Old 09-27-2012, 01:41 PM   #1
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
Need ideas to keep lifting cam in place
I'm looking for a better way to keep this cam from moving on it's shaft.
This is on a printing machine. The cam lifts the weight of the print head of the machine on a stationary follower. The problem is that the cam is only held in place by 2 set screws (which have held pretty well to this point) and the set screws will loosen and allow the cam to move on the shaft and eventually the cam will start hitting the frame of the press. Loctite does not help. On this type of press this is a common problem. One solution I have seen is to split the mounting boss and make it clamp the shaft. Not impossible, but it requires a lot of downtime and a trip to a machine shop. Thought about drilling a divot in the shaft to catch one of the set screws, but don't want to end up chewing up the shaft if that does not hold. Ideas or suggestions from the collective would be welcome.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
JAB is offline   Reply With Quote
Old 09-27-2012, 02:21 PM   #2
Bounder
Oddometer: 400
Can you drill straight through the cam and shaft and use a roll pin to stake it?
Bounder is offline   Reply With Quote
Old 09-27-2012, 02:24 PM   #3
High Country Herb
Olds Cool Adventurer
High Country Herb's Avatar
Oddometer: 2,662
Do you need to be able to adjust its angle? If not, how about drilling it all the way through, and replacing the 2 set screws with bolt and lock nut? Crude, but effective. If you use a brass or aluminum bolt, it will wear before the important steel parts.
edit: you beat me to it!
High Country Herb is offline   Reply With Quote
Old 09-27-2012, 02:29 PM   #4
kioti
Cruzinonline
Oddometer: 205
Cut a Keyway and be done with it.
kioti is offline   Reply With Quote
Old 09-27-2012, 02:35 PM   #5
MagyarMan
MagyarMan's Avatar
Oddometer: 474
Yup that's how it's done!
MagyarMan is offline   Reply With Quote
Old 09-27-2012, 03:02 PM   #6
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
A roll pin might do it. Guessing if it can't move, it may not come loose, but a roll pin won't put up with much shearing force. There is a square key on it already with one of the set screws on top of it to clamp it. I would be wary of drilling the shaft all the way thru because if the shaft or the bolt broke, it could drop the print head on the operators hands.
Thought about drilling and tapping one more hole for a set screw and drilling a matching divot into the shaft for the screw to catch.
Keep it coming.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
Old 09-27-2012, 03:30 PM   #7
timsgs
timsgs's Avatar
Oddometer: 44
Put a small indention in the shaft with the point of a drill bit, then use a pointed short set screw, and then another set screw on top of that one to lock it in place.
2007 DRZ400s, 1995 Nighthawk 750
Son, don't force that , get a bigger hammer....
timsgs is offline   Reply With Quote
Old 09-27-2012, 04:45 PM   #8
MagyarMan
MagyarMan's Avatar
Oddometer: 474
I've worked on NC lathes and the ballscrew shafts had drilled and reamed taper pins slotted on the large end and the safety wired to keep it from backing out. These shafts took a lot of shocks and the only time I had a problem was when there was a tremendous wreck (shearing the brass pins on the slide). The taper pins never broke but were a bit bent! Drove them out ,rereamed the hole and put a slightly larger taper pin in. It might be worth a look?
Old 09-27-2012, 11:27 PM   #9
GreaseMonkey
Rhymes w/piecejunkie
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 4,763
If you want to try the simple stuff first, I'd suggest removing those set screws and replace them with proper bolts that you can tighten. Maybe get them long enough to put a nut on, then you can tighten the bolt down and snug the nut down underneath it to keep it from loosening.
Of course there are plenty of other ways, but to me that would be the easiest and fastest thing to try. Next would be to drill a dimple under where the set screw "cough cough bolt...." is and that should keep it from moving. Lastly you could also tap the hole larger and use a heftier bolt.
GreaseMonkey is offline   Reply With Quote
Old 09-27-2012, 11:29 PM   #10
GreaseMonkey
Oddometer: 4,763
Also, post up some pics of what your machine looks like.
Old 09-28-2012, 08:31 AM   #11
machinebuilder
Oddometer: 691
its har to tell much from the picture but
a set screw on top of the key + 1 90degrees from it, is a very common way to do that.
If loctite isn't holding the set screw, CLEAN the hole and screw first, loctite primer helps too.
IF you have room (deep enough hole) double set screw, the top one will lock the bottom one, just make sure the top one is a flat end
you may need to check the linkage alignment. It sounds like you have a problem with some side forces on the cam pushing it side to side. possibly the piece welded on the cam has a crooked hole.
as a last resort weld it to the shaft
2009 BMW F800GS NON ABS
the best thing to buy for your bike is gas.....Neduro
Remote is not found on the coffee table.......seen on a T Shirt
machinebuilder is offline   Reply With Quote
Old 09-28-2012, 11:35 AM   #12
xcflyn
xcflyn's Avatar
Oddometer: 1,093
-take that gear box apart and send that shaft in and get it splined, then have the cam hub broached ? hopefully timing can be adjusted on input ?
-Go to taper lock hub with key- it wont move- I used to work on 2' cams on 1.500 shafts, heavy load high speed, taper locks rarely failed if ever.
-Also sometimes we look at the problem instead of solution so to speak. Can you counter the cam loading to take some of the strain off the cam hub ? Generally even in high speed applications there is always some type of unloading effect as the cam goes past the high or dwell, this creates the load to be out of balance so to speak.
Just some thoughts. I didnt read too closely so maybe this was covered in past replies.
-I would not drill into the shaft or you may find the next weakest link.
xcflyn is offline   Reply With Quote
Old 09-28-2012, 12:36 PM   #13
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
Here is photo of the machine....................
The whole head hinges at the back. The cam and follower are about a foot in front of the pivot point, so there is a fair amount of weight or twisting force on that cam. Not a lot of speed or impact, but it is constant load/unload. There are 2 smallish set screws holding that cam to the shaft. I like GM's suggestion to replace the screws with bolts. There is a 1/4-20 over the keyway and a 5/16 at 90 degrees of that. Thinking about dropping a couple of brass flat washers in the holes to give the bolts a little more traction on the shaft and lock them in with a lock nut.
The spline shaft idea would totally kill the problem. If were going to build machines like this, that would be the way to go.
Thanks again for the input.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
Old 09-28-2012, 01:22 PM   #14
Benesesso
Benesesso's Avatar
Oddometer: 8,499
Which Loctite and how did you use it? Are the shaft and cam both plain carbon steel?
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 09-28-2012, 01:49 PM   #15
JAB OP
Unsprung Weight
JAB's Avatar
Oddometer: 1,099
Used the blue stuff on the set screws. Everything is carbon steel. I don't think the cam was heat treated.
1991 Honda XR628R
1978 Yamaha XT500
1965 Hodaka Ace 90
Times are GMT -7.   It's 12:56 AM.
