Old 10-28-2005, 06:52 AM   #1
CaribouCases OP
Boulder CO
CaribouCases's Avatar
Location: Adventure Rider & Aftermarket Systems Manufacturer
Oddometer: 1,213
Thumb New Pelican-based Luggage System
Introducing Caribou Adventure Motorcycle Luggage Systems. The world's toughest and most waterproof motorcycle luggage, and the Original Pelican-Based Motorcycle Luggage Company. The beginning of this thread is updated regularly, so please read this part first.
Current Product Line:
Complete side luggage (pannier) systems in 25 Liter, 35 Liter, 36 Liter, and 40 Liter case sizes, both top loading and side loading available.
Complete rear top case systems in 25 Liter, 26 Liter, 34 Liter, 35 Liter, 36 Liter and 40 Liter sizes.
Side Case systems designed for Hepco Becker, SW Motech and Givi side luggage racks in 5 different case sizes.
Caribou Rear Cargo Plates.
Do It Yourself (DIY) mounting kits for side luggage and top cases.
Accessories including our Custom Case Liners, Inner Bags, Tie-Down Brackets, ROK Straps, Tool Kit Cases, SOLAS Reflective Tape Kits, Lid Organizers, Top Case Back Rest Pads, Rear LED Brake and Turn Signal Light Bars, Moto-Tote Bags and more.
Storage solutions for Scooters.
Attachment systems for Pelican cases on Vehicles, RVs, Trailers, Boats, Fighter Jets
Our luggage fits most Adventure Touring and Dual Sport bikes including BMW GS bikes, Kawasaki KLR 650 and Versys, KTM 950/990 and 1190 Adventure, Suzuki V-Strom DL650/Adventure and DL1000, Triumph Tiger 800/800XC and 1200 Explorer, Honda NC700X, Yamaha Super Tenere and many more. Our side luggage kits will fit just about any bike with Hepco Becker, SW Motech EVO and Givi Monokey side luggage racks. Our turn-key complete systems include Hepco Becker side racks, cases, mounting hardware, lid locks, lid lanyards, elastic retention straps, and optional case liners pre-installed by us. The back of the cases are pre-drilled for a no hassle solution, just bolt things together and go. Or if you prefer, order just any parts that you need to create a luggage system that fits your budget and style.
Product Details:
Caribou Luggage is based on Pelican an other military-style cases constructed of ultra high-strength polypropylene copolymer resin featuring heavy-duty watertight o-ring lid seal. They will not crack or shatter like hard plastic or deform & leak like aluminum – even in extreme temperatures. With heavy-duty hinges and latches, caribou cases are nearly indestructible and guaranteed for life. You break it, we replace it free (except shipping costs).
We integrate waterproof lid locks with our own heavy duty catch hardware for security and pry resistance, no generic off-the-shelf cheap parts here…
Dual lid lanyards keep the lid from swinging all the way down when the case is opened. Elastic straps with a center clip to hold your gear into the main cavity of the case. All standard features of our complete systems, pre-installed for your convenience….
Our Lid Lanyards have a snap button so you can disconnect them and open the lid completely for easy packing
Optional Caribou Case Liners give you the best of both worlds of top loading and side loading motorcycle luggage – when you open the case nothing falls out, you can see and access all of your gear easily, and you can leave long items strapped across the rear seat and still get the case open. These liners are made of a strong, weatherproof, mold/mildew and UV resistant material that resists creasing so it doesn’t get caught in the lid seal when you close the case. Snap buttons on the liners and case lid allow you to lay the case flat with the lid fully open. They are pre-installed when ordered as an option/accessory with a new set of Caribou side case luggage, and they are retro-fittable to existing Caribou side cases.
Optional Caribou inner bags make packing and carrying your gear a cinch. High quality ballistic nylon with 3/4 length zipper, one outer mesh pocket, one closed outer zip pocket, and handle…
Other Caribou Accessories include Tie Down Brackets, ROK Straps, SOLAS reflective tape kits, Lid Organizers, LED Brake and Turn Signal Light Bars and more...
The cases remain totally waterproof after all of our modifications, tested to the extreme submerged in an ice-cold mountain creek for 30 minutes and not a drop inside…
All cases have heavy duty handles with rubber padding. Waterproof air valve automatically equalizes pressure as you change altitudes.
The Caribou latch has a key lock for security that is matched to the lid lock key. A 180 degree turn of the wing knob creates a dual action that holds the case completely tight to the luggage rack. No movement or rattles of any kind, and unlike “puck” or spring-pin fastening devices, the Caribou latch is adjustable to account for normal wear and keep cases tight over many years and many thousands of miles. Turn the wing knob and lift the case off, it is that easy. All heavy gage steel, no flimsy plastic parts holding the case to the bike.
Hepco Becker side rack and Caribou quick attach/release latch...
Understand that if you crash hard, these cases are not going to break, they are simply too tough. The force instead is transferred to the luggage rack and the bike’s sub-frame. Therefore, we designed the latch to break-away upon high impact and be field replaceable. Better to break an easily replaceable $25 part than the expensive luggage rack or even more expensive sub-frame of the bike. No other luggage system offers this feature. This is critical when using super tough Pelican Storm and SKB cases…
Today our complete side case systems come with German-made Hepco Becker racks, they are the best designed and strongest racks you will find. Most of the HB racks are the "Lock-It" type that are easily removed in a few minutes leaving behind small, discreet attachment plates.
Caribou luggage is designed to allow plenty of room for the passenger’s foot and leg for comfortable 2-up riding …
All Caribou side luggage systems are designed to hug the bike’s frame for a narrow width, about 38” side-to-side across the cases (give or take an inch depending on bike). Note that our 36L top loading cases add 4" to that overall width…
Caribou 25L, 35L and 40L Top Case systems feature an external latch system. The 34L top case utilizes an internal QFS™ quick attach/release. All systems include an integrated waterproof case lid lock, bike-specific mount hardware and a rigid aircraft grade aluminum cargo plate.
External latch system...
Internal Latch System for the 34L case only...
Our 34L Rear Top Case holds a full size helmet with room to spare for a mesh jacket...
You have lots of options because we make side luggage panniers designed to fit Hepco Becker, SW Motech EVO, and Givi Monokey side luggage racks. All of our case and mounting systems have the same industry leading features: rugged design with steel parts, quick attach/release, lockable, field replaceable break-away latch. This offers a significant luggage upgrade that is very affordable, especially if you already have one of these racks. Our side luggage case mount system is also available separately as a DIY kit..
Caribou Side Case Pannier Mount Hardware for Givi Monokey and SW Motech EVO Racks...
Caribou 35L (Pelican 1550) side luggage on Givi racks and the Versys...
Caribou Side Case Pannier Mount Hardware for Hepco Becker Racks...
Our 36L Top loaders with Hepco Becker side racks...
We don’t just cobble together off-the-shelf parts or attempt to cheaply copy other manufacturer's designs. Caribou Luggage is professionally engineered, tested and manufactured for reliability, quality and safety and is proudly made here in the USA...
Caribou luggage has been tested tough over hundreds of thousands of miles by riders all over the world including our own real-world product testing in Colorado and the brutal back roads of Baja Mexico. When it comes to protecting your gear and your safety, stick with the Pelican Case luggage professionals – Caribou Luggage Systems…
Please visit our web site at www.cariboucases.com for more information and to order. You may call us at 303-786-8947 from 8:00am-5:00pm Monday thru Saturday Mountain Time. Also check out our You Tube video and the Caribou Lugggae FAQ
Thank you!
Roger Pioszak/President
Roger Pioszak, Caribou Luggage Systems.
Please see our Pelican-Based Luggage Thread in the Vendor Forum .
Made in Boulder, Colorado USA
PH: 303-786-8947 Mon-Sat 8:00am-5:00pm Mountain Time Zone
CaribouCases screwed with this post 12-02-2014 at 03:09 PM Reason: Clarifications, add photos
CaribouCases is offline   Reply With Quote
Times are GMT -7.   It's 01:38 AM.
