09-23-2012, 03:26 PM
#5236 | |
Oddometer: 194
I just turned it on, loaded a route, and looked at the dashboard. No speed field. It never occurred to me to try demo mode. In fact, I'm not even sure how to, although I'm sure it's buried somewhere in these 350 pages....![]() I just hate it when my toys outsmart me!!! |
09-23-2012, 04:46 PM
#5237 | |
Procrastinators
Oddometer: 5,787
Want to know more about the Garmin Montana? See the Wisdom and FAQ Thread. "Don't play a lute to a cow" (Old Chinese Idiom) "The motorcycle, being poorly designed for both flight and marine operation, sustained significant external and internal damage," police noted. |
09-23-2012, 04:50 PM
#5238 |
Procrastinators
Oddometer: 5,787
Probably, but when I have my gps in demo mode, and load a route, I usually click "Go" then "Yes" to "Do you want to simulate driving this route..." to see what choices the gps will make.
09-23-2012, 05:13 PM
#5239 |
Hooked Up and Hard Over
Oddometer: 7,444
Emmbeedee,
to you since you know this unit quite well and to the point, can i build large complicated routes that contain some unmapped sections that require switching to direct routing then back to auto routing once back on mapped roads all in the same continous route in Mapsouce then upload it to a Montana and will it run it as is like my 276c chartplotter will with no fuss? thanks my friend, frank Sent from my SCH-I800 using Tapatalk 2
Frank Reinbold "Every bike I ever had, was the best bike I ever had, when I had it" *2010 FOREVER WEST* NEW ENGLAND AND CANADA OFFROAD F800GS 14 DAY IDAHO ADVENTURE KTM 950 TRANS AM TRAIL WEST TRANS AM TRAIL VID CLIP THE DEAN OF WESTERN ADVENTURE ROUTES |
09-23-2012, 05:15 PM
#5240 | |
Procrastinators
Oddometer: 5,787
![]() I usually follow tracks since they're more reliable for my purposes. Hopefully someone here will have the answers for you.
09-23-2012, 05:25 PM
#5241 |
Oddometer: 7,444
ok thanks anyway,
anyone else? Sent from my SCH-I800 using Tapatalk 2
#5242 | |
Procrastinators
Oddometer: 5,787
![]() I would probably break down the kind of route you're suggesting into segments, and use waypoints to help in the direct routing. That way you wouldn't need to try to get the route to work in both direct and auto-routing modes.
09-23-2012, 05:33 PM
#5243 |
Oddometer: 539
Segments with waypoints. Pretty sure that is the method doc rock uses with the Montana.
DP. You considering the switch to Montana? Sent from my iPhone using Tapatalk
'12 Yamaha Super Ténéré (Blue) '08 WR250R I refuse to tiptoe through life only to arrive safely at death THE DEAN OF WESTERN ADVENTURE ROUTES Backcountry Byways Journal |
09-23-2012, 05:39 PM
#5244 |
Oddometer: 7,444
rupee. im always searching for the next big thing. lol
so far nothing can replace our *76 units as far as i can tell in regard to the way we use them. now go get your feet massaged. lol Sent from my SCH-I800 using Tapatalk 2
09-23-2012, 06:42 PM
#5245 |
Khan!
Oddometer: 988
I have significantly used every Zumo from the beginning, minus the 220. Having the Montana for 3 days and a tank full of gas including offroad, I can easily say the Montana is the way to ride. Many of the Zumo limitations gone. Just to mention a few, real sunlight visibility, multiple maps and customizable... nice. Although not perfect, it does get close and the gripes are minimal.
Thanks for the push in the right direction.
КМЗ Dnepr MT11 // КМЗ M72 // ИЖ Planeta 5 // КМЗ MV750 // BMW R1200GS 30th
09-23-2012, 06:59 PM
#5246 |
earthbound misfit, I
Oddometer: 6,593
Is map instability, rotating though different orientations, on my 600 while riding a map speed issue? I've tried different map speed settings, using garmin topo, and prefer north up vs track up.
http://www.youtube.com/watch?v=PZKIh5aCYCI |
09-23-2012, 07:02 PM
#5247 |
Deputy Cultural Attaché
Quite a few of us have had the orientation swap issue, particularly when the unit is near level when mounted. Easily solved by locking orientation in the settings.
Successfully surviving motorcycling since 1976. |
09-23-2012, 07:09 PM
#5248 | |
Pretty Dogged
Oddometer: 442
In testing I found the only way to get it to work was to load it in smaller (day ride length) routes with start and finish waypoints and a couple of extras waypoints inbetween. I finally went back and converted the entire route to a track and loaded my important waypoints so I could route directly to the waypoints if I decided to go off-track and then wanted to get to the next important waypoint. I do not think it was a space limitation as I have 1/3 of my hard drive as free space......I just think that a very large route has too much data for the Montana to load and run efficiently. The brain can only handle so much. J
2007 BMW Dakar & 2009 Ducati Multistrada entering the middle of the in-land sea called Saskatchewan Canada http://s737.photobucket.com/home/OceanMtnSea |
09-23-2012, 07:36 PM
#5249 | |
Kool Aid poisoner
Oddometer: 4,823
Good. Bad. I'm the guy with the gun. Guess what doofus, nobody reads your lame blog. |
09-23-2012, 10:05 PM
#5250 | |
Long Haul Adventurer
Oddometer: 3,173
Strait answer to your question is, yes, you can have a mixed (on/off-mapped road) routes and send it to the Montana but you'll have to have the exact same map set on the Montana as MapSource or BaseCamp did when you created the route (and yes, you can make mixed-routes in BaseCamp). Just have to remember to set Recalculation to OFF when you navigate your mixed-route. Example of Mixed-Route created in BaseCamp on 24K US North Central Topo: ![]() ![]() Cheers,
Cheers, Dan |
