Old 09-08-2012, 08:55 AM   #5476
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Originally Posted by RoninMoto View Post
Once you make the power supply, just connect a hose with a jug of desired solvent and have it gravity feed through the injector as it is cycling. It will be slow/nonexistent at first but should become a stream when it is clean.
Was thinking I'd build something along the lines of a pressurized flush or a back flush set up even. Would pulsing it be better than simply holding it open?
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 09-08-2012, 01:01 PM   #5477
Uller
Uller's Avatar
Oddometer: 1,674
pulsing it would allow pressure to build behind the solenoid for a more forceful blast of cleaner each time it was cycled. I did backflush it first then the normal direction.
I don't have an ultrasonic cleaner and used the syringe method shown on youtube. seemed to work fine. I've got about 10,500 mi. on my original injector and carry a spare with me.
I believe they are in the ballpark of $150 here in the states.
Uller is offline   Reply With Quote
Old 09-08-2012, 04:13 PM   #5478
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 847
From what I understand, the injector in itself IS a pump. When the coil is activated, it triggers a hammer that pushes the fuel inside the motor.
That said, your local Diesel Engine Tune Up shop will clean these injectors better then you will ever do for few bucks ...
I know that just trying to dip that think into some "liquid mechanics" wont work 100%
Paul Jr.
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-08-2012, 04:37 PM   #5479
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Got it back together and not I'm getting no fuel. I can pull the injector out and get a clean spray pattern, but with my finger in the back of the throttle body I get nothing from the injector. Pull it out and it's not consistently pulsing now
Injector? electrical?
Connections look good, new spark plug, good fuel pressure (though I don't have a pressure gauge that'll read that high) drop a little fuel in the TB and it fires right up- No fuel through the injector though. It there a way to test the electrical? Something like a noid light? I doubt my DVM would read quickly enough to see the pulsing.
My bad
Old 09-08-2012, 08:02 PM   #5480
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,756
After a gear lever any ideas ? the hammerhead is outa stock for another month
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz is offline   Reply With Quote
Old 09-08-2012, 08:17 PM   #5481
crankshaft OP
Guns are for pussies
crankshaft's Avatar
Oddometer: 14,004
You might be better off without the Hammerhead I had a problem with the splines on mine and they never called me back, been waiting 8 months! No big deal, it's only $80.
Just say'IN
crankshaft is offline   Reply With Quote
Old 09-08-2012, 11:51 PM   #5482
Mudguts
when in doubt GAS IT
Mudguts's Avatar
Oddometer: 2,106
I had a look at my 500 exc they are closer 690 then hammerhead and cheaper then a 690 lever
Mudguts is offline   Reply With Quote
Old 09-09-2012, 12:48 AM   #5483
.chris
690 Advenduro
.chris's Avatar
Oddometer: 93
Originally Posted by beaney View Post
Buy a decent torx socket set
Tried your idea, and now I have managed to strip the torx bolt.
Who the hell uses torx for such tight bolts, will be replacing it with a proper bolt if I ever get it out.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 09-09-2012, 02:46 AM   #5484
Night Falcon
Adventure NZL
Night Falcon's Avatar
Oddometer: 1,993
why ya taken off ya shock for?
My EXC530 Adventure
My KTM690 Adventure
2008 250 Beta Rev3 - Trials with lots of errors
Night Falcon is offline   Reply With Quote
Old 09-09-2012, 04:52 AM   #5485
Brute
Melbourne , outer east .
Brute's Avatar
Oddometer: 1,046
Take the fuel hose off the injector , turn ignition on & see if you get a surge of fuel . If so block the hose with your thumb & turn ignition on again & see if it has pressure ( it should be very hard to stop it spraying ) keep your thumb on it a while to see if it holds pressure in the line.
Disclaimer ,,, if you set your bike or shed on fire don`t blame me ,
Brute is offline   Reply With Quote
Old 09-09-2012, 05:12 AM   #5486
LOZ
Oddometer: 1,201
Originally Posted by 690Emaf10 View Post
Thanks, I sprayed some WD40 on it before I left for work. I'll see what i can do with it when I get home.
if its anything like mine ....... ..cut it off..start looking on e-bay for a secondhand tank,when trying to get it out the nut in the plastic gouged a hole in the tank and i had to fit a new tank
950
loz
LOZ is offline   Reply With Quote
Old 09-09-2012, 05:15 AM   #5487
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Done, and done. I don't see it being a supply issue. I have the back flush fixture for the injector set up. I'll get on that this morning and see what happens.
My bad
Old 09-09-2012, 07:13 AM   #5488
daveknievel
daveknievel's Avatar
Oddometer: 609
I have a shifter on my 690 that is from my 05 450 SMR. Same thing. They only offer 4 different shifter for ktm's. And the hammerheads aren't out of stock. Tucker rocky has 5 in ILL, 9 in cailf. None in the PA . Warehouse.
daveknievel is offline   Reply With Quote
Old 09-09-2012, 08:22 AM   #5489
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,985
Update
Looks like the fuel volume is there, but the pressure is not all that great. Looks like I'm going back into the tank for round three
http://s2.photobucket.com/albums/y35...t=IMG_0345.mp4
My bad
Old 09-09-2012, 08:49 AM   #5490
Gros Buck
Gros Buck's Avatar
Oddometer: 847
Tried your idea, and now I have managed to strip the torx bolt. Who the hell uses torx for such tight bolts, will be replacing it with a proper bolt if I ever get it out.
Well
As far as I am concerned, Torx is one of the best thing on earth ... Particularly in tight places. Torx are 99% class 8.8 or 12.9.
One thing however, it's pretty easy to mix sizes. You can easily use a T40 while it should have been T45 ... Oups ... And another thing ... Torx bolts are 10 times more expensives when you can find them...
Paul Jr
KTM690r 2011
Times are GMT -7.   It's 08:46 PM.
