Old 09-09-2012, 04:12 AM   #5461
LOZ
Oddometer: 1,206
Originally Posted by 690Emaf10 View Post
Thanks, I sprayed some WD40 on it before I left for work. I'll see what i can do with it when I get home.
if its anything like mine ....... ..cut it off..start looking on e-bay for a secondhand tank,when trying to get it out the nut in the plastic gouged a hole in the tank and i had to fit a new tank
950
loz
LOZ is offline   Reply With Quote
Old 09-09-2012, 04:15 AM   #5462
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Originally Posted by Brute View Post
Take the fuel hose off the injector , turn ignition on & see if you get a surge of fuel . If so block the hose with your thumb & turn ignition on again & see if it has pressure ( it should be very hard to stop it spraying ) keep your thumb on it a while to see if it holds pressure in the line.
Disclaimer ,,, if you set your bike or shed on fire don`t blame me ,
Done, and done. I don't see it being a supply issue. I have the back flush fixture for the injector set up. I'll get on that this morning and see what happens.
When there is no way out - Find a way further in.
DL650 DR350 MMS Edition KDX Past bikes ...and an airhead vvv
Originally Posted by Mugwest
Originally Posted by Buzztail
You shoulda told me to do this a long time ago
My bad
Buzztail is offline   Reply With Quote
Old 09-09-2012, 06:13 AM   #5463
daveknievel
daveknievel's Avatar
Oddometer: 757
Originally Posted by Mudguts View Post
I had a look at my 500 exc they are closer 690 then hammerhead and cheaper then a 690 lever
I have a shifter on my 690 that is from my 05 450 SMR. Same thing. They only offer 4 different shifter for ktm's. And the hammerheads aren't out of stock. Tucker rocky has 5 in ILL, 9 in cailf. None in the PA . Warehouse.
daveknievel is offline   Reply With Quote
Old 09-09-2012, 07:22 AM   #5464
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Update
Looks like the fuel volume is there, but the pressure is not all that great. Looks like I'm going back into the tank for round three
http://s2.photobucket.com/albums/y35...t=IMG_0345.mp4
My bad
Old 09-09-2012, 07:49 AM   #5465
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Originally Posted by .chris View Post
Tried your idea, and now I have managed to strip the torx bolt. Who the hell uses torx for such tight bolts, will be replacing it with a proper bolt if I ever get it out.
Well
As far as I am concerned, Torx is one of the best thing on earth ... Particularly in tight places. Torx are 99% class 8.8 or 12.9.
One thing however, it's pretty easy to mix sizes. You can easily use a T40 while it should have been T45 ... Oups ... And another thing ... Torx bolts are 10 times more expensives when you can find them...
Paul Jr
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-09-2012, 09:34 AM   #5466
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Final chapter (I hope)
A very small hole in the new in-tank fuel line was leaking only when under pressure. replaced the week old stuff with some more bought at CarQuest rated/printed the same and it fired right off.
It seemd to be getting worse as time went on making the origional testing void. I started from scratch again and found the low pressure condition that wasn't there before. When no pressure was on the hose it worked normally, but when any restriction was there it blead pressure from the leak.
My bad
Old 09-09-2012, 11:59 AM   #5467
Czechie
Czechie's Avatar
Oddometer: 75
Scotts steering dumper
Hi guys,
could any of you help with Scott's steering dumper. I have the original mounting set up for 690.
I have bought the following bar riser and tried to fit the dumper in.
Unfortunately I realised that I am missing approx. 5mm to fit the pin in.
I know that the easest solution is to turn the bar riser by 180 degres and it will fit. However this is not what I want as this position of the bar riser bring the handlebars closer to the seat which I dont like.
I was wondering whether any of you had a similar problem and what the solution was. I was thinking or playing with the bottom part but not sure whether this will not screw up someting else. I did not try to lose the nut but it seems to me that the "needle" is fitting perfectly in so I can't remove it.
Any tips or hints? Cheers.
Czechie is offline   Reply With Quote
Old 09-09-2012, 12:08 PM   #5468
beaney
rally racer
beaney's Avatar
Oddometer: 124
Rally Raid Products make a longer arm for the damper to solve this problem
690 enduro/ rally
350 exc
RALLY-RAIDPRODUCTS.CO.UK
beaney is offline   Reply With Quote
Old 09-09-2012, 01:31 PM   #5469
bobzilla
Dirty Old Man
bobzilla's Avatar
Oddometer: 913
Originally Posted by Czechie View Post
Hi guys,
you nee to use a puller to get the arm off. I would make or buy a longer pin. the pin on my husaberg as around 3" long if i remember
Ride the DEZ
05 FE 550 Husaberg plated
08 FE 650 Husaberg plated
01 DR Frankenbike 650
76 CB750
bobzilla is offline   Reply With Quote
Old 09-09-2012, 02:48 PM   #5470
Beer'o'clock Baz
Beer'o'clock Baz's Avatar
Oddometer: 1,759
Thankis mate - being in aus dont think i could get them sent over - hammerhead are outa stock and my dealer has another four weeks to wait with 8 sold already , his eyes kinda rolled abit when he said four weeks aswell
do you work for one of the shops
But the fact that some geniuses were laughed at does not imply that all who are laughed at are geniuses. They laughed at Columbus, they laughed at Fulton, they laughed at the Wright Brothers. But they also laughed at Bozo the Clown.
Carl Sagan
Beer'o'clock Baz is offline   Reply With Quote
Old 09-09-2012, 05:36 PM   #5471
.chris
690 Advenduro
.chris's Avatar
Oddometer: 94
Originally Posted by Gros Buck View Post
Well
Paul Jr
And a special prize for Gros Buck ... Turns out it is a T50, not a T45, now I get to try again with a half stripped bolt and the right sized Torx, might have better luck this time.
I am interested in the future, because it's where I am going to live
.chris is offline   Reply With Quote
Old 09-09-2012, 05:37 PM   #5472
.chris
690 Advenduro
.chris's Avatar
Oddometer: 94
Originally Posted by Night Falcon View Post
why ya taken off ya shock for?
Time for a service. Forks are already off, just having trouble with this one bolt.
Old 09-09-2012, 06:43 PM   #5473
DirtJack
DirtJack's Avatar
Oddometer: 1,598
I think you have to turn the riser 180 degrees because, as you have it mounted, the pivot axis of the damper is not centered on the turn axis of the steering head, or to put it another way, this mount does not support the forward location of the bars. Putting a longer arm on the damper will not solve your problem.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-10-2012, 12:03 AM   #5474
Czechie
Czechie's Avatar
Oddometer: 75
Thanks Beany, have not noticed this product in your e-shop. However, the last statement makes me worry because I use the bike even for commuting to work (being on motard wheels) so I dont want to lose the possibility of locking the stearing. Is that really true or is there any work around?
Cheers. D
NOTE:WHEN THIS IS FITTED,THE STEERING LOCK CANNOT BE USED
Old 09-10-2012, 05:07 AM   #5475
Buzztail
NMBBMFBK
Buzztail's Avatar
Oddometer: 10,987
Can injector o-rings be sourced locally? Finished the bike up and it has a leak at the 90 elbow where it enters the injector housing. Anyone have a part number that can be picked up in town or will I have to wait on shipping?
My bad
Times are GMT -7.   It's 09:01 PM.
