Old 09-05-2012, 06:24 AM   #61
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,870
Originally Posted by Sporting Wood View Post
What was wrong with the old ones?
Mine started to disintegrate....mounting tabs broken off and cracks all around...after only about 300-400 miles...
So what is the solution for the relocated crank case breather hose mount? Buy some longer hose?
It is directly above the throttle body wiring cluster....
Mike
Reinheitsgebot
'07 990ADV '08 530EXCR '04 XR650L
Bonsai Elephant - "
Life without a 990 is no life at all!"
Michhub screwed with this post 09-05-2012 at 06:26 AM Reason: add new plate pic
Michhub is offline   Reply With Quote
Old 09-05-2012, 07:26 AM   #62
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
When I received my new baseplate I noticed the new location of the breather and asked Chris at CPR Fab about the hose length. He said it should reach even if previously trimmed for the old mount. I think you need to route the hose between the throttle bodies. That what I'm going to try.
I've not tried to install it yet but looking at your pics I think I better have a look at my baseplate
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 09-07-2012, 10:42 PM   #63
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Original baseplate broken
Do today, I decided to replace my original baseplate with the new improved version. I'm glad I did!
After removing the temperature sensor I discovered that the holes for the mounting screws are too large on the new baseplate
I guess it's off to the hardware store tomorrow to find a solution
Moto-Treks
Old 09-08-2012, 01:02 AM   #64
Spark01
V-Twin
Spark01's Avatar
Oddometer: 305
Just a small question, (because mine still looks ok after couple of 1000 km's) .
Are there small pockets made in the underside of the orginal old type base plate?.
Because my tuner made total of 3 pockets in there (1x for the idle speed motor, 1x for the 2nd valve motor, 1x for the linkage of the second throttle, this was reported back to CPR in june).
If those pockets aren't there then the base plate isn't straight on the throttle bodies (due to idle speed motor and/or the 2nd valve motor) and is put under a lot of stress.
And can cause early life time failure of course.
P.S for the problem with your new base plate i would contact Chris at CPR, their customer service is good.
'10 990SMT
Spark01 screwed with this post 09-08-2012 at 01:13 AM
Spark01 is offline   Reply With Quote
Old 09-09-2012, 05:27 PM   #65
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Mine had only the one near the temp sensor. My 2nd valve motor didn't contact the base plate but the idle motor did ever so slightly.
Moto-Treks
Old 09-09-2012, 06:38 PM   #66
Michhub
Major Medical
Michhub's Avatar
Oddometer: 3,870
+1.....but I had to create the relief myself....Chris told me the development was done with the secondary valves/motor/linkage removed. The new plate has relief all around...sorry no pics. The crank case vent line will reach....mine was caught between the frame and valve cover, once that was free...route between the throttle bodies and all was ok. The temp sensor mount for me was a bit tight but I put the screws in from the bottom up, the holes were smallish....just had to encourage the holes to loosen up with a poker....
I also found the mounting of the filter to the new plate a total bitch....couldn't hook the lip for at least 20 minutes but now its a 'Honkin' good time
Mike
Reinheitsgebot
Bonsai Elephant - "
Old 09-10-2012, 07:00 AM   #67
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Yeah, the new base is totally different on the bottom
Moto-Treks
Old 09-10-2012, 08:02 AM   #68
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Just about the time I decided to run to the hardware store for some bolts, Chris responded to an email I send confirming that there should have been 2 bolts with nyloc nuts - must have lost them
Anyway, a short time later I had the temp sensor all mounted in the new baseplate
The breather was a very tight fit. I tried for about a minute to get it to fit and just about the time I thought I'd have to enlarge the hole it popped in.
Here is the new baseplate all ready to be mounted on the 990
Moto-Treks
Old 09-10-2012, 08:17 AM   #69
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Breather Rerouting
You need to reroute the breather hose from the stock forward position to run between the throttle bodies.
Like Michhub, I found the hose stuck between the valve cover/frame but it wasn't too hard to reroute it to between the throttle bodies.
Even though I had cut the hose for the original mount it had enough material to match up to the new location on the baseplate.
Moto-Treks
Old 09-10-2012, 08:35 AM   #70
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
Next was moving the wires located under the new breather hose location
I cut a tie wrap or two and moved the wires out of the way so that I could get the hose connected.
and then, repositioned the wires near the rear throttle body
Here's the new baseplate mounted on the 990 waiting for a filter
and all ready to go
Just need to button the whole think back up and give it another test ride.
BTW, I had about 1k miles on the filter and it was a bit dirty on the outside be totally clean on the inside
Moto-Treks
Old 09-10-2012, 08:59 AM   #71
dad2bike
Cranky Old Fart
dad2bike's Avatar
Oddometer: 4,076
I sure wish you had posted up that pic before yesterday. When I put the new baseplate on I screwed up and then had to take it apart again to put the valve on correctly.
All of your pics are great!
Tom
2006 950 Adventure "Big Orange", 2009 690R "Ginger",2003 525 EXC,
To Think is to Create!
My2Wheels
690 WIKI
dad2bike is offline   Reply With Quote
Old 09-15-2012, 09:09 PM   #72
-GUV-
Oddometer: 244
I have just got back from my first ride since installing a CPR filter & removing the 2nd flys (shafts still in place), mine now has the expected induction noise but it also has an annoying whistle when I roll the throttle on, I thought that it might be air rushing through the screw holes in the fly shafts so I reinstalled the screws to no avail. Has anyone else had the same problem and found a solution?
-GUV- is offline   Reply With Quote
Old 09-15-2012, 10:29 PM   #73
moto-treks OP
Back Home
moto-treks's Avatar
Oddometer: 1,800
I've not heard that whistle. Have you tried reinstalling all of the secondary flys? You can always set them to 100% open with tuneECU.
Moto-Treks
Old 09-15-2012, 10:40 PM   #74
-GUV-
Oddometer: 244
Funny that you suggest that, I've just been out testing again since reinstalling the flys, still whistles, it's similar to a leaking flange gasket only it is quiet during tame thottle use.
Old 09-24-2012, 01:08 AM   #75
-GUV-
Oddometer: 244
Fixed
I rotated the rubber intake sleeves 180deg as they aren't very well port matched, no more noise.
Times are GMT -7.   It's 06:48 PM.
