Old 09-25-2012, 04:40 PM   #31
rpmwfo
Oddometer: 134
Sent a PM. I'll take a set.
2007 XR650R Plated/2004 KX500 Plated/2007 KTM 450 EXC with 540 kit/2012 R6/2013 KTM RC8R
rpmwfo is offline   Reply With Quote
Old 09-25-2012, 04:46 PM   #32
Renazco
Formerly AKA Boejangles
Renazco's Avatar
Oddometer: 4,742
Make that two sets, love the work you guys are doing!
Seats www.renazco.com
Parts & Accesories www.renazcoracing.com
Renazco is offline   Reply With Quote
Old 09-26-2012, 01:48 AM   #33
LukasM
Oddometer: 5,425
Great stuff Jesse! Wish I had your Solidworks modeling skills.
Old 09-26-2012, 06:14 AM   #34
babuja
babuja's Avatar
Oddometer: 353
Im interested 2 (looking for this mod for some time), depending on price of course.
At this moment i'm using adapted CRF triple clamp and cant find a way to apply scoot damper ot other damper.
Cheers guys
Babuja
________
KTM 950 ADV
www.babuja.smugmug.com
http://www.nomadstrail.net/site/
babuja screwed with this post 09-26-2012 at 06:43 AM
babuja is offline   Reply With Quote
Old 09-26-2012, 11:04 AM   #35
jesusgatos OP
fishing with dynamite
jesusgatos's Avatar
Oddometer: 2,393
I was using stock CRF tripleclamps on my 650R for a while too, and I ended up using a Scotts low-mount setup. Worked alright, but affected light/fairing options. With those tripleclamps, you're pretty much limited to using a dipstick-mounted stabilizer post (sucks). Or you could get a CR500 upper tripleclamp and use that with a forward-mounted frame clamp, but it will still limit the steering a bit. Not trying to talk you out of anything, and we'd love to sell you a set of tripleclamps, just sharing info so you can make an informed decision.
jesusgatos is offline   Reply With Quote
Old 09-26-2012, 01:13 PM   #36
babuja
babuja's Avatar
Oddometer: 353
This is near the solution you're talking about?
I would like to keep my temperature oil dipstick (information)...if no other option I would consider to remove it and install some other temperature oil info like Vapor...but the best solution (not sure) would be something like this for CRF Showa forks.
Limit in what way? Could you explain it?
Tnks man, I appreciate all the info.
With GatosBros triple clamp I would install Scotts damper low-mount setup and using a dipstick-mounted stabilize, correct?
Cheers guys
Babuja
________
KTM 950 ADV
Old 09-26-2012, 02:21 PM   #37
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Yes, exactly. That's the option I chose.
Agree with you. Personally, would not consider a dipstick mount a viable option.
The CR/F upper tripleclamps make it flat-out impossible to use a Scotts forward-mount frame clamp/stabilizer post. CR500 upper tripleclamp sort of works, but it limits the steering.
No. Our tripleclamps are designed to use this forward-mount frame bracket. I designed the upper tripleclamp around it, and you can see the clearance at full-lock steering in these screen-captures.
Old 09-26-2012, 02:22 PM   #38
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
The machinist we've been using is really jammed-up right now, so we're looking for other manufacturing options. Also just talked to Gary at Emig Racing and sent him a link to this thread to see if he might be willing to make these tripleclamps for us.
Old 09-26-2012, 02:34 PM   #39
babuja
babuja's Avatar
Oddometer: 353
Perfect, very interested
Cheers guys
Babuja
________
KTM 950 ADV
Old 09-28-2012, 01:33 PM   #40
babuja
babuja's Avatar
Oddometer: 353
Acerbis 24 L compability
Hi jesusgatos, could you please confirm compability with Acerbis 24L tank?
Cheers guys
Babuja
________
KTM 950 ADV
Old 09-29-2012, 01:37 AM   #41
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
It's been a while, but I had one and don't remember any clearance issues. Will verify fit as soon as we can get samples made.
Old 11-19-2012, 11:58 AM   #42
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Any word on a conversion kit for the XRL?
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 11-19-2012, 04:19 PM   #43
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Not for the L, no. Think we might just use the R conversion tripleclamps and add steering stops to the L frames. Ordered an XR400 oil cooler so we can make something that will incorporate the oil cooler mounts into the steering stops.
Old 12-04-2012, 10:28 AM   #44
rpmwfo
Oddometer: 134
Any word on when these might be coming out? I've got the forks, just need a set of clamps.
Old 12-11-2012, 11:02 AM   #45
jesusgatos OP
jesusgatos's Avatar
Oddometer: 2,393
Sorry for taking so long to reply. We finally found a machine shop who is able to make these for us in small quantities at reasonable prices. We're just figuring out costs on a few last things and then we'll be taking pre-orders. Will be contacting everyone on our list as soon as we've nailed-down final pricing and have an estimated delivery date.
Times are GMT -7.   It's 01:54 PM.
