Old 09-12-2012, 08:09 PM   #5506
nippybit
Nippybit
nippybit's Avatar
Oddometer: 92
Norris Kick
Originally Posted by Pantah View Post
Hey Nippyman - You have my kind of profile and I've never got that Norris kick down right. Since you ARE my senior, I should listen up better. The last time I got stuck like that I simply dropped her splat and stepped off.
The nice thing with the 690 is we can still pick her up!
Hey Pantah, yeah I think we are both old guys and the good news is we are still riding and, as you say, we can pick up the damn thing if we tip over. I think we both have the motorcycle and general need for speed sickness as well. I understand it is not curable and is a lifetime affliction. BTW I can do part of the Norris kick to try to clear the luggage and if I succeed I then need to have physical therapy for my back. So, I continue to use the footpeg for easier mounting. Give the kickstand foot a try.
Cheers
2010 KTM 690 R (sold 12/11/12)
Previous bikes (way too many to list here and what's the point)
Been riding mostly off-road since 1960--began at age 14.
Watch this space as I am about to say something really prophetic!
nippybit is offline   Reply With Quote
Old 09-12-2012, 09:46 PM   #5507
Sparrowhawk
Sparrowhawk's Avatar
Oddometer: 2,287
Crank, just curious. Some think the 690's tranny is too narrow to deal with difficult singletrack & high speed tarmack. I was wondering what you thought and if tranny work was part your agenda. Cool project!
Sparrowhawk is offline   Reply With Quote
Old 09-13-2012, 01:20 AM   #5508
LukasM
Oddometer: 5,426
What tranny work? There is nothing that could be done as nobody will ever produce a different set of gears for this bike.
Old 09-13-2012, 04:13 AM   #5509
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,820
I imagine for the racing Crank does, the tranny is just fine.
Old 09-13-2012, 05:01 AM   #5510
yuu
yuu's Avatar
Oddometer: 122
Originally Posted by motoged View Post
So.....that clutch lever has that magic dimple/bump on it that all other after market levers are missing??
Seems so. Im able to start the bike while in gear, with the lever pulled.
yuu is offline   Reply With Quote
Old 09-13-2012, 11:27 AM   #5511
motoged
motoged's Avatar
Oddometer: 908
Thanks for the reply
Ged Schwartz
Kamloops , BC
Baja '05 , Baja 06/07 , Baja 08/09 , BC Alpine Single Track
motoged is offline   Reply With Quote
Old 09-13-2012, 11:33 AM   #5512
yuu
yuu's Avatar
Oddometer: 122
No problem. it does take a bit of getting used to, as the relationship between the lever and pivot is different (duh) - so it has a different feel to the hand - but not bad or anything negative, just different.
It has adjustment for free play AND stop so you can tweak the position a bit more than the stocker and not waste lever travel after the clutch has fully engaged. Though they are not finger adjustments - you'll need a small (3mm if I recall correctly) allen key to make any changes.
Old 09-13-2012, 11:56 AM   #5513
tonykof
Dinosaur Tamer
tonykof's Avatar
Oddometer: 159
Originally Posted by nippybit View Post
The "hop method" works great if you are Chuck Norris and know how to do a side kick. I have the same issue of clearing luggage especially my KTM tail bag. Pantah, you might try a kickstand foot for extra stability on soft ground, sand, or gravel. They aren't perfect but do help quite a bit. I have the Touratech foot and it cost about $30 as I recall. I am sure other companies make these as well. When installed it also gives you a bigger target to hit with your foot when you are trying to put the kickstand down.
I use the "moving horse method" to get on when ever I can as I'm totally "ballerina toes" otherwise...
"Moving horse method" = kickstand up , bike in gear, left foot on the peg, slip clutch to get moving stand up on left peg & throw right foot over..."moving horse"
Doing the "Chuck Norris" I'm always afraid i'm going to catch & rip the seat with my boot...
BMW R1150GS
KTM 640 Adventure
KTM 525 EXC
KTM 350 XCF
tonykof is offline   Reply With Quote
Old 09-13-2012, 12:51 PM   #5514
Gros Buck
Beef = Packed Vegetables
Gros Buck's Avatar
Oddometer: 848
Ok Ged ... You do the guiney pig. You buy it. Install it, and check it. And if it works you tell us ... I'm also shopping for short handles ...
Paul Jr 8
KTM690r 2011
Gros Buck is offline   Reply With Quote
Old 09-13-2012, 03:13 PM   #5515
DirtJack
DirtJack's Avatar
Oddometer: 1,600
Motion Pro makes levers which I use on all three of my KTMs. Much cheaper too.
Remember, you're reading this on the Internet and it was written by a guy who can remember stuff which never happened.
2014 KTM 1190 Adventure R
2008 KTM 300 XC (plated)
2008 KTM 690 Enduro
DirtJack is offline   Reply With Quote
Old 09-14-2012, 12:31 AM   #5516
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 786
Anybody run a bar mounted windshield?
This year I did 5200k in 7 days and atleast 3 days of that was burning highway. I'de like some protection as im planning a similar ride for the spring.
Thoughts anybody? Im 6'3" should I just man up again?
tattewell is offline   Reply With Quote
Old 09-14-2012, 01:23 AM   #5517
francs
Oddometer: 270
I tried Givi A660 (I'm 6'2) and it did not work as I expected, I got the wind at the top of my helmet (it's annoying). And the windshield began to "move" Because of the bar design is difficult to tighten the clamps (and it's very "crowded" on the bar to find a place to put the clamps). When I'll have time I'll experiment a bit with the settings.
francs is offline   Reply With Quote
Old 09-14-2012, 01:37 AM   #5518
motoged
motoged's Avatar
Oddometer: 908
Originally Posted by Gros Buck View Post
Ok Ged ... You do the guiney pig. You buy it. Install it, and check it. And if it works you tell us ... I'm also shopping for short handles ...Paul Jr 8
Paul,
Thanks for the "encouragement" but I have Cycra barkbusters on the bike and for extra security, extra clutch and brake lever spares....... I figured if I spent over $100 on spare levers, I would never need them; had I not bought the spares....would've broken the original levers
Ged Schwartz
Kamloops , BC
Old 09-14-2012, 02:16 AM   #5519
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 786
Thanks francs, maybe ill look more closelly at the rally raid fairing, but I was hoping to be able to just put the screen on for the highway bits, then strap it to my paniers for the fun bits through Slovenia, Croatia, Hungary and Romania...
Old 09-14-2012, 02:26 AM   #5520
mtntrails
Oddometer: 471
http://www.slipstreamer.com/Product/Sport/sport.html
The Slipstreamer Spitfire is my favorite windscreen for dual sport bikes. They are inexpensive, very adjustable, easy to remove and do a terrific job of keeping the wind off of your upper body.
mtntrails is offline   Reply With Quote
Times are GMT -7.   It's 09:55 AM.
