Old 09-06-2012, 04:21 AM   #1
YOUNZ OP
Oddometer: 324
Pulling a trailer
Solo with a trailer usually means 3 wheels on the ground, so this should be the correct slot.
The question is, what are some of the nuances and safety issues one needs to be aware of, before hitching up?
Such as, braking in a turn or curve and making U turns, etc.
Is towing a trailer solo, just not a great idea? Thanks
YOUNZ is offline   Reply With Quote
Old 09-06-2012, 04:48 AM   #2
Bobmws
Curmudgeon At Large
Bobmws's Avatar
Oddometer: 1,245
Lots of miles pulling a camper on a solo bike. Allow for extra braking distance. Brake well before a turn, then you can power through. Braking in a turn pushes the rear wheel to the outside. You will learn to lean the bike way over when that happens! And buy a new seat cover!
Be aware of the extra width at dirveways, gas pumps etc.
You definitely want a swivel hitch on the trailer tongue with your solo bike.
Be prepared for 20-30% fuel mileage reduction.
Pack the trailer with the weight slightly biased to the front, just because you have the space, don't overload it!
I found that loading gear in the camper/trailer reduced the load on the bike and the suspension worked much better.
Bob Weis 04 K12RS - Hannigan Hack
Everything happens for a reason, but sometimes the reason is you're stupid and make bad decisions.
Photo's: http://s1077.photobucket.com/albums/w464/Bobmws/
www.earplugco.com
Bobmws is offline   Reply With Quote
Old 09-06-2012, 05:26 AM   #3
YOUNZ OP
Oddometer: 324
Just avoid U turns?
Old 09-06-2012, 07:46 AM   #4
Montague
UDF Adventurer
Montague's Avatar
Location: an alternate universe, much better than yours
Oddometer: 664
trailer on a solo
Be very careful on steep hills, especially unpaved. With a relatively heavy (small pop up camper) trailer. Let's say the old road into the campground at Meat Cove, Nova Scotia.
Don't ask me how I know...................
But with that said, I hauled the trailer thousands of kms all across Canada with no other issues. I still have it and use it with my Ural and Yaris. The swivel hitch is very good to have.
PS: U Turns are fine (with enough space) and beat the heck out of trying to back up..............although it is no issue with the Ural!
Honda ST1300 with Hannigan Super Sport sidecar (Hondagan), Ural Gear Up, Rokon Ranger and now an Argo, WTF is wrong with me?
A Brit named Billy once said something silly; he so wrongly concluded that Ural deluded.
Montague screwed with this post 09-06-2012 at 10:13 AM
Montague is offline   Reply With Quote
Old 09-06-2012, 09:55 AM   #5
YOUNZ OP
Oddometer: 324
Plan ahead, park smart. Plus, bigger trailer, bigger bike.
And, I assume, not as many different driving issues, as learning to drive a sidecar rig.
Old 09-06-2012, 10:10 AM   #6
Montague
UDF Adventurer
Montague's Avatar
Oddometer: 664
You got it pretty much covered.
Someone else already mentioned, pack the trailer load with care to keep the weight over the wheel(s) with a slight front bias.
Do everything a little slower and more carefully, braking distances will be longer and since you won't have trailer brakes, avoiding sudden or hard braking is wise.
And yes, you are correct, I did not find the trailer learning curve with my K bike nearly as steep as learning to pilot a Ural.
Old 09-28-2012, 02:57 PM   #7
sledgegreen
Oddometer: 12
Be very careful about parking facing downhill. Especially, don't park downhill and then wriggle the plug to see if that will make the indicators on the trailer work.
If you do do this, you are likely to find out why rotating hitches are a good idea.
sledgegreen is offline   Reply With Quote
Times are GMT -7.   It's 06:27 PM.
