09-20-2012, 05:55 AM
#5146 | |
Kool Aid poisoner
Oddometer: 4,850
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
09-20-2012, 09:03 AM
#5147 | |
Long Haul Adventurer
Oddometer: 3,182
Cheers,
Cheers, Dan |
09-20-2012, 12:55 PM
#5148 |
Oddometer: 627
09-20-2012, 01:09 PM
#5149 |
Deputy Cultural Attaché
I have a rugged mount with the same problem. The security screw will not engage, no matter how much I work it, make sure the mount is closed, etc. It just won't engage.
I bought mine from GPSCity, and emailed them to let them know of the issue. They got Garmin to send me a new rugged mount free of charge. +1 for GPSCity!
Successfully surviving motorcycling since 1976. |
09-20-2012, 01:40 PM
#5150 | |
Oddometer: 1,121
YUP its fully engaged..... Fixed it...took the mount apart. Got rid of the useless spring that pops the security screw up. Gave it just enough extra clearance to engage.
"I don't ride to be seen....I ride because I want to disappear...." Halfthrottle "The difference between genius and stupidity is -- genius has its limits." ~Albert Einstein Offcamber screwed with this post 09-20-2012 at 02:32 PM |
09-20-2012, 04:28 PM
#5151 | |
Kool Aid poisoner
Oddometer: 4,850
I do know that map detail was better, you could scale further out and still keep the high details. The detour feature is quite handy. The Routing Page was much better. Custom avoids (although I imagine there is a round about way to do the same thing with the Montana)But like I said, no way I'd trade the Montana for one.
09-20-2012, 06:56 PM
#5152 |
Oddometer: 378
I tried to take a couple pictures with my Montana last week. Every time it locked up, acted like it was taking a picture. Then nothing happened except you could get out of the camera mode no matter what. Had to hold the power button till it shut off. Repowered ok, and tried again to take a picture. Same thing happened, sure glad I brought another camera along.
Will have to try and see if there is a setting that is off or what. It worked before just fine. |
09-20-2012, 07:25 PM
#5153 | |
Oddometer: 3,182
Cheers,
Cheers, Dan |
09-20-2012, 09:04 PM
#5154 |
Oddometer: 71
I have a Tempe and the 24 hr max temp doesn't reset, not sure about the 24 hr min. Is there any way to force a reset without removing the battery from the Tempe?
81husky screwed with this post 09-20-2012 at 09:15 PM |
09-21-2012, 02:29 AM
#5155 |
Oddometer: 378
Photos
Thanks fro the idea, it only has two photos stored in it, so I am hoping there is a setting that is wrong. I tried it twice before leaving, and it worked great. That seems to be the way things go for me though.
09-21-2012, 08:20 AM
#5156 | |
Oddometer: 451
Thanks for that - that fixed it! 2 more questions - 1) Is there any way to fix the data fields so that they 1 set of data fields in the map screen whilst navigating and another set whilst just viewing the map whilst riding? 2) I've set a profile which has 2 pages of icons. For some reason, the first page shown is always the right-hand, or 2nd page of the 2 pages, and I have to arrow back to page 1 to see these icons. It's only on one profile - all the others show the 1st page first. Can I change this to show page 1 first? thanks again! |
09-21-2012, 08:26 AM
#5157 | |
Oddometer: 3,182
Cheers,
Cheers, Dan |
09-21-2012, 08:31 AM
#5158 | |
2) I believe that the "main" page of a profile is always the default shown when switching to that profile. You can create other pages by dragging the icons to the left or right edges to move them to a new page, but those won't be shown unless you scroll to them. Place your most commonly used shortcuts and applications on the main page so that you only have to scroll for items you use less often.
09-21-2012, 08:35 AM
#5159 | |
Oddometer: 3,182
Cheers,
Cheers, Dan |
09-21-2012, 08:46 AM
#5160 |
Kool Aid poisoner
Oddometer: 4,850
WTF, why did they screw up the data fields? I know with 4.20 you could have a different set of data fields between navigating and non navigating. Friggen Garmin!
