Old 09-19-2012, 08:07 PM   #46
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Originally Posted by Baja Ho View Post
Still interested in this light, but am concerned about what oncoming drivers see. Sanjoh, could you provide a night picture of the low beam from oncoming traffic?
The low beam is adjustable from off to full on, 8 steps/increments. This is a picture of the low beam on step 4 (of 8) which is what I consider an acceptable amount of low beam light to see stuff. I've never been flashed by oncoming traffic at night or during the day with this setting. Pic taken about from about 150 ft.
Same spot with high beam
Low beam from the riders perspective
High beam from riders perspective same spot as low beam pic. Tree about 300ft away from bike.
Old 09-20-2012, 06:39 AM   #47
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
KTM 08-12 Headlight Replacement
Now available on our website. More information
Old 09-20-2012, 09:16 AM   #48
teambft
teambft
teambft's Avatar
Oddometer: 1,189
Awesome.
So to clarify, per your site, that KTM mask PN is the same as the stock 2012 500 EXC mask? Or is that PN from a 2011?
Also, everything I need is $70?
And whats the wattage draw?
11 KTM 300 XC-W,10 KTM 530 XCW Six Days, 950SE just sold. Kids in college...arrrrrgh!!! "Socialism= laziness, stale thinking and zero innovation"
teambft is offline   Reply With Quote
Old 09-20-2012, 10:37 AM   #49
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Originally Posted by teambft View Post
Awesome.
It will fit your 2012 500 exc mask.
$70 gets you the mounting and electrical kit without light, choose which light you want and add that to the price.
With the Model 60, the light will pull 28 watts on full power, low beam on Step 4 (of 8) uses 3 watts.
Old 09-20-2012, 12:44 PM   #50
teambft
teambft
teambft's Avatar
Oddometer: 1,189
Thanks. I just need to space out my accessory purchases....another $170 of momma-dont-know-money
Will look at it. Nice product!!!!!
Old 09-20-2012, 01:53 PM   #51
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,044
ever consider making a kit for suzuki dual-sports?
dr650 and dz400 both use them same headlight shell
as well as the drz250.
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 09-20-2012, 02:32 PM   #52
Hondo
What if its a Samsquamch?
Hondo's Avatar
Oddometer: 9,637
I just received my kit that I am planning on adapting to my KLX450R headlight assy.
One question about LED orientation-
Should the LED's be setup in a + configuration or in 2 rows of 2, like this :: ?
KLRWorld.com Forums - Nighthawk Forums
"Life's an adventure, and I refuse to live a boring one."
Hondo is offline   Reply With Quote
Old 09-20-2012, 02:49 PM   #53
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Either configuration will work, no difference in light output or light pattern. Question is do you want a diamond or a square
Old 09-20-2012, 02:51 PM   #54
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
Momma don't know what she doesn't know
Yes, but our dualsport fairing is a much better option for more road oriented bikes.
Old 09-20-2012, 05:32 PM   #55
GordonFreeman
Gamer
GordonFreeman's Avatar
Oddometer: 1,595
I love the new headlight. Not clear on where the controls for the light brightness go - sticky on handlebar? Pic would help.
________________________
You run into ODS in the morning, you ran into ODS. You think you run into ODS all day, YOU'VE got ODS. (Paraphrasing Raylan Givens)
GordonFreeman is offline   Reply With Quote
Old 09-20-2012, 05:50 PM   #56
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
The "controls" are meant to be mounted inside the mask, near the light. These are intended to work in conjunction with your high beam switch on your handle bars. The electrics are plug n play. Here's an example on a husky, electrics are mounted to the left of the light. Once you get the low beam at a happy place, you don't need to mess with it, works just like the stock light with low beam/high beam just a small difference in output
Old 09-20-2012, 10:05 PM   #57
GordonFreeman
Gamer
Oddometer: 1,595
Thanks - all is illuminated now
Old 09-21-2012, 06:34 AM   #58
GordonFreeman
Gamer
Oddometer: 1,595
Wanted to confirm the light is ok on AC power like KTM generates for the headlight. Specifically, for the light to go full bright, you don't need DC at the switch or light, just flip the switch to high beam on the handlebar?
Old 09-21-2012, 08:59 AM   #59
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,203
The lights need DC power to operate. We are working on an AC solution
Old 09-21-2012, 03:41 PM   #60
clapped_r6
The Spoad Warrior
clapped_r6's Avatar
Oddometer: 2,699
none of us is as dumb as all of us
clapped_r6 is online now   Reply With Quote
Times are GMT -7.   It's 11:56 PM.
