Thread Tools Search this Thread Rating: Thread Rating: 431 votes, 4.94 average. Display Modes
Old 09-24-2012, 01:09 AM   #5236
tvan
Oddometer: 133
Montana shuts down
G'day Everyone,
Hope I can explain this right, Montana when I have a route up and go into the icon that shows a square with 5 lines (little box) the one you use to make changes, the system completely shuts down. Hoping that one of you gurus may bring some light as to why this happens and how I can fix this. Only happens with the routing.
T-Van
1200GSA
tvan is offline   Reply With Quote
Old 09-24-2012, 01:16 AM   #5237
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,812
Originally Posted by DRTBYK View Post
Wow, we seem to be all over the place on this topic.
Strait answer to your question is, yes, you can have a mixed (on/off-mapped road) routes and send it to the Montana but you'll have to have the exact same map set on the Montana as MapSource or BaseCamp did when you created the route (and yes, you can make mixed-routes in BaseCamp). Just have to remember to set Recalculation to OFF when you navigate your mixed-route.
Example of Mixed-Route created in BaseCamp on 24K US North Central Topo:
Cheers,
Base camp for windows ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is online now   Reply With Quote
Old 09-24-2012, 04:23 AM   #5238
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Have you tried it in BC 4.0.1? I can't get it to do mixed routing in either the Mac or Windows versions.
Cheers,
Old 09-24-2012, 05:47 AM   #5239
Jon_PDX
Oddometer: 1,107
New computer, Basecamp, and Montana
I had something strange happen the other day when I connected the Montana to my new MacBook Air.
All I had was basecamp installed at the time. When I plugged the Montana in Basecamp only showed the base map that comes on the Montana. Not the CN NA maps that I have installed on the Montana.
I thought for sure that basecamp would read all the maps on the montana and let me choose from them.
Am I mistaken?
I thought for sure the first time I connected it to one of my other computers all the maps showed in the list but to be honest it's been so long that I could be wrong.
Of course once I loaded CN NA 2012.40 then I could choose it from the list.
Jon...
Bikeless at this time
Past Bikes.....Check with my Wife.....I've lost count :-)
Jon_PDX is offline   Reply With Quote
Old 09-24-2012, 06:00 AM   #5240
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
Am I mistaken?
Jon...
You probably need to run Javawa Device Manager on that gps/map to enable its visibility in BaseCamp.
http://www.javawa.nl/jdm_en.html
Old 09-24-2012, 06:01 AM   #5241
Albie
Kool Aid poisoner
Albie's Avatar
Oddometer: 9,815
Am I mistaken?
Jon...
This tool will help you see all the maps loaded on your GPS:
Old 09-24-2012, 06:19 AM   #5242
Jon_PDX
Oddometer: 1,107
Thanks guys.
Yeah it's all good now that I loaded the maps on my computer and unlocked them.
I was just surprised that they did not show up in Basecamp with the Montana connected to the computer before loading the maps on the computer.
Regarding the software you both pointed me to. I've seen you mention it a few times now so I guess I should check it out.
Jon...
Old 09-24-2012, 06:52 AM   #5243
Emmbeedee
Procrastinators
Emmbeedee's Avatar
Oddometer: 9,842
If you run Javawa on the map you'll be able to connect to any computer with BaseCamp and see the maps, not just computers where you've installed the maps. Definitely worth doing.
Old 09-24-2012, 06:59 AM   #5244
OceanMtnSea
Pretty Dogged
OceanMtnSea's Avatar
Location: left middle Saskatchewan & entering middle BC
Oddometer: 605
There are a few limits when it comes to Along-road Routing. As mentioned there is a 50 Via Point limit. There is also a distance limit which I think (haven't tested lately) is 1000 miles. If one does judicious placement of Via Points AFTER intersections they seem to not get announced and you still get the intersection shown in the Navigation Info list. I have to believe you can make a rather complex along-road route (maybe not walking) with 50 via points.
One trick I used when I had zumo's was to use waypoints for information and not route path shaping. This enabled me to have lots of Waypoints associated with the route. I used Proximity Alerts so that I would get prompts on the zumo.
Cheers,
You are likely right DRTBYK.......only I have become so comfortable with the ease of track use that I really only use routes in a pinch to get somewhere quick without spending a bunch of time figuring out an exact track.
2007 BMW Dakar & 2009 Ducati Multistrada leaving the middle of the in-land sea called Saskatchewan for the Mountain Valleys of BC, Canada
http://s737.photobucket.com/user/Oce...?sort=3&page=0
OceanMtnSea is offline   Reply With Quote
Old 09-24-2012, 07:33 AM   #5245
levain
STILL Jim Williams
levain's Avatar
Oddometer: 7,463
Thanks guys.
Jon...
I'll be doing the same on a macbook air soon. Did you use an external dvd drive, or is there another way?
2015 KTM 690 Enduro R, 2008 Yamaha WR250R, 1971 Lambretta DL
levain is offline   Reply With Quote
Old 09-24-2012, 08:30 AM   #5246
DRTBYK
Long Haul Adventurer
DRTBYK's Avatar
Oddometer: 5,984
I am also a BIG proponent of using Tracks; especially with Waypoints along the path - and proximity alerts. But, I have to know what Routes do because my clients will surely want to use them.
Cheers,
Cheers,
Dan
All Things GPS
Reviews at www.GlobeRiders.com
DRTBYK is offline   Reply With Quote
Old 09-24-2012, 08:39 AM   #5247
DRTBYK
DRTBYK's Avatar
Oddometer: 5,984
The route you were looking at in my post was created 5min before I posted it... so, yes to either: Windows or Mac BC v4.0.1.
The trick is to switch between a routable and non-routable map when you want to go "off-road". On Mac BC you can do it another way using the Routing Properties window to switch between Along-road and Direct Routing Activities and then use the cmd-z when BC wants to recalculate. But, the map switching is easier and less confusing.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-24-2012, 08:44 AM   #5248
DRTBYK
DRTBYK's Avatar
Oddometer: 5,984
Originally Posted by tvan View Post
G'day Everyone,
Sounds like you need to update your firmware to v4.60. By the way the "little box" is the Options button.
Cheers,
Cheers,
Dan
All Things GPS
Old 09-24-2012, 09:02 AM   #5249
BruceWA
Oddometer: 575
Slight change of topic here.......but on my recent trip of a week ago I noticed on about 3-4 occasions that my 650t lost satellite reception, all but one of those occasions when there were NO obstructions, mountains or trees. Once in Idaho on US Hwy 2 just north of Silverwood for about 5 miles. Any ideas? My 276c used to loose satellite reception often and appears to be more sensitive to this.
Thanks.
Figures don't lie, but liars can figure
BruceWA is offline   Reply With Quote
Old 09-24-2012, 09:13 AM   #5250
DRTBYK
DRTBYK's Avatar
Oddometer: 5,984
Thanks.
Hey Bruce,
I was just over that way last week - didn't notice any Black Hole activity. Kidding aside, it's hard to say why your GPS lost signal unless it is repeatable. Five miles is quite a ways to not have signal though. Any other issues?
Cheers,
Cheers,
Dan
All Things GPS
Times are GMT -7.   It's 11:26 PM.
