Go Back   ADVrider > Bikes > Beasts > British Beasts: Triumph Tigers
Old 09-15-2012, 05:07 PM   #211
Tiger68
Oddometer: 3
Thumb 2006 Triumph Tiger Mods
My Triumph 955 I 2006 Tiger
I have owned my Black tiger for about 2 years, since this time I have ridden around Tasmania, Great ocean road Victoria Grampians Victoria, central NSW and Fare north Queensland (Australia) have done almost 20,000 kms, and numerous rides around the area where I live (which has some of the best riding in Australia) I brought the bike with only 10500 kms on the clock and now have over 30,000 kms. Overall I am happy with the bike and have only had a few problems so far which will cover latter.
Overview of 2006 Triumph Tiger
The bike from my prospective is one of the best bikes I have owned. The late 05-06 model came standard with the following
1. Heated grips
2. Panniers
3. Centre stand and
4. Some of the 1050 parts (like engine casings and smother gear and shift operation)
The Tiger
Handling: Is very good, I am no Casey Stoner but I do enjoy riding through the hills and twisty sections very much. I organise rides in the local area once per month and have done some track days. On these local rides many types of bikes show up, Cruisers, sports, sports tourers, Adventurer tourers etc.
In general I always give the sports bikes and others a run for their money, like 1098 Ducatiís, Ninjas etc. on the long straights and sweeping corners these bikes tend to have the edge on speed and high speed corningí were the Tiger gets some steering wobble around 160 kph in high speed bends ( thatís with track day only ? ) . But in the very twisty sections like 15-60 kph sections I am most of the time in front. The Tiger in these sections has the ground clearance to really lay it over, (in these situations I use a twin compound tyre harder centre softer edges for traction like the Michelin Polit road 3 front and rear), I have considered looking at fork braces etc, but what type bike is this? On the dirt the tiger is very good (with the front fork springs replaced makes a big difference to the standard front end dive) the rear is ok. Remember this is no KTM 990, and is a great bike for dirt roads and maybe some fire trails that arenít washed out or rocky (this is where I would consider two sets of rims with off road tyres on the second set). The Tiger does feel top heavy and is a high bike (I am 5 foot and 4 inches tall) those of you that have a Tiger may wonder how I touch the ground. Simple with tippy toes and have to slide of one side of seat a little at lights etc. I figure that I have had to do the same with dirt bike racing for years so why change now. Two up touring is great just set the preload to max ( 5) this on the standard rear will handle two up with panniers and back box ( packed up) the front will feel a little light , to up with no gear (4) setting.
Handling improvements
I have made to help with control ect.
1. Adjustable Brake/Clutch levers, this may not seem like a handling improvement but it does give quicker brake and clutch operation it turn better control and handling.
2. Harder progressive front springs, will stop front end dive under heavy braking and on the dirt bottoming out etc.
3. Tyres as I said Michelin Polit 3,s stick like shit to a blanket.
Engine
1. The engine is well what can I say (Bullet proof) the triple engine is so smooth through all the Rev range, itís a great bike on the open road or around town and will sit comfortably in any gear.
Servicing
1. If you can service a bike yourself ( the basics, oil, plugs, air filter oil filter chain etc) then some stuff on the Tiger is easy ( other not so much) doing an oil change is easy, ( replace with K&N filter as it has a 14 mm nut built into end off filter) Chain adjustment easy and straight forward. But doing plugs and air filter is a pain.
(To get to the plugs do the following)
1. Take of side covers
2. Take of blinkers covers connected to the front fairing
3. Take of seat
4. Take of tank
5. Disconnect fuel lines
6. Take of Air box
THEN YOU CAN GET TO THE PLUGS (EASY???)
2. Same with Air filter ( except 6 donít remove air box)
The best way to do this is replace Plugs and Air filter at same time with K&N air filter and Iridium Plugs and you will not need to do it again for 40,000 kms.
The Problems so far
1. I was riding back from a day out with mates, and it was raining very heavy. My blinkers stopped working so when I returned home I checked the Triumph Blogg site http://www.triumphrat.net/forum.( very handy) said it may be ďrelay 7Ē gone ( this is the blinker relay) as the fuses were good. I also got some electrical repellent spray cleaner, and air pressure hose pump, sprayed out the blinker connections, relay connections and fuse box connections after this all worked, the front blinker wire connections hang down past the fairing, cable tie up under fairing to avoid water getting into the electrics.
2. Did an Advanced motorcycle course with stay upright in Bradford raceway Victoria Australia, My brakes failed and I almost ran off the track (overheated the brake fluid), the brakes on the 955 are not the best for high speed braking etc. (are looking at other solutions at present but Adrianís web site (adrianmol@yahoo.com ) has what looks like a good fix, Also read another forum that did this as well and he rated it. Tiger mods#1Neils bike page.
3. Had engine Management light come on,( was not long after turned on GPS-before starting bike) The sensors on the 955,s are very sensitive and will come on if there is a sudden spick in power.( I should of started the bike first) Itís not a big problem, Get Triumph to plug in and reset. Or do it yourself by turning and starting the bike on and off three times, ( this resets the system ) ,It happened to me about 3 times I ended up putting standard plugs back in ,( after spraying out all wiring with electrical spray ) So I think the iridium plugs were the problem ; it hasnít happened since.
" A WORD OF WARNING IF THE BIKE LOSES POWER AND THE ENGINE MANGEMENT LIGHT COMES ON IT IS IN LIMP HOME MODE TAKE IT TO YOUR NEAREST TRIUMPH DEALER ASAP" but if not power loss, its more than likely an over sensitive sensor.
Items to buy to improve bike (most off eBay)
1. Adjustable levers ( if you have small hands or fingers)
2. Radiator / Oil coiler guard protectors (protect against rocks etc.)
3. Headlight protector ( name says it all)
4. K&N air filter ( smother power 100,000 km life)
5. K&N Oil filter ( has built on nut easy to remove)
6. Indium Plugs ( more power, last longer, ) MY UPSET TEMP SENSOR
7. Taller screen ( for winter or touring there are many different typesí I used a Cee Baileys only downside reduces turning circle ) there are many types
8. Engine crash bars ( I used Thunder bike, just make sure you use high temp sealant CRV, for bolts that go into crankcase, and donít over tension) I got mine through Thunderbike NZ (The best I think and you can put cruiser pegs on.)
9. Front and rear fender extenders ( can use from 94- 2001 Yamaha XJ 900 Division will fit with minor mods)
10. 19 front sprockets will lower revs by 500 rpm (better for open rd.) and
11. Non slip rear seat cover ( stops passengers from moving forward on braking)
12. X2 Leather round large pouches from eBay (with Triumph written on them) I use these to put my tool role in one side, and sockets and other stuff in other side. (The 955I does not have a lot of space under the seat.)
13. The plastic chain Guard will break after a while ( mine was 28,000 kms) so I got one from eBay Germany with TRIUMPH cut into the guard, is steel, may have to drill two other holes for bolts as there ones did not line up)
14. Front progressive fork springs ( not from eBay but IKON Suspension Australia) again there are many brands out there
15. Mine came with a Triumph sports pipe (increases RPM by about 3 HP) so I have about 108 HP, instead of the 105 HP.
16. I also put smaller blinkers on (LED and changed the Blinker relay) Looks better, I guess that an improvement.
17. Gel Seat (for front only, got off gum tree for $ 65.00 Aus.) makes long rides in the saddle more comfortable and the seat is narrower at the front which makes it easier to move around. It seems lower to the ground?
18. 7. Smaller mirrors from local bike shop, look better than standard ones, needed to replace after bike fell over (originals were too expensive)
19. 855i 1999-2000 rear shock 1 inch lower to put on 955i ( just need to put 955i spring on 855i shock -is softer)
MODS I HAVE DONE
1. I moved the rear shock adjustment from under the seat to the inside of the RIGHT passenger peg mount area (means you donít have to take the seat of every time you have a passenger or luggage ( BMW style or latter tiger)
2. Cruiser pegs fitted to the crash bars (from Thunderbike) brought from a bike swap meet for $ 5.00, I think they are Harley Pegs, had to do a bit of grinding to fit, took about 1 hour, but work well on long open roads were it gets a bit boring, can stretch the legs out, and pillion can put their feet on your pegs to do the same.
3. 4. Have put a padded beck rest on rack for wife and kids when they come for a ride, they love it, (fall asleep a lot- donít know if thatís a good thing?) will be keeping the rack for my next bike.
4. I lowered the seat by taking the rubber mounts off and a few other things (the mod is on (adrianmol@yahoo.com ) this web site has some very good ideas which I have used a few.
5. I put an 855i 1999-2000 shock on the 2006 955i and put the spring from the 955i on the 855i shock ( as the spring is softer the 855i) as I am short and it is a quite easy swap and lowers the bike 1 inch ( or more) . As I am only 5,4 tall. I also read this on a forum Girlie Adventure suspension, , I got a 885 shock of eBay for around $270.00 Aus with postage (looks like new) to do this mod do the following steps
1. Take off seat /side covers battery/ battery box
2. Take off rear wheel (will need to disconnect rear brake form swing arm etc.)
3. Take off top shock mounting bolt/ swing arm will drop
4. Take off bottom shock mounting bolt (will need to use extension bar end to hammer out bearing sleeve) make sure you donít lose any roller bearings.
5. Lift up shock through battery area.
6. Do in reserve to put the 855i shock back in. (a little harder putting back together mainly lining stuff up)
7. You will also need to drop the front forks through the triple clamps; (between 25-35mm) they will only go to about 40mm before hitting the handlebars.
THE REASON YOU NEED TO DO THIS IS THE GEOMTARY OF THE BIKE AND HANDING YOU NEED TO BRING THE FRONT DOWN TO MATCH THE REAR
8. I took the centre stand off as it will not lift the bike off the ground, (to low) properly would scrap heaps.
This is quite easy it took me about 1Ĺ hour to pull off, and put back on (looks harder than really is) this will lower the bike about 1 inch or more? , Handling seems good have only gone for one short ride, doesnít seem to be as sharp turning in
I AM GLAD TO SAY THAT I CAN PUT BOTH FEET CLOSE TO FLAT ON THE GROUND, THIS SOUND AMAZING BUT TRUE THIS GIVES REAL CONFERDENCE AROUND TOWN AND OFF-ROAD. THIS I WOULD ONLY RECOMMAND TO RIDERS 5/6 AND UNDER.
Overall
I am happy with the 955i ( All I have done has cost my about & 1500,00 AUS in parts ) and some of my time, They are a great bike with heaps of power 105 HP ( more than a BMW 1200 GS ) and handle very well. Seat high is a problem for shorter riders (like me) but the mods I spoke about can fix this. They have a great tank size 24 Lts you will get between 350-400 kms on a tank (the fuel gauge is not very accurate the low fuel light will come on between 250-300 kms. The Tiger is very comfortable on long trips but you can get an even more comfortable Gel seat as well.
I do most off my own servicing, I agree with another blog that getting to the air filter is a big job. Make sure you have a work shop manual; when you change the air filter do the plugs at the same time (kills 2 birds with the one stone)
If your 6 ft tall plus and like a bike that can go all day every day without any problems in traffic and highway or mountain and some light off road riding then a Tiger 955 i 05-06 model is for you, ( or do the shock Mod) at between 4000-9000 dollarís second hand depending on condition.
( I have been update this for about 1 1/2 yrs ) so some areas may repeat themselfs)
I know live in Cairns Queensland Australia and have ridden all the Atherton Tablelands heaps of times and also done a trip out western QLD near Chillagio and down near Townville via Valley of the lagoons.
Future Trips
Riding down to central west NSW via Cairns at Christmas (about 8000, 00 kms return)
Other trips not on Tiger
I also own a DRZ 400 E and last weekend did the crap track and bloomfield tracks are doing Cape Yoke next year , ( top of Australia next year) and are hiring a Suzuki DRZ 650 to ride In New Zealand in early December.
Well the Triumph Tiger 955I is a great bike ( if I still have it in a another year will give an update)
"IT, S ALL ABOUT THE RIDE"
Tiger68 is offline   Reply With Quote
Old 09-20-2012, 12:42 AM   #212
zoid
Dirty Old Hippie
zoid's Avatar
Oddometer: 1,251
My opinion? I love it! Almost as much as the Guzzi LeMans that I sold to buy this.
I really got lucky on this one. 2006 with only 8660 miles on it when I bought it. I am the fourth owner, but I greatly benefitted by their additions to this fine bike.
Metal Mule luggage
Palmer windscreen
Givi monokey trunk
Mustang lowered pegs
Triumph TOR exhaust
Triumph gel seat (not that great when you get right down to it)
Handlebar risers
Factory manual
Fehling crash bars
SW Motech mirror wideners
Bags Connection tank bag
Triumph center stand
And a date with Gina Bellman
I've owned it for almost 7000 miles now. It handles quite well within its limits (its not a Guzzi LeMans). It is truly all day comfortable for my banged up and arthritic knees. I can ride almost tank to tank. And with that TOR exhaust, it sings almost as well as that Italian basso profundo that I had previously been enamored with.
I haven't quite figured out why some people have complained about the headlights. They are really quite good compared to my past bikes I have owned once you get them aimed properly. Which is a real PITA!!
My only real problem so far other than a lack of vacation time to go riding, is the injection system. Three different maps so far and it still stumbles around 2500 to 3500 rpm at a steady throttle setting. Checked for air leaks and didn't find any. Looks like it is time for some custom mapping.
Also, does this chain ever wear? Over 15000 miles on the original chain, over 7000 miles on it since I bought it and I have only had to adjust it once so far. Admittedly, I almost singlehandedly support Bel-Ray's chain lube division, but still, I would have expected to have seen some appreciable wear on the chain and sprockets by now. I know- qwitcherbitchin. When it is time to replace chain and sprockets, I am using whatever Triumph used originally.
Is it a keeper?
Hell Yes!!!
Power, comfort, looks, rideability. For me, the total package.
zoid screwed with this post 09-20-2012 at 12:53 AM
zoid is offline   Reply With Quote
Old 09-20-2012, 03:26 PM   #213
Eurobykz
Say No to KawaYamaZukiHa
Eurobykz's Avatar
Oddometer: 16
brought home my lightly-used '04 girlie with a bit over 20k km.
I totally freakin' love it. Best of all, it's ORANGE - that would be tigger-colour! Which means that my other orange bike is now sulking in the corner of the garage. ('07 ktm640A for sale!!)
I'm going to lose my license (but the Mounties would have to catch me first)
gonna put on proper barkbusters first, then think about other mods...
it has metz tourance rubber - I guess I can put on anakees or scorpion-trails or TKC's, maybe will try TKC's first, although I expect the rear will be smooth pretty quick given the stupid power!.
why didn't I buy one of these things years ago?
couple questions for the inmates,
seems to have TOR can. would it have been re-mapped? how can I find out??
the crash bars look kinda different - shaped like a U (right side up) with a plate at the bottom about 15x15 cm that attaches to the bottom of the engine. Any idea the origin of this thing??
...winter is coming, better ride while I can!
Ian
Eurobykz is offline   Reply With Quote
Old 09-20-2012, 05:24 PM   #214
mustang
Lurker Extraordinaire
mustang's Avatar
Oddometer: 643
Ian
if it's a TOR pipe it will have the words "for off road use only "stamped into the body of can
The crash bars sound like they are Ma's Bars ......no longer made
mustang is offline   Reply With Quote
Old 09-22-2012, 04:00 AM   #215
bobnoxious67
Baby steps...
bobnoxious67's Avatar
Oddometer: 2,756
Originally Posted by 2tallnwide View Post
I ordered the seat from Corbin, I believe it was $400.00 shipped. The one piece seat is not adjustable like the stock seat is however. Because the seat is wider and flatter it makes the reach to the ground longer as well. I could flat foot the gel seat, but not so much with the Corbin, it is so much more comfortable to me though....
So does that mean you have a gel seat you'd like to sell?
Field and Forest Recreation Area
'00 640 ADV, '01 Girlie, '09 TE450
bobnoxious67 is offline   Reply With Quote
Old 09-22-2012, 11:57 PM   #216
zoid
Dirty Old Hippie
zoid's Avatar
Oddometer: 1,251
If that happens, are you interested in selling the stocker? I don't want to send the gel seat down the road, but I am interested in seeing if the stocker is better than what I have now.
Old 09-23-2012, 11:11 PM   #217
2tallnwide
2tallnwide's Avatar
Oddometer: 2,566
Yeah, I reckon I'd sell it, this pic was taken in June....
It'll be a while before I get home from work. Could get my wife to ship it to you if you need it in a hurry though...holler at me, and we'll work something out if you like.
If you're gonna dish it out make sure it tastes good.
http://www.youtube.com/watch?v=zBkh6lrOfT4
2tallnwide is offline   Reply With Quote
Old 11-23-2012, 04:52 PM   #218
keystiger
rat on a roll
keystiger's Avatar
Oddometer: 372
Perfect
Love my '05. Been riding 33 years, best bike ever. BUT stop telling everyone!!!! These things are one of the best "sleeper" deals in motorcycling. We need to keep it on the "down low" ya'll
I saw a subliminal advertising executive, but only for a second.
-- Steven Wright
keystiger is offline   Reply With Quote
Old 11-23-2012, 08:20 PM   #219
Drunk_Uncle
Drunk_Uncle's Avatar
Oddometer: 2,269
Hey Zoid, ride the Girlie offroad for a couple hundred miles spinning up the rear and sliding through corners will result in chain wear. Other than that I love it. I bought mine bone stock aside from a Cee Baily windshield with the Triumph lunch boxes. I have done the following.
Touratech mounts (kept the Zegas that were on my Uly)
Touratech engine guard, radiator guard, headlight guard, and sump guard(bash plate)
SW motech center stand
AME heated grips
Denali LED lights
Barkbusters
Now a question for the experts. I have been told that 05-06 955s use 1050 cases and some other 1050 parts. Sooo would a 1050 go into an 06 Tiger?
"I refuse to tiptoe through life only to arrive safely at death" '13 Tiger 800XC, '14 Street Triple, '00 KLR 650(finished project), and 2010 Honda NT700V wife's.
Drunk_Uncle is offline   Reply With Quote
Old 11-24-2012, 06:25 AM   #220
keystiger
rat on a roll
keystiger's Avatar
Oddometer: 372
Drunk Uncle that is a very very interesting question. However I have another question for you............ why?
HP gain isn't that significant on the 1050. Around 9 or 10 hp difference you can gain that with a Blue Flame muffler and Tuneboy.
Just curious, would love to see someone do it though just for the coool factor.
-- Steven Wright
Old 11-24-2012, 07:21 AM   #221
2tallnwide
2tallnwide's Avatar
Oddometer: 2,566
The 955i is plenty of motor for my use, but I would love the traction, and cruise controls of the new 1200 Explorer...
Old 11-24-2012, 10:38 AM   #222
Drunk_Uncle
Oddometer: 2,269
Keystiger, I may be in need of a motor in the next year or two. On the way back from D2D last year I made a bone head mistake, pumped some diesel. I got most of it out and it ran just fine, but now my coolant level has dropped a little bit in the overfill bottle. The ability to use a 1050 opens up more options for finding another motor. I love the bike and don't want to replace it.
I do plan on a Tiger 800XC, but as a more dirt worthy companion than a replacement.
Old 11-24-2012, 01:01 PM   #223
keystiger
rat on a roll
keystiger's Avatar
Oddometer: 372
Well, just a thought but I think the Triumph 955i Daytona, Sprint or Speed Triple motors would basically bolt right up give h.p. increases and might be easier to source/find. Is rebuilding the existing motor an option?
Probably more expensive than sourcing another motor though.
Sorry to hear of the issues you are having.
-- Steven Wright
Old 11-24-2012, 06:34 PM   #224
Drunk_Uncle
Oddometer: 2,269
Thanks. Right now she is running fine other than getting a bit warm when going slow. We'll see in the spring when I get it serviced.
Old 11-25-2012, 06:26 AM   #225
jwdub
Oddometer: 711
Drunk Uncle,
I doubt if having run a bit of diesel hurt your motor. I did the same with my 97 BMW R1100RT when the tank truck delivering a load of premium and diesel had the baffle separating the two fail. The load mixed and was used to fill the service station's premium tank. I ran it for about 10 miles out and 10 miles back to the station. It ran progressively worse until it would barely run when I got back. Siphoned the fuel out and refilled with premium at another station. I did a bit of research following the event because I had similar concerns. However, I found that diesel has lubricating qualities and, while it runs and sounds terrible, no damage should result. I continued to ride the BMW for another 45K without any issues.
jwdub is offline   Reply With Quote
Times are GMT -7.   It's 11:21 AM.
