Old 09-07-2012, 03:50 PM   #2701
OzRider64
Friggen slow Adventurer.
OzRider64's Avatar
Oddometer: 90
Cry model 44's on the blink, not happy.
G'day Sanjoh,
Back in October of last year I purchased a set of model 44's off you. Only got to fit them to my bike in Feb of this year.
For the first couple of months they worked fine. My bike is a 2010 R1200gs. The lights are fitted to a PC8 Fuse block with a IQ-170 from Skeene Products and a mini switch from Cyclenutz which is used to turn the lights on.
I sent you a post a couple of months ago regarding the flickering in one of the lights and you told me not to worry.
Well a week ago the other light went out totally and the other lights flicker is getting worse.
Decided to pull the tank of last week and check all the connections again. Everything checked out fine. Disconnected the mini switch and ran the lights through the IQ-170 same problem. Disconnected the IQ-170 and ran the lights connected to the battery same problem.
I understand from your website the lights had a limited warranty and I am well outside that time frame. I am more annoyed that other people are having a good run from them. I suppose Chinese manafactured items can have variable quality. Only three weeks ago I had to replace a ballast on my 35w HID from DDM which I have had on for the same time as the modell 44's.
Sanjoh, I don't no what to do here. Do I purchase another set and take the risk??. Can I send them back to you to have a look at or do I bin them and go for a set of Clearwaters.
Any help would be much appreciated Sanjoh.
Simon.
Tassie, where two heads are better than one.
2010 R1200GS
OzRider64 is offline   Reply With Quote
Old 09-07-2012, 04:32 PM   #2702
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,054
Hi Simon,
If you purchased in October of last year, the lights are still under warranty. Please contact me by email sandjoh@gmail.com for further instructions.
Old 09-08-2012, 05:36 AM   #2703
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,290
Originally Posted by SV_Dwayne View Post
Wouldn't it work better to flip the mount around, so the center of gravity of the body of the light is directly over the mount rather than in front? It would have less leverage on the pivot screw that way.
Tried that, don't remember why it didn't work, solution was to remove the bracket once the lights were aimed. That gave me access to the bolt & jam nuts. Lights haven't moved since.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 09-08-2012, 12:11 PM   #2704
Rainier_runner
Epic Adventurer
Rainier_runner's Avatar
Oddometer: 288
60's, volt meter, flashlight!
Order placed! Can't wait to get these 60's mounted up, and to test out the flashlight! They'll be WABDR tested the last week of the month. Pics will ensue.
Thanks.
Rainier_runner
2014 KTM 1190 Adventure R
2006 Suzuki DR 650 ADV
Rainier_runner is offline   Reply With Quote
Old 09-08-2012, 01:03 PM   #2705
Jazz62
Jazz62's Avatar
Oddometer: 1,011
Some pics of the model 60's
Finally got a chance to get some pics of the model 60's on my '00 1150GS. Back wall of the garage is approximately 55 feet away. These pics are a very accurate representation (to my eyes) of how the output of the model 60's really look. Everything shot in full manual mode using a Nikon D90 and a Tamron 18-50mm 2.8 lens. No editing of any kind aside from JPG conversion.
I don't see how you could beat the performance of these lights at anywhere near the price.
***The only disclaimer is that in these pics the projection angle of all the lights is slightly lower than they would be if I were sitting on the bike***.
Pic 1 - Nothing but ambient lighting courtesy of City of Chicago
Pic 2 - 35W HID low-beam only
Pic 3 - 35W HID lowbeam and advmonster model 60's at 100% - SHAZAM!
Pic 4 - 35W HID lowbeam, 55W halogen highbeam, advmonster model 60's at 100%
Pic 5 - advmonster model 60's at 100%, no lowbeam or high beam
Jazz62 screwed with this post 09-09-2012 at 01:28 AM
Jazz62 is offline   Reply With Quote
Old 09-09-2012, 01:05 AM   #2706
viz
I Ride Ms Piggy
viz's Avatar
Oddometer: 1,813
Front lens broke...
Hey Sanjoh - just had a small rock go through the front lens on a 40 . The glass broke into shards which is not the safest...
Replaced the lens with an old one from a 10 that I had lying around - what are the chances of future lights having a lexan or polycarbonate front lens? Don't think it would add too much to the cost...
viz
Pig In The City - 2010 BMW R1200 GSA Adventure
Webmaster BMW Touring Club of NSW
viz is offline   Reply With Quote
Old 09-09-2012, 04:24 PM   #2707
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
Sanjoh, I got your lights in yesterday (Holy crap! FAST shipping. I ordered Thursday afternoon and they arrived at my door on Saturday with standard shipping selected!). I went to install them and realized automotive wiring is definitely not my thing. I want to wire them independent of any of the headlights so that I can flip them on and off regardless of whether the high or low beams are on or whether the keys are on, etc.
In my simplistic mind, it makes sense that I can just add an inline fuse and switch to the hot wire and just run the negative wire to the negative terminal of the battery. Here is a quick diagram of my proposed wiring plan:
Would I need a relay or a voltage regulator or anything? Is that diagram complete crap?
If anyone else has my answer, please feel free to jump in. This isn't just directed toward Sanjoh.
'09 Suzuki SV650, '02 KLR250, CRF70 and 80 for the kids IBA # 56419
Newfoundland 2012
James Bay 2014
max384 is offline   Reply With Quote
Old 09-09-2012, 04:32 PM   #2708
Jazz62
Jazz62's Avatar
Oddometer: 1,011
You'd want the switch after the fuse, wouldn't you?
Old 09-09-2012, 04:36 PM   #2709
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
Would you? I honestly have no idea. I never gave that even a second thought. It was arbitrary where I placed the fuse and switch in that diagram.
Newfoundland 2012
James Bay 2014
Old 09-09-2012, 04:36 PM   #2710
RoundOz
Plenty of seasoning
Oddometer: 1,004
Pretty close...
Generally a fuse should protect the whole circuit from shorting to the frame, so close to the battery and before the switch is best. As long as your wire and switch are rated for the amps you don't need a relay. (eg, a 10 amp switch and #14 wire should be heavy and physically robust enough for this small of a load. You could probably go smaller but won't save much money.
2009 KTM Adventure
RoundOz is offline   Reply With Quote
Old 09-09-2012, 05:01 PM   #2711
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
Thanks. I'll make sure to put it between the switch and the battery than. The rest of the diagram looks okay though?
The switch I have is rated to 30amps. I have an inline mini-blade fuse holder rated to 30 amps. I figured I'd use a 5 or 10 amp fuse since the lights are only 0.85 amp each. I already have 18ga wire, so I guess I'd just use that since they can handle roughly 16amps. Plus the wires from the lights look to be about 20ga, so that should work out fine, I would think. What do you think?
Newfoundland 2012
James Bay 2014
Old 09-09-2012, 08:05 PM   #2712
watagans300exc
watagans300exc's Avatar
Oddometer: 108
Hey Sanjoh,
Will your rotary dimmer control the output of a 55 watt HID ballast? Or will the smoke come out of both......
Cheers,
Tony.
watagans300exc is offline   Reply With Quote
Old 09-09-2012, 09:43 PM   #2713
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
Just got 'em mounted, wired, and properly aimed. Thanks for the wiring help guys.
Wow! What a difference they make! I'm definitely glad I went with the model 30s for extending my low beams out a bit. The tight pattern is just what I needed.
Newfoundland 2012
James Bay 2014
Old 09-10-2012, 05:27 AM   #2714
RoundOz
Plenty of seasoning
Oddometer: 1,004
I think your work is just fine. I guess I assumed you were wiring a pair of 60s, which would pull more amps. Even so, the difference in voltage drop (the loss caused by the resistance of the wire)between 14 and 18 gauge is probably negligible and affects led lights less than halogens anyway...with 100 W halogens you can see the difference in the color and power of the beam if you go cheap on the size of the wire, and worse case you will melt it.
I personally prefer to stay at or larger than 14 for any additional auto wiring, but I have to admit it is mostly from old habits in dealing with larger loads and greater distances that tintops impose. There is something to be said for the thicker insulation that larger wire generally has, but if smaller wire is routed and secured the right way that becomes less of an issue.
An important point is that your wire needs to have enough current carrying capacity to blow the fuse you have installed. From your figures you have allowed for this. Many trailer homes are reduced to a pile of ash ( some would say this is an improvement) because they have very few outlet circuits, and fuses or breakers have been replaced with larger sizes to prevent nuisance tripping from a larger load than the wiring was designed to carry. In a well-designed circuit, the fuse will stop current flow before the colorful plastic falls off.
A fire on a bike is a scary thing. One of mine had flames coming from under the tank as I stood next to it at the gas station with the gas cap open and fuel filler hose in hand. It was an OEM starter solenoid that picked the least fortunate moment to melt down. No fuse between the battery and the solenoid meant that all the smoke got out and it quit working. Some cobbled together parts from NAPA got me going again and the only permanent damage was to my undershorts.
2009 KTM Adventure
Old 09-10-2012, 05:44 AM   #2715
max384
Disgruntled Student
max384's Avatar
Oddometer: 3,338
I should have specified the lights I was using. I had actually started another thread a few weeks ago asking about LED lighting options. Once I found this thread, I abandoned my other one to post here... But neglected to mention the lights I had decided on.
Yikes! That is definitely a bad time to have flames pop out from under your seat! I have a friend who had his Daytona 675 burn to the ground due to a shorted wire. Luckily his decided not to fail on him at the gas pump.
Thanks for all your help with this.
Newfoundland 2012
James Bay 2014
Times are GMT -7.   It's 08:40 AM.
