Old 09-12-2012, 09:36 PM   #46
Yellow Pig
Allergic to Asphalt!
Yellow Pig's Avatar
Oddometer: 7,477
Originally Posted by crankshaft View Post
Just as an FYI, the MX1k rules don't allow LED tail lights.
Any special reason for this quirky rule?
Old 09-12-2012, 09:38 PM   #47
GalacticGS
1200 GS Rider
GalacticGS's Avatar
Oddometer: 2,257
I read the rules as stating that LED tail lights don't satisfy the requirement for a rear reflector, but if you add a 2" reflector (or reflective tape) then you've satisfied the rule. I don't see the rule as banning LED tail lights. Am I incorrect?
NCR7: REFLECTOR
All 4-wheel vehicles must have two red reflectors of at least 2" diameter each or two 2-inch round red reflectors (DOT stock taillight lenses satisfy this requirement) attached to the rearmost portion of vehicle at each corner. The reflective tape or reflectors must be clearly visible from the rear. LED lights are non-reflective and do not meet this requirement. Motorcycles and ATV’s must have one (1) 2" red reflective device.
NCR17: LIGHTS
All bike and quad entries must have one (1) headlight and one (1) taillight. The taillight must be on and operational at all times. The entry may not be allowed to start a Special stage unless the taillight is operational.
Thanks for any insight or clarification.
Larry
2006 R1200GS; 2009 Husaberg Rally 570; 2011 Husaberg FE570
www.galacticgs.com
"Speak to me of summer, long winters longer than time can remember;
Setting up of other roads, travel on in old accustomed ways."
GalacticGS is online now   Reply With Quote
Old 10-02-2012, 11:30 PM   #48
640 Armageddon
-oo-
640 Armageddon's Avatar
Oddometer: 2,633
Originally Posted by Baja Dad View Post
I have A older style Sub frame that you are looking for.
maybe we can work out a trade?????
I also have a extra new style Rear fender and side panels if that is the way you want to go.
I added a Dust light to my rear rack and keep my 07 rear fender and tail light.
That is not a quick response but this thread slipped down a bit
I thought I have seen somebody here who managed to put the old style plastics to the newer bike. Did not know that the subframe is different ... I have the rear fender at the moment and I will have to check if it fits. I will do this at the near future and if it does then we may be able to work out a trade with the plastics you have with the new Navigation Tower I will have for the 640 ... If I need the subframe as well we will go for the full montY
Any updates with the bike Maineroot ??
Aurora Rally Equipment - Rally parts with lifetime warranty
"Do or Do Not. There is No Try" - Yoda
640 Armageddon is offline   Reply With Quote
Old 10-03-2012, 05:51 AM   #49
Pantah
Patriot Nation?
Pantah's Avatar
Oddometer: 10,133
subscribed - i'll follow this until the finish line. good luck and have fun getting ready.
Straight ahead and faster -Bo Weaver 1970
"There I was..." -Griffin Niner Three Hotel
"One day closer to a parade..." Jonny Gomes, spring training 2013
Pantah is offline   Reply With Quote
Old 10-03-2012, 06:47 AM   #50
Maineroot OP
Oddometer: 142
I'm waiting on parts to show up.
I should be back to the build next week.
#34 MX1K
TEAM GREENWOOD: Kali Protectives, Hammer Nutrition
Maine Root Handcrafted Beverages, Darco Boot, ATOMIC MOTO,
Klim Riding Gear, Flexx Bars, Seat Concepts Seats, CJ DESIGNS PEGS, FORMA
BOOTS, Tj's Cycle, Austin TX
Maineroot is offline   Reply With Quote
Old 10-03-2012, 09:03 AM   #51
Baja Dad
Baja Dad's Avatar
Oddometer: 1,973
Come on !!!
Get on with it !!!!!
Do they do everything SLOW in Texas?????
2015 support: Multitool,GPS IMS Aurora Rally Kriega, Raiden LS2, Helmets,
100Goggles,SIDI,Seat Concepts, Precision Concepts, MX1West,Dunlop
Baja Dad is offline   Reply With Quote
Old 10-03-2012, 11:07 AM   #52
wrk2surf
on the gas or brakes
wrk2surf's Avatar
Oddometer: 6,696
the earlier 620 subframe used different plastic and a larger airbox that accepts the larger 450-525 airfilter/cage but has no battery space... but dont ask me bout this
I dont think the plastics match up as the earlier one had a flat bar across the rear and the newer has one with a punched out gusset that rises higher to add a little suspension bottoming room. You can add some type of spacer on the older sub to fit a new style OEM rear fender. But there is many threads on this in the thumper section especially one by laramie about different colors that the LC4 wears.
wrk2surf is offline   Reply With Quote
Old 10-19-2012, 08:08 PM   #53
Maineroot OP
Oddometer: 142
Parts ARRIVED
I got back from a week trip to Boston and found a pile of parts from the brown Santa (UPS MAN).
Seat Concepts seat was the first thing I got into. Lendon did this one up in SUEDE with a custom pocket at the front to keep your score card in for timing. It looks amazing.
If this seat is anything like what Seat Concepts did for my other bike, I am going to be impressed.
GREAT WORK SEAT CONCEPTS!!! You can see their fine work here: http://www.seatconcepts.com/
#34 MX1K
Maineroot screwed with this post 10-19-2012 at 10:08 PM
Old 10-19-2012, 08:14 PM   #54
Maineroot OP
Oddometer: 142
Cj designs pegs
Next thing in the box was a set of CJ DESIGNS PEGS. These bolt right up to your stock pegs offering a larger platform.
They come in 2 sizes. See pictures below. I am going to test these out and decide which ones would work best for the rally bike. They make total sense, and look cool as hell!
Craig makes some really trick stuff for the ADV crowd. Check out the website below for more info.
http://www.cjdesignsllc.com/
http://www.dualsportwarehouse.com/CJ...tension-FP.htm
#34 MX1K
Maineroot screwed with this post 10-19-2012 at 10:06 PM
Old 10-19-2012, 08:46 PM   #55
Superpacman13
Superpacman13's Avatar
Oddometer: 252
Subbed in
KTM's:14' 150XC 08' 450SX-F 06' 560SMR,'77 RD 400, 73' G3SS-C
Superpacman13 is offline   Reply With Quote
Old 10-19-2012, 10:13 PM   #56
Maineroot OP
Oddometer: 142
Rear Spring
I yanked out the shock to replace the spring with the heavier unit.
It was a bit of a pain in the rear. You have to undo the top and bottom bolts, then take out the linkage bolt. ..... actually it was easy.
Then raise the rear tire so the swingarm is about parallel with the ground. Rotate the entire shock counter clockwise so the resevoir can clear the opening and wiggle it out. That was the hard part. Took about 10 min.
To swap the spring you just back off the preload ring, then the spring is loose on the shock. The retainer ring will pretty much fall down and you then remove the retainer ring, and pull the spring out. Swap in the new spring, and put the retainer ring back in place while you snug up the preload to hold it all in place.
Then back in it goes. wiggling the new spring and shock in place took some time to get it all to slide in. Once in place, I put the top bolt in, then the bottom bolt, then I used a combination of the jack stand to align the swingarm to about the right spot- then got a screwdriver in the hole to line up the linkage and hold it in place.
Then I chased the screwdriver end with the bolt from the opposite side. All done.
The only thing that sucks is that the new spring is a boring black color. I liked the old white one- it looked cool.
#34 MX1K
Maineroot screwed with this post 10-19-2012 at 10:21 PM
Old 10-19-2012, 10:21 PM   #57
oregoncoast
Racing Like a Noob
oregoncoast's Avatar
Oddometer: 4,494
NCR7: REFLECTOR
NCR17: LIGHTS
All bike and quad entries must have one (1) headlight and one (1) taillight. The taillight must be on and operational at all times. The entry may not be allowed to start a Special stage unless the taillight is operational. Thanks for any insight or clarification.
Never had an issue with our LED taillight.
Old 10-20-2012, 12:12 AM   #58
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,045
Sounds like grounds for a DQ to me..........................
pfdskipper is offline   Reply With Quote
Old 10-20-2012, 12:20 AM   #59
oregoncoast
Racing Like a Noob
Oddometer: 4,494
Old 10-20-2012, 01:03 AM   #60
erdsh
KTM 640 Adventure
erdsh's Avatar
Oddometer: 104
KTM 640 suspension
I own a 2001 KTM 640 ADV, and I must say that after rebuilding my front and rear suspension and installing RaceTech bladder in the rear and RaceTech Gold Valve in the front, there is a vast improvement in the suspension operation mainly in high speed and in tough terrain.
Most recommended.
A local suspension expert did the work for me.
Good luck.
TT600S
XTZ660Tenere
Cagiva Elefant 750
TT600R
KTM300EXC
CR125
YZ125
and many other...
erdsh is offline   Reply With Quote
Times are GMT -7.   It's 06:03 AM.
