Old 09-19-2012, 12:14 PM   #541
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,888
Originally Posted by oPAULo View Post
Post up a pic of your axle. Is it hollow?
Or go ask Bracket over here. He's left all us little people behind.
http://advrider.com/forums/showthread.php?t=742318
Axle is hollow but has two huge aluminum nuts. The nuts could probably be drilled out but I don't want to weaken them.
'06 KTM 950S Adventure
'12 Ram 2500, Cummins, 6-speed auto, Laramie Longhorn, RamBox.
DakarNick is offline   Reply With Quote
Old 09-19-2012, 04:42 PM   #542
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
Didn't do much today. Got the bolt size for through the axle and got a bushing figured out so the trailer won't pull where the threads of the bolt are.
oPAULo is offline   Reply With Quote
Old 09-19-2012, 04:43 PM   #543
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
Does it have axle blocks? I saw some extended axle blocks somewhere.
Old 09-19-2012, 06:44 PM   #544
ben2go
Moto Flunky
ben2go's Avatar
Oddometer: 3,616
Trailer turned out better than I imagined.
I resemble that remark except mine are brass.
Originally Posted by bassogap View Post
If my aunt had nuts, she'd be my uncle. What's your point?
Manic Cycles=My Blog
ben2go is offline   Reply With Quote
Old 09-20-2012, 06:20 AM   #545
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,888
Yes, it does have blocks. Sorry, I've been thinking about the front wheel so much I told you it has two nuts!
The rear actually has one nut. One side has the axle connected to the axle block. The other goes through the block to the nut. I'll look at it more tonight and try to figure something out.
Old 09-20-2012, 03:40 PM   #546
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
Nothing new. Put a few more miles on it. Might take it apart for paint this weekend.
Old 09-20-2012, 06:25 PM   #547
Eddieb
Eddieb's Avatar
Oddometer: 994
Keen to see some close up pics of how you did the mountings on the axle.
'05 DR650 - '06 Wee Strom - '86 BMW R80 with Velorex sidecar - '67 Ducati 250 Mark 3 Narrow Case
www.AdventureRidingNZ.co.nz Free GPS tracks for New Zealand, over 60 Owners and workshop manual downloads, ADV bike specs chart & more
Eddieb is offline   Reply With Quote
Old 09-20-2012, 08:42 PM   #548
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,888
I got it! I didn't look very thoroughly to begin with, so I looked more tonight. The 950 swingarm has a threaded "standoff" parallel to the axle on the bottom of the arm. One on each side. Beefy enough to hold a trailer I'm hoping! Thread is 10mm.
Pic tomorrow.
Old 09-22-2012, 06:18 PM   #549
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
Got the new 7/16 X 12 bolt and got the skewer figured out.
Here it is assembled. The carabiner locks it from coming apart. The bushing at the right end is a slip fit inside the axle and over the threaded end to protect the threads of the skewer.
There is a rod welded to the nut and captured by the pins to keep it from turning.
Here you can see the bushing has a flange on it to keep it at the threaded end. The trailer pulls on this instead of the threads. This is why I couldn't just weld the nut to the trailer.
Then the wife and I tested it some more. Gravel, some trail and interstate. It's still awesome!!
Old 09-22-2012, 07:50 PM   #550
Mr. Fisherman
PROUD 2B Riff Raff!
Mr. Fisherman's Avatar
Oddometer: 10,776
Great problem solving ideas... loving it.
Mr. Fisherman is offline   Reply With Quote
Old 09-22-2012, 08:00 PM   #551
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,888
Looks great, Paul! Here is my progress so far. Like I said a few posts ago, I "found" two 10mm x 1.50 threaded "lugs" cast into the bottom of the swingarm.
Like so...
I then drew up the mounting plates. The plates will be bolted to the swingarm with two 45mm long bolts through a spacer and two PTFE-impregnated bronze flange bushings. I'll show that when I get them. Everything except the yellow cardboard mockup is on paper.
The parts in yellow will pivot in the vertical direction. The yellow "spacer" at the back will be where the horizontal "axle" will be. Somewhat like a bicycle head tube. That's on paper, too. But one thing at a time.
Everything will be steel for now. For a few reasons. One, I have some 1" tube and 1/2" tube already in the garage. Two, I can weld steel with my mig welder but have no experience with a Tig so... I'll work with what I have for the time being. I've spent $22 on bushings. I hope to build the trailer for less than $100. Most of the cost will be in a tire and shock.
More pics as I progress.
DakarNick screwed with this post 09-23-2012 at 08:21 AM
Old 09-23-2012, 07:02 AM   #552
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
AWESOME!
That lug cast into the swingarm looks a little small and weak but maybe it's bigger in person.
Isn't your axle hollow? You could get a locking nut to fit with a hole through it.
Old 09-23-2012, 08:18 AM   #553
DakarNick
Swabee
DakarNick's Avatar
Oddometer: 6,888
AWESOME!
Yeah, it's 10mm. Little smaller than I'd like. I may look for another way to do it.
The axle is hollow but only nutted on one side. The chain side is held in position with the chain tensioner.
Old 09-23-2012, 08:42 AM   #554
duanew1
In my Pajama pants
duanew1's Avatar
Oddometer: 760
Mr Bracket has some solutions on this page.
http://www.moto-mule.com/hitching.html
Bikes I own
2008 Yamaha WR250R
1992 Yamaha XT225
2008 SYM HD200
duanew1 is offline   Reply With Quote
Old 09-23-2012, 08:51 AM   #555
oPAULo
jack of all terrain
oPAULo's Avatar
Oddometer: 4,061
Originally Posted by lousot View Post
why not drill out the nut
That's a $398.36 KTM nut!! You don't drill those....
Times are GMT -7.   It's 10:56 PM.
