Old 09-17-2012, 04:45 AM   #3691
xtscruff
Oddometer: 20
3aj parts
Hi folks, can anyone help me, i am looking for a left hand headlamp rubber ring and insert for the left hand headlight, these are not available through yamaha anymore unfortunately, so i thought i would ask you good folks, there are a few other parts i am looking for but not quite yet.
Cheers
xtscruff is offline   Reply With Quote
Old 09-17-2012, 07:37 AM   #3692
webmonstro
A Aventura Continua....
webmonstro's Avatar
Oddometer: 562
Originally Posted by Dannog View Post
Hoping someone can help. I wanted to fit a tacho to my 92 XT600E.
I purchased a new tacho from ebay hoping that once I sorted the wiring and added the tacho cable from the motor everything would be OK.
Unfortunitely, the centres of the bolts holes for the bracked don't align with the triple clamp.
Does anyone know if a triple of a pre 1991 XT600 or any other model will be a direct bolt on to the headstem and forks.
I'm hoping that if I pick up a new top triple clamp and headlight bracket all will work out.
Hi
A bracket from a 1996-2003 (4PT model) vil fit as this is the XT600E "new" version sold in europe after they discontinued selling them in the US
The earlyer years might fit but the headlight is different so you might have problems there
Nuno
webmonstro is offline   Reply With Quote
Old 09-17-2012, 07:50 AM   #3693
snowjob
snowjob's Avatar
Oddometer: 593
XT675 Cylinder O-ring
Originally Posted by snowjob View Post
1. Find a thinner o-ring
2. Machine the chamfer back to size
3. Don't use an o-ring
4. Use some type of gasket sealer/maker, but what kind?
I stopped by my machinist this morning and he won't touch it...... I almost don't blame him, but a competent lathe operator could cut this groove. He suggested simple gasket maker and a google search shows that many old Britbikes employ this method instead of a base gasket.
Tonight I am gonna try to put it on my lathe and see how it looks. If there is significant risk of ruining the cylinder, I will just go for the gasket maker. Otherwise I will try to cut the groove. Sadly, my best option for holding it is a 3-jaw chuck. Would prefer a proper mandrel to support the whole length. We'll see how it goes.
Wisconsin Michigan Dual Sport Adventure Trip (link)
Picos, Pyrenees, Route Napoleon Trip (no link until I actually write it)
XT600, YZ450, 996, KX65, KLX125, JT2MX, & XS650 Street Tracker (sidecar getting prepped)
snowjob is offline   Reply With Quote
Old 09-17-2012, 10:31 AM   #3694
vudu
vudu's Avatar
Oddometer: 188
Interesting project. Always wondered about hotting up the XT. As they say there's no substitute for cubes.
I suspect the chamfer should be a tad smaller as the o-ring would be a little stretched. I'm surprised the machinist didn't point out the fact prior to commencing the work.
Yes, rubber is good for comfort and long distance, but you try stand if you have wet boots? It is very annoying...
+1
I must admit I only feel the vibes in my hands. Still liking your work Radan. Ever considered a matching (smaller) set of passenger pegs?
vudu is offline   Reply With Quote
Old 09-17-2012, 10:43 AM   #3695
bosley1980
Oddometer: 162
WOW I LIKE rpm face - it is nice colors
WHERE YOU FIND IT?
WHICH MODEL IT IS?
bosley1980 is offline   Reply With Quote
Old 09-17-2012, 11:23 PM   #3696
mr bones
Oddometer: 86
Changing my fork springs & giving them a revamp. I don't have a manual & was just wondering how much oil is in the manual for a 92 600?
I'm gonna run 10 weight probably. It's going to be well loaded so I thought heavy oil would help.
What's everybody running in there's?
mr B
mr bones is offline   Reply With Quote
Old 09-18-2012, 05:59 AM   #3697
furylow
Oddometer: 10
Quick question, I have both 17" and 18" rear wheels, which handles better? I'll use 130 80 17 or 130 80 18....
furylow is offline   Reply With Quote
Old 09-18-2012, 09:31 AM   #3698
vudu
vudu's Avatar
Oddometer: 188
18 in the rough 17 on the road.
Old 09-19-2012, 03:05 AM   #3699
Dannog
Oddometer: 6
mr B
I had my forks redone by technick in penrith and they used 15 weight oil
Dannog is offline   Reply With Quote
Old 09-19-2012, 03:16 AM   #3700
Dannog
Oddometer: 6
WHERE YOU FIND IT?
WHICH MODEL IT IS?
Found it on eBay. Seller has more. Seller is ninostechnoshop
Old 09-19-2012, 03:25 AM   #3701
mr bones
Oddometer: 86
15 weight is probably going to serve my purpose Better.
Cheers
Anybody no how much oil as per the manual per fork leg?
Old 09-19-2012, 07:02 AM   #3702
Coots
That's what she said
Coots's Avatar
Oddometer: 155
Laugh
Cheers
Checked my manual, here is your answer.
Each fork 538 cm3 (18.9 Imp oz 18.1 US oz.)
Oil level should be 6.10 from the top of the fork.
If you need a manual, check over on the hubb site in the Yamaha Tech. I am pretty sure that is where I got mine.
Good luck.
Coots Jr is just a younger me!
03 DL1000 "Bumble Bee"
91 XT600
03 SV650S SOLD
Coots is offline   Reply With Quote
Old 09-19-2012, 11:57 AM   #3703
bosley1980
Oddometer: 162
Originally Posted by dannog View Post
found it on ebay. Seller has more. Seller is ninostechnoshop
thank you very much
Old 09-19-2012, 01:47 PM   #3704
mr bones
Oddometer: 86
Good luck.
Cheers.
Old 09-20-2012, 10:40 AM   #3705
jch
jch's Avatar
Oddometer: 83
How are you going to get an RPM reading from your engine to the tach?? Is there a way to just plug this tach into some existing cable to get a reading?
jch is offline   Reply With Quote
Times are GMT -7.   It's 07:53 AM.
