09-05-2012, 06:44 AM
#2296 | |
Oddometer: 13
09-05-2012, 06:52 AM
#2297 | |
KTM
Oddometer: 1,196
I mean the slider that "wraps the swing arm". with the chain being lower it rides more on the upper surface and the lower surfance a well. Something else also recently seen on a friends bike is if your chain is too loose it rides up on the lower side of the front gear and saws right threw the guide.
Every question in life has an answer of YES OR NO Maybe = NO Keep life simple and enjoy it!
09-05-2012, 12:04 PM
#2298 | |
Oddometer: 29
I just had my exc remapped and it fixed all the lean issues I had. I believe you load the euro map first then xcw map. Works great. |
09-05-2012, 12:42 PM
#2299 | |
beat up ex flat tracker
Oddometer: 6,753
Mine has yet to boil water out of the radiator riding the same trails. I can go 200 miles on the 4.2 gallon Safari tank on it,that's really about far enough on any sort of gnarly trails/jeep roads. Somewhere around 14 to 1 air/fuel mix is where a bike runs best at,doesnt matter if its FI or carbed. Yet yours gets 63 mpg at times,that's flat amazing. There are more then a few dirtbikes with FI out there,I dont remember any saying they get 13 or 14 mpg better with FI,my little truck surely doesnt get much better mileage with FI. Sounds like you got a good one!
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. |
09-05-2012, 12:47 PM
#2300 | |
Oddometer: 6,753
I asked a couple shop guys where the local trailriding is,they said maybe Georgia? You must have found some good trailriding around there?
09-05-2012, 12:51 PM
#2301 | |
Oddometer: 6,753
Wouldnt it kinda block air flow that way? But then,what the hell do I know? ![]() How do I get one of those oil coolers? Me Likee!
2003 DR 650.(1976 Montesa 250 Enduro-nice!) - - 1990 MASI TEAM-3V.- 1976 Motobecane, Super-Mirage.- Kona, HumuHumuNukuNukuApua'a. Single Speed ThRaShEr BiKe. 1968 360 Greeves challenger MXer. 1999 Triumph Trophy 1200. 2011 KTM530 EXC. 2012 KONA Hei Hei Deluxe (ongoing bike issues) -2009 KTM 200XC-W. Foot dragger screwed with this post 09-05-2012 at 01:49 PM |
09-05-2012, 04:08 PM
#2302 |
Oddometer: 67
Mapping and fuel mileage
I have my 500 exc remapped with the euro EXC map (which was done in west virgina before i shipped it to cali)and it has been great no issues at all.Removed smog crap put on exhaust turned up the idle and have had no issues, and the map switch does work(stock, mild, wild).I am going to be sweep riding on sep 22-23 for my cousin who puts on the yosemite dual sport rides twice a year and "Best Dual Sport Bikes" is going to be there, cant wait to meet them and bend there ear a little. Just went over to Carson City NV over Carson Pass(CA to NV) this weekend with my sumo set up and got 170 miles out of my clockwork 3.2 gl tank.I was averaging 70-75 mph. Everyones preference in final gearing, riding styles and terrain is also going to be a factor in the fuel mileage discussion.Overall I am very happy with the bike its the best I have ever owned. I am also very happy with the products I bought for my bike thanks to the info I gained here and vendors that are active on this site, Big thanks to HDB and Globetrottin for making well built and thought out products.
http://stifdickerson2006.smugmug.com...IMAG0591-S.jpg
No Matter Where You Go, There You Are. Stifdickerson2006 screwed with this post 09-05-2012 at 04:36 PM Reason: picture did not show up |
09-05-2012, 04:34 PM
#2303 | |
Oddometer: 6,753
The trails around here tend to be steep and tight,probably affects mileage compared to other areas,sometimes just getting up them involves lotsa work. I have done some pre riding for www.ironman dualsport.com,out in the Nevada desert we went 800 miles in 4 days,hot each day, on the bikes at 6 in the AM and finish in the heat. I lost 9 lbs that didnt come back. I rode my DRZe for that,came home and bought the 530,no mas wrestling a heavy bike in the rocks. Whats the name of your cousin's dualsport business?
09-05-2012, 04:52 PM
#2304 | |
Oddometer: 67
No Matter Where You Go, There You Are. |
09-05-2012, 05:54 PM
#2305 | |
Oddometer: 6,753
09-05-2012, 07:04 PM
#2306 | |
Oddometer: 975
Anyway, I put down my deposit on a '13 500EXC today ![]() I am already scheming about a Baja Designs Squadron headlight (need to check on the stator output) and sumo wheels. I like the idea of the KTM rear wheel with the cush hub, and the lower price for a complete Warp 9 front wheel assembly. Has anyone seem them in close proximity so see how similar the rims look? In other words, would it be noticeable if you did that mix-n-match setup?
More than twice as many Americans died in British concentration camps during the Revolutionary War as died in combat. Don't believe it? Google prison ship martyrs monument. 350EXC-F |
09-05-2012, 08:21 PM
#2307 | |
Oddometer: 67
The clockwork tank fits fine with the fan, but the thermostat housing is a little tight. I pulled my thermostat off.as far as using a cush hub or not I start out of that conversation as I have no experience with them.if you are going to be hammering the drive system on road I would get one.I looked set the warp9 sets but found a great deal on DNA set up With EBC break rotors and sprocket that use OEM bearings for just a little more so I went with them. I'm running 15 frt & 42 rear on the street and really like it.
09-05-2012, 09:24 PM
#2308 | |
Oddometer: 6,753
09-05-2012, 09:45 PM
#2309 |
Oddometer: 67
Yes they do have a cush system in the clutch. Which for my style of riding is fine but if I was a more aggressive rider and really hammering the drive system I would put one on. The cush or no cush debate is almost as vast s the type of oil argument.
09-05-2012, 11:11 PM
#2310 |
Oddometer: 272
Kush Sprocket
