Old 09-03-2012, 11:07 AM   #2686
Turbocat
73 2U
Turbocat's Avatar
Oddometer: 15
THAT was quick !
I placed my order Wednesday evening and the postman delivered my lights Saturday, just in time for me to play with them over the Labor Day weekend.
I also bought the LED flashlight, which is very cool --
Turbocat is online now   Reply With Quote
Old 09-03-2012, 05:44 PM   #2687
millsan1
IBA #49986
millsan1's Avatar
Oddometer: 239
Just got my second order, quickly and efficiently. Great lights.
Sent from my Galaxy Nexus using Tapatalk 2
Some people like my Blog, Hope you do.
http://millsan1.blogspot.com/
millsan1 is offline   Reply With Quote
Old 09-03-2012, 10:41 PM   #2688
Rev
Asshole
Rev's Avatar
Oddometer: 252
any ideas on mounting a pair to the forks of the 08 KLR?
could i beg a rotary switch that could handle 4 60's ? even better if the knob could come off so i could put the box behind my dash plate
Give a man fire, and he's warm for a night.
Set a man on fire, and he's warm for the rest of his life.
Rev screwed with this post 09-03-2012 at 10:50 PM
Rev is offline   Reply With Quote
Old 09-04-2012, 04:44 AM   #2689
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Did you try the flashlight at night?
Thanks for your business
You can mount them on the lower fork leg by removing the stock side reflectors. Or pick up a set of turn signal relocators for a 41mm fork.
As much as I would like to sell you 4 model 60s, you just don't need 4! Unless you are wearing your welding helmet. Please try a pair and if find you need more light we can talk.
Old 09-04-2012, 05:40 PM   #2690
2012BlackKLR650
KTM 690 Enduro *****
Oddometer: 38
Email sent
Hi Sanjoh.. looking forward to hearing back from you!! Can't wait to try out my mount ideas...... just need to find out if the total throw for the 60 model 'flood' is longer than the 30 model 'spot'. I was thinking one of each (1 mounted as spot on top fairing of my KLRto give maximum distance, the other where my orig fender was mounted so it will turn with bars) ..BUT if the total throw of the 60 flood is just as far..then I will spring for 2 of those with a rotary dimmer.
2012BlackKLR650 is offline   Reply With Quote
Old 09-04-2012, 05:44 PM   #2691
Wadester
Rides a dirty bike
Wadester's Avatar
Oddometer: 2,068
I have a question about the available mounts:
You offer a Heavy Duty bracket:
And a crash bar mount
Do you need both to use the crashbar mount? I know the light comes with the "standard" bracket, but do you need a bracket and a mount?
Thanks.
PS: I wish the rotary dimmer knob came off too. A panel mount would be very nice.
Two roads diverged in a wood, and / I took the one less traveled by, and / now where the hell am I?
This isn't a "you're doing it wrong" topic. (Originally Posted by Human Ills, 7/1/14)
Wadester is offline   Reply With Quote
Old 09-04-2012, 06:26 PM   #2692
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Email reply sent.
The model 60 has more throw due to having over twice the lumen output as the model 40.
Thanks.
You do not need both. The crashbar mount is intended to provide a platform to mount lights on a round tube, the heavy duty bracket is an upgrade to the standard bracket which is an integral part of the light.
Old 09-06-2012, 09:13 AM   #2693
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Another happy customer
Model 60s
Rotary dimmer
Old 09-06-2012, 05:45 PM   #2694
skybo1
Oddometer: 91
Yes-very happy
Those are my pictures above.
I just returned from my first night ride- HID's 55W low and high and 2- M60's to fill in
the other areas.
I wired it so in low beam the M60's adjust and in highbeam they max blast.
John did a great job of immediately getting back to me with any questions I had.
Definitely recommend!
skybo1 is offline   Reply With Quote
Old 09-06-2012, 10:01 PM   #2695
millsan1
IBA #49986
millsan1's Avatar
Oddometer: 239
Just came back from an impromptu saddle sore ride and the 60s are the bomb. A grounding issue took them out for a spell and even with dual hid low beams it was dark. These lights are not to be missed.
Old 09-07-2012, 03:14 AM   #2696
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
Originally Posted by Notabiker View Post
Looks nice but if it's only that one bolt the lights have quite a bit of leverage to loosen the bolt when you hit bumps..
The bracket I made rests along the fork leg, 4000+ miles and no movement, no bouncing. This is a road bike with a sidecar, so no washboard dirt roads encountered.
Now if you want to talk about tightening the pivot screw on the light bracket........
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 09-07-2012, 04:35 AM   #2697
SV_Dwayne
SV_Dwayne's Avatar
Oddometer: 309
Wouldn't it work better to flip the mount around, so the center of gravity of the body of the light is directly over the mount rather than in front? It would have less leverage on the pivot screw that way.
Kicking ass seems to be THE ONLY solution to life's problems. Kicking ass is the first, second and third option. Plan B and C are also kicking ass.
SV_Dwayne is offline   Reply With Quote
Old 09-07-2012, 02:50 PM   #2698
OzRider64
Friggen slow Adventurer.
OzRider64's Avatar
Oddometer: 90
Cry model 44's on the blink, not happy.
G'day Sanjoh,
Back in October of last year I purchased a set of model 44's off you. Only got to fit them to my bike in Feb of this year.
For the first couple of months they worked fine. My bike is a 2010 R1200gs. The lights are fitted to a PC8 Fuse block with a IQ-170 from Skeene Products and a mini switch from Cyclenutz which is used to turn the lights on.
I sent you a post a couple of months ago regarding the flickering in one of the lights and you told me not to worry.
Well a week ago the other light went out totally and the other lights flicker is getting worse.
Decided to pull the tank of last week and check all the connections again. Everything checked out fine. Disconnected the mini switch and ran the lights through the IQ-170 same problem. Disconnected the IQ-170 and ran the lights connected to the battery same problem.
I understand from your website the lights had a limited warranty and I am well outside that time frame. I am more annoyed that other people are having a good run from them. I suppose Chinese manafactured items can have variable quality. Only three weeks ago I had to replace a ballast on my 35w HID from DDM which I have had on for the same time as the modell 44's.
Sanjoh, I don't no what to do here. Do I purchase another set and take the risk??. Can I send them back to you to have a look at or do I bin them and go for a set of Clearwaters.
Any help would be much appreciated Sanjoh.
Simon.
Tassie, where two heads are better than one.
2010 R1200GS
OzRider64 is offline   Reply With Quote
Old 09-07-2012, 03:32 PM   #2699
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Hi Simon,
If you purchased in October of last year, the lights are still under warranty. Please contact me by email sandjoh@gmail.com for further instructions.
Old 09-08-2012, 04:36 AM   #2700
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,321
Tried that, don't remember why it didn't work, solution was to remove the bracket once the lights were aimed. That gave me access to the bolt & jam nuts. Lights haven't moved since.
www.earplugco.com
Times are GMT -7.   It's 09:50 AM.
