Old 09-14-2012, 10:20 AM   #1
SCExpat OP
Ex-expat
SCExpat's Avatar
Oddometer: 634
How to turn?
So I have maybe 30 minutes "peg time" practicing figure 8's. I took a look at a Trials Training Center beginner video and they teach that you should lean the bike way over to turn. I have been just standing up vertical and turning the bars as far as I can. I tried turning leaning the bike over and it seems to work OK for me but.....I kinda like keeping the bike vertical better. Am I developing a bad habit that will cause me problems if/when I progress?
SCExpat is offline   Reply With Quote
Old 09-14-2012, 10:31 AM   #2
nwcycle
nwcycle's Avatar
Oddometer: 1,174
Call me!!!!
See your PM
nwcycle is offline   Reply With Quote
Old 09-14-2012, 10:46 AM   #3
motojunky
Professional Idiot
motojunky's Avatar
Oddometer: 1,085
Yes, you are developing a bad habit. I did the same with turning. I can turn "correctly" but I have to make a conscious effort - if I just ride naturally, I keep the bike near vertical and move my body incorrectly. Try to make the right way habit while you can.
motojunky is offline   Reply With Quote
Old 09-14-2012, 11:16 AM   #4
sanjoh
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,205
Videos have helped me with turning, more peg time is the answer!
Now how the heck can I make it acrose the balance board I mean it's only 10' long x 10" wide!
Old 09-14-2012, 02:27 PM   #5
Mike Mc
Mike Mc's Avatar
Oddometer: 88
Total noob here, but throwing this out anyways..
From what I understand, you want to lean the bike into the turn so it would naturally turn the amount you want without handlebar input. To accomplish this you shift the weight on your pegs to get the desired lean.
So you steer with your feet.
Corrections and upbraiding concerning this theory are cheerfully welcomed...
Mike Mc is online now   Reply With Quote
Old 09-14-2012, 04:12 PM   #6
dmay
Oddometer: 256
How ever far you are leaning try to keep your head above the center line of the tire contact patches with the ground,this will keep you from tipping into the inside of the turn. This is one area a vintage bike will teach you better than a modern,they won't turn unless you lean them,and they fall over if your weight is too far in. A leaned over bike will take torque from the rear wheel better than just turning the front wheel,but you'll need to shift the weight back to the outside peg with it still leaned over before applying power.
If you do your turns while straight up you need good throttle and clutch control to keep from pushing the front wheel out....Now If I could just practice what I preach
Doug
2011 Sherco 250 trials,83 Fantic 240 trials,1992 Fantic 309 trials,09 Kawasaki KLX250s,1984 SWM 320TL,03 KTM 640 Adv
dmay is offline   Reply With Quote
Old 09-15-2012, 08:40 AM   #7
SCExpat OP
Ex-expat
SCExpat's Avatar
Oddometer: 634
I knew there was a lot more to it than just turning the wheel......but I just want to believe it could be so simple. This is almost like learning to ride all over again and I expected to ride just like a dirt bike......but it is turning (no pun intended) out to be quite different.
Old 09-15-2012, 08:38 PM   #8
lamotovita
Ageing Adventurer
lamotovita's Avatar
Oddometer: 1,554
When I started riding Trials at 40, after having ridden motorcycles since my early teens and going all the way through a racing career, I didn't learn to ride all over again, I learned how to ride for the first time.
By the way, there's a Trial next Sunday at Hayden ID. Why don't you carpool with one, or more, of the Boise boys and come on up?
Beaten paths are for beaten men.
lamotovita is offline   Reply With Quote
Old 09-17-2012, 02:46 AM   #9
Bob_M
Bob_M's Avatar
Oddometer: 161
push on outside peg
I got a great tip this weekend and it worked great. Try to apply pressure on the outside peg by pushing hard as you turn and hold the pressure while you lean the bike over. It feels very different from standing up and will almost force you to stay on top of the bike.
To turn left, pressure onright peg while initiating the left turn and hold the pressure on the peg, try really pushing on the peg
Try this in some figure 8s.
It worked for me this weekend in Exeter, RI on the off camber sections and there were a lot of them.
Bob
1996 Gas Gas JTR270, 2001 Ducati ST4
1977 Honda 750F2, 1970 Honda QA50
Bob_M is offline   Reply With Quote
Old 09-17-2012, 04:48 AM   #10
lineaway
Oddometer: 3,010
http://trialstrainingcenter.com/how-...s/basic-turns/
lineaway is offline   Reply With Quote
Old 09-17-2012, 05:31 AM   #11
YOUNZ
Oddometer: 324
I suppose one could do the same with a Honda Gold Wing or a Harley if they where an acrobat? World class!
YOUNZ is offline   Reply With Quote
Old 09-17-2012, 09:03 AM   #12
SCExpat OP
Ex-expat
SCExpat's Avatar
Oddometer: 634
I just rode with Brian and Vern yesterday for my first practice session, outside of doing figure 8's in the driveway. They are training for the trials in Hayden. I have my inlaws visiting form Brazil so am stuck here. A bit different turning in dirt compared to pavement. I need to work on staying over the pegs (not get my head over the bars too much) staying relaxed and letting the bike move under me. I also learned that I do not need a 270cc bike even though I am big (250lbs). I wanted to go over a small rock.... only about 1 1/2 feet tall. Hit the gas to get the front wheel up and over.....and looped it!
So I also need to work on throttle control.
Old 09-17-2012, 04:03 PM   #13
DerViking
Shred
Oddometer: 350
Another useful training tool for trials in general, and turning in particular, is a Mountain Bike. Without a steering stop, you can turn very tightly, past 90degrees, which makes staying at the sweet spot more difficult than a moto. Bicycle is much harder to lean, so no help there per se.
Bicycle is also good for throttle. I know, totally different, but... Riding tight 8s on a hard surface has been good cross training for me. You need much less wheel turn than you'd think, on the inside of a corner. The bicycle is so internal that I feel it translates particularly well to the clutch/brake/throttle constant dance of the moto.
I ride a custom brazed steel "Trials 29er" a good friend built me. Its a real hoot on the trails, and is great for impromptu rock hopping. Hopping the front and rear on a bicycle is basically the same, but predictably easier. Good practice for refining your technique and precision, as well as your amplitude. Rear wheel hopping from object to object is easier to learn, and has helped me in drops and gaps. Cant wait for Sedona season!
I was a serious Bicycle Trial rider and Mountain Bike Racer before I rode Moto, and I know it has helped me, in both sports. Two Wheels Good!
But+1 on above. Peg time is king. Doesn't matter what or where you are riding. Go trail riding, always a hoot on a trials bike. (I have a GG300 ). Drag a log or a pipe or just a flat 2x4 into the yard, practice riding down it or across it or weave back and forth. Steering into a slippery pipe(wet root) and lifting and placing really teaches you to be precise. It will also throw you on your ass.
ATGATT: When you fall off your motorcycle, you will be wearing what you were when you got on your motorcycle. Dress accordingly.
DerViking is offline   Reply With Quote
Old 09-18-2012, 06:46 AM   #14
Sting32
Trials Evangelist
Oddometer: 1,430
Let me just say, that the video in question on TTC, is a typical exaggeration yet goal of learning your balance in a turn. When I teach new riders to our sport, we have to do 2 things, explain and demonstrate. WHen we demonstrate, it is seemingly neat and necessary to show you the extreme or "what you can do" with the information we're passing along. you will start out just trying to lean the bike somewhat, and compensating for the bikes new "balance point" by adjusting the position of your body.
Just like racing, showing you a jump, really good riders might just knack knack, mid air or a big kick/whip, but that doesnt really change how a jump needs to be taken as far as takeoff and landing.
In trials you are working without centripetal (is that the word) forces you get when riding at speeds above a jogging pace. think of the bike's footpegs and handlebars, at all times as a balance beam, a balance beam that changes the position of the middle balance point, depending on what turn dynamics are in play. you shift your weight to compensate a left turn, by loading the outside peg in a turn. I like my beginners to use this rule of thumb for flat ground turns... Whichever direction you turn, you MUST allow that arm to become STRAIGHT. The handlbar is now being held UP by your arm, the other arm bends, so that your body can distribute the weight onto the other arm a little but mostly the peg on the opposite side of the turn.
Litterally if you turn left, you lean the bike over to the left, and you left arm goes straight, and holds pressure holding the bike from falling any farther than you need it to to complete a turn. At the same time you body shifts all (or most) of the weight of your body, to the right peg. this is the balancing "act" the more you lean the bike the more weight has to compensate for the weight of the bike that is trying to pull you to the ground on the left. All of this struggle as it were, is about reaching a balance or stale mate as it were with the changing center of balance left to right.
That film on TTC, shows a really good extreme turning condition with bike demonstrated at an extreme lean, yet often useful position. IT IS something you need to be able to do, as practice. When I practice most anything, I try to make test/practice more extreme than what I hope to have to use in a section. WHY? I have always managed to have to use a skill exagerated out to extreme, time and again, to recover from maybe slipping off a hill or approach wrong.
I'll state TURNING is the most basic principle in trials. It should be so easy to you to do like the video shows, at "very soon" in your trials career. It is like dribbling is to basketball. if you cannot dribble naturally without looking like a dork, you cant do anything in basketball...
SO, just keep on working on your turns. I swear, that you should be able to accomplish the same position after an hour of practicing figure 8's. That is if you practice like I do, I do it until I can do it, before I do other things. be it in 20 minutes shifts or a full hour at a time.
For another "what it is worth" my students are required to do 20 figure 8's anytime we unload the bikes from garage or pickup... And anytime they are waiting "their turn" on a practice section or what have you. It is that important. You then take these figure 8's and visually lay them out over ALL terrain, hills ditches, and you rotate that 8 all around that stuff. when you do turns in your sleep so to speak, then you are ready (grasshopper) to be challenged more in trials...
Sting32 is offline   Reply With Quote
Old 09-18-2012, 07:01 AM   #15
darmst6829
Oddometer: 374
Originally Posted by lineaway View Post
The physics of such an exaggerated turning technique escapes me and frankly it looks unnecessary.
Dave
darmst6829 is offline   Reply With Quote
Times are GMT -7.   It's 10:46 AM.
