cows. Not the stuff for woman. this stuff works great for dry skin. My vet turned a friends wife on to it for her dry heals and it cured them.
Thanks to the Interstate Highway System, it is now possible to travel from coast to coast without seeing anything.
-- Charles Kuralt
I never plan a ride, just the destination and that's always subject to change.
STUFF2C is offline   Reply With Quote
Old 09-06-2012, 09:17 PM   #853
Kinsman
Ribs....for her pleasure
Kinsman's Avatar
Oddometer: 4,267
Yep, Bag balm too. And you can get pure lanolin too; smells like a barn plus it works great.
Chris R
Schreckendgust Field, Montana
Kinsman is offline   Reply With Quote
Old 09-07-2012, 07:24 AM   #854
bomber60015
Anatomically Correct
bomber60015's Avatar
Oddometer: 14,862
Also HoofMakers (silly name) . . . .works great!
"Here is your country. Cherish these natural wonders, cherish the natural resources, cherish the history and romance as a sacred heritage, for your children and your children's children. Do not let selfish men or greedy interests skin your country of its beauty, its riches or its romance.” T.R.
Old 09-09-2012, 07:35 PM   #855
hillbillypolack
Grumpy Old Goat
hillbillypolack's Avatar
Oddometer: 6,435
Relocating an old home stereo has already been suggested, but I'd also add a set of moisture proof speakers to keep humidity affecting them.
I've had a gas heater and dehumidifier in the garage for years-mostly because I dislike having the floor sweating and rusting tools, bikes and parts in the garage. Works like a charm even if I have to manually empty it.
Old toothbrushes work like a charm for cleaning parts and chains.
Garage sale pie tins, muffin pans and cookie sheets with tall edges work fantastic for parts cleaning 'bins', and even as shallow organizers in tool chests. I have a few cookie sheets with Oetiker clamps so I can paw through them yet they are still 'organized' in my fastener drawer.
Have a container of Q-tips handy for small cleaning duty. A roll of paper towels and garage rags as well.
When tuning a bike, have a shop fan feeding cool air into the front of the bike. If you don't have a table at the bike's height, use your tie-downs to hang it from the ceiling.
Trawl through craigslist for a cycle lift. Even if it's the hydraulic foot pedal version, it'll save your back several times over.
Use compressed air in nooks and crannies after washing your bike to prevent rusting from standing water. If you want to get particular, use WD-40 sparingly at pivots etc after drying the areas.
I found Jesus. He was behind the sofa the whole time.
1996 M900 2012 GS 2008 Megamoto 2008 S2R
2006 HP2e
hillbillypolack is offline   Reply With Quote
Times are GMT -7.   It's 06:55 AM.
