08-05-2012, 06:58 AM
#511 |
Wharf Rat
Oddometer: 506
Thanks Butters you are right. I am pretty good at breaking little plastic things so I wanted to be careful. One wire is completely separated, no wonder it didn't want to respond!
#512 | |
Fool - Born This Way
Oddometer: 1,245
The G650X is VERY dependent on its battery! If you review this and all related threads, you'll find that many agonizing and perplexing problems have been solved with a new, high-quality battery.
You may be an idiot if you care what I think ... http://www.flickr.com/photos/geoffster/sets/ |
08-05-2012, 09:30 AM
#513 |
Wharf Rat
Oddometer: 506
I soldered the disconnected wire and now it runs through the pre-sequence MOST of the time, not all the time. That's confidence inspiring. I'll head out and hope it lasts....
08-18-2012, 04:34 PM
#514 | |
Oddometer: 2,066
Marc 07 XChallenge 99 VFR |
08-21-2012, 07:49 PM
#515 | |
Dog Chauffeur
Oddometer: 2,665
08-21-2012, 09:31 PM
#516 | |
Survivor
Oddometer: 391
You know, it's often not changing the battery that fixes these little gremlins. For instance, mine plays up occasionally, the other night she kept stalling but what you need to do is stop the bike and then turn on the ignition. Once the lights have finished flashing open the throttle all the way and the close it again. Then turn off the ignition and turn it back on again. This resets the computer and normally fixes everything. That might be why swapping the battery fixes the gremlins, you're effectively resetting the system but the throttle trick is a built in reset you can do whenever you feel like it. |
08-22-2012, 12:06 AM
#517 |
NO NI NA
Oddometer: 97
08-22-2012, 05:22 AM
#518 | |
In my case, sometimes I forget to unscrew the throttle lock when I stop the bike. Opening the throttle as you describe simply has the effect of ensuring the throttle is in its correct position when you turn the ignition on the next time so allowing the bike to correctly set that as the idle position. Mike |
08-23-2012, 09:57 PM
#519 | |
AttitudeIsEverything
Oddometer: 1,255
Baja 2012 Ride Report ~~~ My 07 BMW G650 XCountry Thread | 03 Honda Shadow ACE 750 | 99 Honda XR400 ~~~ Kids: OSET electric | Honda CRF50FindMeSpot ~~~ Spotwalla Baja Trip ~~~ Neduro Did Dakar! |
08-23-2012, 10:04 PM
#520 | ||
Oddometer: 1,255
08-24-2012, 01:06 AM
#521 | |
Mike |
09-14-2012, 10:10 AM
#522 |
Oddometer: 20
Model: xChallenge
Year 2007 ABS: no Mileage at time of issue: 14000 Date of occurrence: 9/13/2012 Modifications (if any): Remus Exhaust, uniflow filiter, rg tail tidy Description of Failure(s): I was riding along the freeway at about 70 mph and the motor cut. After getting to the side of the road, I was able to start it again, but the second the engine was under power, it would die. Then I got it to idle for about 5 min, and it died on its own. Then after getting it started one more time, when I shook the bike around it would die the further it was leaned ot the right. Also, when leaned to the right one time the over heat light came on while trying to start the bike. The bike is new to me and never had a real problem of starting, had one time i can recall abotu amonth ago where the bike stalled on its own, and it may have been a little slow to start that evening, but that was about it. Resolution (if any): Swapped out the battery, now using a Full Spectrum Power Pulse 2 battery (A123 type) I'll let you know how it goes! Reference Thread I am asusming it is the battery, but do you have any other recomendations? maltese screwed with this post 09-16-2012 at 01:31 PM Reason: Fixed |
09-14-2012, 02:59 PM
#523 |
Wharf Rat
Oddometer: 506
Battery in top condition is a must. I was saved enormous effort on my X when I read on one of these threads that 90% of electrical gremlins can be traced back to faulty ignition switch.
The solder joints are prone to failure. They allow intermittent operation for awhile causing (me) great puzzlement. I bypassed the key switch entirely with a rocker switch and all of my previous symptoms have disappeared. Hope this helps. An inspection of the switch mechanism is worth doing IMO. |
09-19-2012, 04:05 PM
#524 |
Oddometer: 7
More battery woe's with this fine bike!
Anyone know if these (Shorai LFX14A4-BS12) help or have a bad reaction in a g650x? The Yuasa YTZ10S makes it run better but won't last if it doesn't start right up!
09-20-2012, 03:29 AM
#525 |
Winter wonderlanding
Oddometer: 356
My Shorai is a "summer battery", both of the two that I've sampled. Soon as the temps go anywhere near cold let alone freezing point, problem arise, and it seems to take forever for the battery to really wake up and start the bike. Takes like 15mins or so, and I do know the drill required. Unfortunately, cannot promote Shorai for Xchallenge.
