Old 09-05-2012, 06:28 AM   #5401
Pundy
Oddometer: 341
Originally Posted by DirtJack View Post
The 690's have adjustable (two settings) triple clamps. As delivered, they are set to max offset (less trail). Using the smaller offset increases the trail and should improve stability at speed. You can easily check which setting by removing the triple clamp cap (don't loosen the pinch bolt). If the dot is at the rear, they are set to max offset. Changing offset requires disassembly of the front end and gives an opportunity to grease the steering head bearings.
You mean the cap at the center of the top of the triple clamp? Is this procedure outlined somewhere in the manual? I need to check this for sure.
Pundy is offline   Reply With Quote
Old 09-05-2012, 06:40 AM   #5402
Barman
Way Offline
Barman's Avatar
Oddometer: 1,166
Here's a thread. http://www.advrider.com/forums/showthread.php?t=517497
I am at one with my duality.
Barman is offline   Reply With Quote
Old 09-05-2012, 09:19 AM   #5403
Aaron from Texas
Aaron from Texas's Avatar
Oddometer: 489
Anyone interested in this wheel?
This was on my 2008 KTM 690 SMC. Woody's Wheel Works built with 19" Excel 7000 Series rim, Rad Eagle hub, and Heidenau K60 Tire.
Not too sure how many miles are on her, but she's straight with no scratches. Bearings are great.
1987 Honda XL600R
ftwtexas.blogspot.com
Aaron from Texas is offline   Reply With Quote
Old 09-05-2012, 10:50 AM   #5404
BK.RD.RNR
Torque Stick
BK.RD.RNR's Avatar
Oddometer: 5,771
Originally Posted by crankshaft View Post
Anyone know where I can find an EBC clutch kit for the 690?
There were TONS of them on ebay last month.
BK.RD.RNR is offline   Reply With Quote
Old 09-05-2012, 01:29 PM   #5405
DirtJack
DirtJack's Avatar
Oddometer: 1,600
The procedure is not given in the 690 owner's manuals, but is the same as given in KTM dirt bike manuals for bikes which have adjustable fork offset. Remember, more offset means less trail (quicker turning) while less offset means more trail (better stability at speed). Here is an image from a page in a dirt bike manual (the offset values are different). The dot on the top of the steering stem (cap off) at the rear corresponds to the max offset setting. The procedure is to disassemble the forks and loosen the stem at the bottom clamp and rotate the dot to the front to give the smaller offset value.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-05-2012, 02:49 PM   #5406
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,759
Thanks fellas for all the info
I will be doing the offset on the weekend - is there anything i should adjust, check, grease while im in there
thanks
Beer'o'clock Baz is online now   Reply With Quote
Old 09-05-2012, 04:53 PM   #5407
Pundy
Oddometer: 341
THIS, could revolutionize my ride. Can't believe I didn't know about it. Thanks!
Old 09-06-2012, 12:44 AM   #5408
toniton
toniton's Avatar
Oddometer: 30
thanks for explain it!
Where can I find this manual?
I have donwloaded the owners manual of the 530 exc and the 450 sxf and I can't find this picture.
KTM 690 Enduro R
toniton screwed with this post 09-06-2012 at 01:20 AM
toniton is offline   Reply With Quote
Old 09-06-2012, 01:13 AM   #5409
Beer'o'clock Baz
Oddometer: 1,759
Had the afternoon off and the job completed - test ride tomorow-
Thanks guys for helping thoughts yas might like a pic
Old 09-06-2012, 04:05 AM   #5410
DirtJack
DirtJack's Avatar
Oddometer: 1,600
If the manuals are for current models, they no longer have adjustable offset triple clamps. Use manuals for bikes 2010 and earlier.
2008 KTM 690 Enduro
Old 09-06-2012, 04:30 AM   #5411
Sutherngintelmen
around the bend
Sutherngintelmen's Avatar
Oddometer: 1,205
Originally Posted by B2 View Post
like a pic
Puppet MC
There is a pleasure in the pathed woods, There is a rapture in the smoking pipe, There is chaos, where none intrudes, in the deep dell, with its thrills roar; I love not nature less, but bikes the more. Byron riding.
All pics < 6/30/12 deleted by Apple Now with SmugMug supporting ADV
Sutherngintelmen is offline   Reply With Quote
Old 09-06-2012, 07:57 PM   #5412
Beer'o'clock Baz
Oddometer: 1,759
OK - theres good news and bad - first up the bad
It did not cure the headshake, I give up i have tried everything i might as well gear it down and not go over 130 kph
Now for the good news, it feels so much better to ride more comfy and on the dirt "fantastic" it has taken that tipping over from the front out - i have had three offs on dirt where the front wheel has slid from under me making me highside and it has taken that feel away - i know peeps will say yeah but it wont corner as well but i corner with alot of rear wheel so it feels better more planted up front
so thats a and a
p.s the windsheild didn't take the headshake away either i don't know if i mentioned that
p.s.s going to start on the fuel filter on the weekend anything i should know about
p.s.s.s just went for a spin with the missus on the back no speed wobble at all
Beer'o'clock Baz screwed with this post 09-06-2012 at 09:58 PM
Old 09-06-2012, 08:26 PM   #5413
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 915
us 'mericans dont know KMPH but i take mine to 100 mph dirt and pavement............it is squirlie on groved pavement even at 65 and it will wag a bit on the dirt especially if its got many tracks and soft but it has never been anything that was scary
always on knobs mostly m-12 on the front and whatever on the back 17 lbs both tires. they are balanced and have rim locks
forks are on the first line from the top and i usually have a safari tank and full or empty dont seem to matter.
is your front axle square? rear tire aligned? sag set properly?
sorry man out of ideas
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 09-06-2012, 10:08 PM   #5414
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,123
so thats a and a
p.s.s going to start on the fuel filter on the weekend anything i should know about Don't kink the fuel line
this tell me that is a preload issue , have you played with the fork preloads ?
Answer these for me please
.? Is it still tucking under or pushing out wide ?
How much do you weigh with gear ,
What springs do you have
what psi
Mudguts screwed with this post 09-06-2012 at 10:18 PM
Mudguts is offline   Reply With Quote
Old 09-06-2012, 10:09 PM   #5415
Mudguts
Mudguts's Avatar
Oddometer: 2,123
I think spiderman had a wank in your shed
Times are GMT -7.   It's 03:16 AM.
