09-25-2012, 01:09 PM
#1 |
Space Available
Oddometer: 278
MSR Tire Chaning Stand...anyone use one?
I get the concept, reviews on it seems ok.
Anyone use it here? Will help make it a little more comfortable spooning both street and dirt tires on/off? I don't see how it would make it any easier. Here is what it looks like: http://www.jakewilson.com/p/56/88/34...Changing-Stand Also, does it breakdown and pack small?
2005 Suzuki Hayabusa 2008 BMW GS Adv |
09-26-2012, 02:35 AM
#2 |
Buffoon
Oddometer: 8,021
I have the stand. its ok. gets pretty wobbly as the legs are weak and being two piece there is room for play.
I had tried like hell to buy a Mikes Racing stand - apparently the originator of the design. he wasnt answering emails or calls, and a lot of web reading showed others had the same experience. however a friend did get one from mikes racing this spring. it costs another $60 or so but if you can get one, it is way better than the msr/moose stands.
It's important to own a great adventure bike, and leave it in the garage because there's no time to adventure ![]() |
09-26-2012, 05:50 PM
#3 |
Wrench Rider
Oddometer: 712
If it might help, an Iron Butt rider friend who would go thru 10+ tires a year
made his own; simple, cheap. A 30 gallon barrel w/one end cut out and covered with heavy heater hose. Then a pipe installed thru the drum about a foot from the top to provide an anchor point to hold the wheel in place. The drum was full of rocks to keep it stable. A decent bead-breaker and a few good tire irons and you are in business. |
09-26-2012, 07:47 PM
#4 |
Oddometer: 977
I use three milk crates stacked up.
Roads? Where we're going we don't need roads. -Doc Brown |
09-26-2012, 07:56 PM
#5 | |
Oddometer: 2,534
looks like a bunch of top racers all use this stand http://www.mikesracingproducts.com/mrp_web_site_002.htm
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
09-26-2012, 08:52 PM
#6 |
Oddometer: 460
I have not used that one but did make my own and having the wheel clamped down and at waist level makes tire changing waaay easier for me...FWIW mine is fairly small and light, clamps in a vice and was easy to make, posted some photos awhile back at http://advrider.com/forums/showthread.php?t=822721
09-26-2012, 10:05 PM
#7 | |
Oddometer: 2,534
09-27-2012, 02:50 AM
#8 | |
Buffoon
Oddometer: 8,021
09-27-2012, 07:20 AM
#9 | |
Space Available
Oddometer: 278
Hope it works out and I don't have to kill my back changing tires....some days, it can be a real chore, especially a set of rear 17/190 street tires. I gotta be in the mood to change tires when working off my present system (harbor frieght bead-breaker, spoons and the floor with some 2x4).
09-27-2012, 06:58 PM
#10 |
Boring Old Fart
Oddometer: 814
I'm using the Moose Racing version with a No-Scuff bar from Dave Anderson. Since the picture was taken I've mounted the stand to a 2' x 2' piece of 1/2" plywood and replaced the cheesy 1/2 x 13 tpi center rod with a piece of 5/8" Acme threaded rod. I bolt the plywood base to the garage floor with a couple of 3/8" anchor bolts when I'm changing tubeless tires with the No-scuff bar, but that's not necessary with tube tires and tire spoons. It paid for itself pretty quickly.
"I don't want a nickel... I just wanna' ride my motor-sickle." Arlo Guthrie |
09-27-2012, 07:01 PM
#11 |
Oddometer: 192
stand
make a mount for your reciever hitch on your truck. portable and sturdy....................steve
roundstock |
09-30-2012, 11:22 PM
#12 | |
Buffoon
Oddometer: 8,021
![]() I think if I ever get a flat offroad I will walk out not a bad idea, but I never disconnect the trailer. one could also cement a piece of 2" square tubing in the floor for the same result
10-07-2012, 05:05 PM
#13 |
cultural illiterate
Oddometer: 6,401
Here is my version.
14" rim Old patio table base
. I wonder where that road goes? |
