Old 09-14-2012, 01:23 PM   #69121
WilderRider
WilderRider's Avatar
Oddometer: 1,785
Originally Posted by neo1piv014 View Post
However, mine came with green and blue wires. Before I solder it together, seal everything back up, and put the oil back in the bike, I want to know if they wound up making new replacement parts that are correctly wired. Just curious.
Mine came with red and white, but it is really not a problem if you have to reverse them after you put it all together. Like I had said, they do not seem consistent on the coloring. I would connect them OUTSIDE the engine case to make it easier to do this. I had to.
RISK: "The loftier your goals, the higher your risk, the greater your glory."
WilderRider is offline   Reply With Quote
Old 09-14-2012, 02:30 PM   #69122
neo1piv014
ADV in training
Oddometer: 619
Connect them outside the case? That's a damn good idea....
New question, what's the best way to get the damn phillips heads out so you can pull that coil? I just barely got one out, but the second one turned into a perfectly smooth cone the second I twisted the screwdriver.
_________________________
Ride videos
'01 DR650
"The impossible often has a kind of integrity which the merely improbable lacks."
neo1piv014 is offline   Reply With Quote
Old 09-14-2012, 02:38 PM   #69123
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
Originally Posted by ER70S-2 View Post
If I pulled out the camera when my ex looked like that, I'd get punished.
That's why I love the lady. It's OK she was smiling and laughing about it a minute later.
Old 09-14-2012, 03:09 PM   #69124
wayno
wayno's Avatar
Oddometer: 6,692
Originally Posted by Tex76 View Post
Ya keep us updated on the levers. The last owner of my DR cut his balls off to get a good fit with the handguards. I want to replace the whole setup.
I remember a guy who does not ride a DR anymore cutting the balls off then sliding the lever back into the whole that is on the bottom of ball and having some one heli-ark them back on...just a cheap suggestion.
There are also handguards that fit off the tripple tree that have room.
RIDE SAFE
"Never wrestle with a pig. You just get dirty, and the pig likes it. George Bernard Shaw
wayno is offline   Reply With Quote
Old 09-14-2012, 03:56 PM   #69125
WilderRider
Oddometer: 1,785
I think I ended up using an impact driver on one of them. One of them came out fine for me. The trick was having someone hold everything while I whacked (I believe my wife was supporting it against the footpeg while I did this because the wire is still attached). Of course, just in case of future need, I ended up replacing the phillips head with allen bolts (like the NSU screws). I do not remember the pitch or size now. I was waiting on the gasket, so I just took the screws down to Ace Hardware and matched them up.
Old 09-14-2012, 04:24 PM   #69126
neo1piv014
ADV in training
Oddometer: 619
I'm going to try getting my hands on an impact driver this afternoon when I pickup a soldering iron or some other way of connecting the wires in the right place. If that doesn't work, I'm really trying to make drilling out the screw my last option. Once I've got that taken care of, I'm definitely picking up some damn allen heads for everything that' got a phillips on it now. What the hell were they thinking...
Ride videos
'01 DR650
Old 09-14-2012, 04:50 PM   #69127
Kommando
Kommando's Avatar
Oddometer: 7,361
They're JIS, not Philips? I get tough screws out pretty easily with a cordless drill and a soft setting of the clutch. I gradually use a harder and harder setting until the screw breaks free. Just make sure to fully seat the bit in the screw head before applying torque.
Kommando is offline   Reply With Quote
Old 09-14-2012, 05:06 PM   #69128
Kommando
Kommando's Avatar
Oddometer: 7,361
Originally Posted by bross View Post
I didn't have any problems with the Tiger handling wise or find it to be any more of a handful than my DR is on our ride. I did crash twice, well one crash and one just set it down slowly. No damage to the bike and I didn't even have time to fit the BarkBusters before we left so I just had the crappy plastic hand guards, but I loosened the lever bolts so my clutch just twisted instead of snapping when I crashed.
This ride ended up being way tougher than I was expecting. I suck in sand and that crash isn't a reflection on the bike but more my ability or more accurately, lack of it. Probably would have crashed my DR there too. We rode about 50kms on power line roads, these were steep rocky, loose climbs and descents with a few washouts thrown in. I didn't have any trouble on that knarly terrain, just the sand.
A sand-capable front tire could make a HUGE difference until you build skills in the soft stuff.
Old 09-14-2012, 05:11 PM   #69129
Eddieb
Eddieb's Avatar
Oddometer: 974
I just bought the handguard extenders from Procycle, job done.
Originally Posted by Procycle website
Don't cut your balls off! I mean - don't cut the ball ends off of your levers. These billet spacers move your handguards outward to allow clearance for the full length of the stock levers. Designed to fit steel or aluminum bars. Includes longer stainless steel mounting bolts. Not compatible with Emgo
05 farkled DR650 - 86 BMW R80 with Velorex sidecar - 67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is offline   Reply With Quote
Old 09-14-2012, 05:48 PM   #69130
Kommando
Kommando's Avatar
Oddometer: 7,361
Originally Posted by Feelers View Post
Do you think that a 790cc kit and something like the Wee-Strom seat would be sufficient for 2-up adventure touring?
Unless the 2 of you are over 400lb or at altitude or something, you don't even really need the 790 kit for 2up touring. Just open the intake/exhaust and tune the carb. If you get it right, it'll do over 90MPH on stock gears, and it'll get there quicker than most factory-stock cages. Not running lean jetting also makes the bike feel a little cooler.
We ride the DR 2up a LOT (dirt, street, AND slab), and our only real issue is that the seat isn't very long. This means that we can't move around much. We're also crowded by a tankbag, tank panniers, a steep IMS tank, and a rear topbox. The rider and passenger pegs are lowered, touring pegs are bolted to the skid, and the seat is a Seat Concepts kit on the stock pan. I also have stiffer springs front and rear. The lowered rider pegs allow my knees to tuck nicely behind the tank panniers. The topbox is moved back 3-4" from where it would normally be.
We're 5'8"/200lb/30"inseam and 5'4"/petite/30"inseam. If you're much bigger than us, I'd suggest a more spacious bike like a DL. The lowered/touring pegs, seat, and springs are highly recommended for much 2up on a DR.
Old 09-14-2012, 07:10 PM   #69131
kamlander
Oddometer: 57
I wound up calling them yesterday afternoon and was told that my part was out for delivery that day. The lack of tracking notification threw me off as well, so I guess I judged a little harshly and a little early. Interestingly enough, did yours come with the red and white wires or the blue and green wires? The first post I read about replacing this thing was from a couple years ago and the general point was "came with blue and green wires, but you have to reverse them for it to work." Then, a couple people from more recently said "came with red and white wires. Put the red to green and white to blue." The company's website was even updated to show that it comes with the red and white wires and how to wire them in. However, mine came with green and blue wires. Before I solder it together, seal everything back up, and put the oil back in the bike, I want to know if they wound up making new replacement parts that are correctly wired. Just curious.
__
mine came with the blue and green, and a little note saying to reverse them. fired right up, fuck yeah. knocked out the screws with a little 12 volt impact driver, worked perfect. you may be able to get a dremel tool with a cutoff wheel inside the case and cut a slot in the head of the screw, rather than trying to drill it out. solder inside the case or out,either way pretty easy, did mine inside,just because. ________________
kamlander is offline   Reply With Quote
Old 09-14-2012, 09:05 PM   #69132
Feelers
Oddometer: 187
Question
My bike sounds a lot like yours - stiffer springs, IMS tank, lowered pegs, Aftermarket (Sargent seat)...
I know the 790 kit is unnecessary - just kind of an added benefit maybe. A longer seat would be the main thing. Do you think this would be sufficient? http://advrider.com/forums/showthrea...671846&page=31
Feelers is offline   Reply With Quote
Old 09-14-2012, 09:47 PM   #69133
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Works for me
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 09-15-2012, 11:50 AM   #69134
bross
Where we riding to?
bross's Avatar
Oddometer: 4,530
What's a sand capable front tire? I had new TKCs mounted front and back. Sand was a very small component of this ride, basically about 1 km stretch. Rest was mostly hard pack gravel and then steep, loose rocky climbs and descents. And what's your recommended method for getting through this? My wife took the advice of a fellow inmate and sat way back on her seat, 2nd gear, steady throttle and made it easily on her DR200 running IRC GP1s.
I was on the pegs, steering with the pegs, in 2nd gear but felt like the front got caught in a rut and wouldn't climb out and that's when the front washed.
So, how do you guys who are better at this do it?
Old 09-15-2012, 12:20 PM   #69135
Adv Grifter
on the road o'dreams
Adv Grifter's Avatar
Oddometer: 6,128
I've used a TKC 80 on my DR650 in Baja ... lots of deep sand. It worked very well. Also ridden my buddies Wee Strom with TKC's mounted up. Not bad but the Wee is not easy in sand.
There may be better knobbies for sand but they may not work great on highway ... and for sure won't wear as tough or as long as the TKC's do.
On real light weight dirt bikes (two stroke 250's) sand never bothered me much. When I got more into dual sport riding on 600 class 4 strokes in the late 80's I discovered I SUCKED at sand riding. But over the years ... with lots of practice, crashes and advice from "experts" I've got better at it. I even rode my DL1000 in some mild sand on several Baja and Mexico rides.
I don't believe there is a hard and fast method for sand riding to guarantee success riding a heavy bike. I've a buddy who is amazing in deep sand ... and he sits down through all of it. (XR600R)
For me ... I do better standing up. One of the most important technique, IMO, is LOOKING WELL OUT AHEAD. Ignore whats right in front of you ... fix your gaze far out ahead. Things just get easier. No idea why. It works.
Standing and keeping a very loose grip on the bars works well for me. Steering with your feet works too ... for me. But most important is looking ahead.
I keep my speed moderate and steady ... then when the bike starts to dig in or go squirrely ... I gas it a bit ... but as soon as I'm back under control I slow back down. In long stretches of very deep sand you must STAY on the gas and steadily increase speeds until your past the worst. NEVER slow down suddenly ... you will crash.
Some will say just gas it until the bike "planes out" . Sometimes hard to do on a very heavy, loaded up bike. In my early days in Baja I tried "gassing it" and ended up going 70 mph in deep Baja sand. If and when you crash at these speeds ... you are in trouble.
I like to go about 25 to 30 mph and then gas it just a bit to pull out of deeper sand, then slow back down. But everyone has a different approach. Seat time is what really helps. Work out what techniques work best for you.
Times are GMT -7.   It's 06:27 AM.
