Go Back   ADVrider > Riding > Face plant
Old 09-24-2012, 02:39 AM   #271
WayneC1
Oddometer: 2,632
Advrider E365 has purchased the machine, his post is in the check your forks thread, the title docs will probably provide some leads but I am not familiar with how the US title documents work really
Perhaps it would be worthwhile asking the seller who he bought it from as it sounds like it was not from an insurance co
WayneC1 is offline   Reply With Quote
Old 09-24-2012, 10:23 AM   #272
SilkMoneyLove
SilkMoneyLove's Avatar
Oddometer: 2,305
GS Fork question
So, is the theory that the rider brakes hard and the force of the braking on the left fork causes some twisting and too much force for the right side fork and it splits/cracks, eventually failing?
Why else would the right side be more prone to failure?
Either way, crashing sucks donkey balls.
SilkMoneyLove is offline   Reply With Quote
Old 04-23-2014, 09:27 PM   #273
Romet
Oddometer: 8
Thanks for posting this. I was just about the buy the same year and model.
Romet is offline   Reply With Quote
Old 05-03-2014, 10:05 AM   #274
PT Rider
Oddometer: 706
The theory is that BMW designed the parts too weak. BMW later improved the parts but retained the same part numbers. This part number game is exactly what GM is being castigated for regarding the defective ignition switches in the cars that caused fatal crashes.
http://www.advrider.com/forums/showp...6&postcount=92
It's not what you look at that matters, it's what you see.
Henry David Thoreau
PT Rider is offline   Reply With Quote
Old 05-05-2014, 04:01 PM   #275
jfman
jfman's Avatar
Oddometer: 1,509
Reminds me of...
jfman is offline   Reply With Quote
Old 05-05-2014, 08:30 PM   #276
SilkMoneyLove
Oddometer: 2,305
Originally Posted by jfman View Post
Reminds me of...
Just needs a little JB Weld and some zip ties :-)
Old 05-06-2014, 12:22 AM   #277
WayneC1
Oddometer: 2,632
PT Rider, the manner and timing of the ending of the NHTSA preliminary enquiry into the GS axle lug breakages was so strange it smelt of brown paper bags
Considering what is happening with GM it would be worthwhile US people raising questions over NHTSA handling of the GS failures at political levels
650GS Info - www.f650gs.crossroadz.com.au
Old 07-21-2014, 09:04 PM   #278
smokin998
Rides Water Buffalo
Oddometer: 39
In case anyone is still following this link....the NHTSA report.
http://www-odi.nhtsa.dot.gov/cars/pr...h&summary=true
Jamie
smokin998 is offline   Reply With Quote
Old 07-22-2014, 01:25 AM   #279
WayneC1
Oddometer: 2,632
As for NHTSA, if you want a laugh I have copies of the pdf's on my web site and received a take down notice from ISO Stds body, it turns out one of the docs is simply the ISO STD for corrosion. I took that one down and told ISO to take to NHTSA as NHTSA is required to put up the submissions
Old 07-22-2014, 01:14 PM   #280
atomicalex
silly aluminum boxes
atomicalex's Avatar
Oddometer: 2,991
Do I need to wade in here? I've worked on some recalls and assorted automotive failures that got to recall status.
I've been poking around again, all signs point to the fact that no one can ID a solid, real cause for the failures, so there is legally nothing to recall. BMW responded properly, and NHTSA left open the avenue that the defect is undefined, which gives owners specific legal rights. If the defect was defined and a recall issued, all hell would break loose with people having to give up bikes until a solution was found and then the issue of replacements and so on.
Do I want to find out what the cause is? Yes. Actually, based on the failures I've seen pics of, it's what's known as a cold casting defect and is wickedly hard to track down. It only occurs on the startup of the casting line under certain conditions. Typically great care is taken to avoid having those parts get into the food chain, but if the vendor was not careful, it is possible a few could. So BMW redesigned and NHTSA closed.
Without more failures that look alike, it will not be possible for NHTSA to recall. Or for that matter, for BMW to completely and without question eliminate the defect.
Katherine, in words - F650GSa - CBR250R (sold) - Super Sherpa - Nine Days in the Alps - More Alps: Finding GS Land
atomicalex is offline   Reply With Quote
Old 09-20-2014, 08:42 PM   #281
WayneC1
Oddometer: 2,632
Here is another failure from EBay Germany
http://www.ebay.de/itm/191339186080?redirect=mobile
Old 09-20-2014, 09:07 PM   #282
PT Rider
Oddometer: 706
BMW F650 GS accident damaged
For sale is a BMW F650GS , the result of an accident ( slipped into the ditch ) no longer roadworthy . But the engine and transmission are still undamaged and fully functional. Other parts such as rear swingarm , rear tires ( Michelin ) with rim , etc. are also in Ordung ( both tires 2014 new, approx 80 % ) , see photos . Sprocket , pinion , chain I renewed last year . Technically very well maintained and was flawless. The front fork is not for use . It was upgraded a fork bridge on which the additional protective sheet was attached to the front wheel . I am the second owner . Year of construction : 2000 Mileage : 23000 km
(Thank you Google Translate)
Henry David Thoreau
Old 09-20-2014, 09:59 PM   #283
jfman
jfman's Avatar
Oddometer: 1,509
So BMW is waiting for someone to die before they recall?
Old 11-29-2014, 05:17 PM   #284
patrkbukly
52 Weeks of warm
patrkbukly's Avatar
Oddometer: 1,243
W t f
Are you kidding me...WTF. That fork had to have sustained some damage from something extreme.
You only live once, but if you do it right, once is enough.
Mae West
patrkbukly is offline   Reply With Quote
Old 11-29-2014, 05:57 PM   #285
PT Rider
Oddometer: 706
A properly designed and manufactured fork tube would had to have sustained some damage from something extreme.
If it was properly designed and manufactured in the first place, why would BMW change the design...while retaining the same part number?
Henry David Thoreau
Times are GMT -7.   It's 01:27 AM.
