09-13-2012, 05:01 AM
#5536 |
Oddometer: 109
09-13-2012, 11:27 AM
#5537 | |
Oddometer: 542
Ged Schwartz Kamloops , BC '96 GS 1100 '04 450 EXC '09 690 EXC Baja '05 Baja 06/07 Baja 08/09 BC Alpine Single Track |
09-13-2012, 11:33 AM
#5538 |
Oddometer: 109
No problem. it does take a bit of getting used to, as the relationship between the lever and pivot is different (duh) - so it has a different feel to the hand - but not bad or anything negative, just different.
It has adjustment for free play AND stop so you can tweak the position a bit more than the stocker and not waste lever travel after the clutch has fully engaged. Though they are not finger adjustments - you'll need a small (3mm if I recall correctly) allen key to make any changes. |
09-13-2012, 11:56 AM
#5539 | |
Oddometer: 134
"Moving horse method" = kickstand up , bike in gear, left foot on the peg, slip clutch to get moving stand up on left peg & throw right foot over..."moving horse" ![]() Doing the "Chuck Norris" I'm always afraid i'm going to catch & rip the seat with my boot...
KTM 690R Enduro KTM 525 EXC Yamaha WR250F |
09-13-2012, 12:51 PM
#5540 |
Beef = Packed Vegetables
Ok Ged ... You do the guiney pig. You buy it. Install it, and check it. And if it works you tell us ...
I'm also shopping for short handles ...Paul Jr 8
KTM690r 2011 |
09-13-2012, 03:13 PM
#5541 |
Oddometer: 347
Motion Pro makes levers which I use on all three of my KTMs. Much cheaper too.
Proud to be supporting Pyndon in the 2013 Dakar ! 2007 KTM 990 Adventure 2008 KTM 300 XC (plated) 2008 KTM 690 Enduro 1998 KTM 400 RXC (sold) |
09-14-2012, 12:31 AM
#5542 |
Mad Poser
Oddometer: 607
Anybody run a bar mounted windshield?
This year I did 5200k in 7 days and atleast 3 days of that was burning highway. I'de like some protection as im planning a similar ride for the spring. Thoughts anybody? Im 6'3" should I just man up again? |
09-14-2012, 01:23 AM
#5543 |
Oddometer: 170
I tried Givi A660 (I'm 6'2) and it did not work as I expected, I got the wind at the top of my helmet (it's annoying). And the windshield began to "move" Because of the bar design is difficult to tighten the clamps (and it's very "crowded" on the bar to find a place to put the clamps). When I'll have time I'll experiment a bit with the settings.
09-14-2012, 01:37 AM
#5544 | |
Oddometer: 542
Thanks for the "encouragement" .. I figured if I spent over $100 on spare levers, I would never need them; had I not bought the spares....would've broken the original levers ![]() ![]()
09-14-2012, 02:16 AM
#5545 | |
Mad Poser
Oddometer: 607
09-14-2012, 02:26 AM
#5546 | |
Oddometer: 326
http://www.slipstreamer.com/Product/Sport/sport.html The Slipstreamer Spitfire is my favorite windscreen for dual sport bikes. They are inexpensive, very adjustable, easy to remove and do a terrific job of keeping the wind off of your upper body. |
09-14-2012, 02:36 AM
#5547 |
Mad Poser
Oddometer: 607
I find the gearing is fine up to about 110 - 120 Kph, anything above that and the mileage really starts to suck, so its no good for the slab anyways.
09-14-2012, 02:37 AM
#5548 | |
Mad Poser
Oddometer: 607
Have you put on on your 690? I'de be curious about pics if you have any, I guess that goes for any dual sport... Lighting is the next issue I was going to look at. Rally fairing solves both problems, plus fuel, but I never found fuel to be too big of a problem as I have 2 Kolpin cans on my paniers. |
09-14-2012, 03:01 AM
#5549 | |
Oddometer: 326
09-14-2012, 03:25 AM
#5550 |
Oddometer: 170
Givi is similar (shape and sistem) .
