09-29-2012, 09:07 AM
#9256 |
Oddometer: 4,235
i will keep mine on for sure! i guess they bolt it on there for something more than to hold parts lol!
09-29-2012, 09:46 AM
#9257 | |
Thomas
Location: Dreary old Norway, dreaming of adventures past
Oddometer: 3,432
'01 F650 Dakar - modified as best I can 2005: Australia - 8 months/ 26.000 km (anti clockwise circle) 2009: Norway - 2 weeks/ 6000 km (Lindesnes to North cape) Gravel Seekers.com Hey ! It's the African ant eater ritual ! |
09-29-2012, 09:52 AM
#9258 | |
Thomas
Oddometer: 3,432
Two words: lock washers.
09-29-2012, 11:03 AM
#9259 |
Oddometer: 11
09-29-2012, 12:13 PM
#9260 | |
2 wheels rule
Oddometer: 862
). I think I will put the bolt back in just to see. Thanks for the tip.Bike felt great though. I put it through some punishing stuff that I had not even ridden my small 450 through! I should have taken a picture of a couple of the "roads", but I was having too much fun to stop. Suspension worked overtime for sure! Bottom'd out more than once! A few from the tamest roads I was on yesterday. ![]() ![]() ![]() Snow up there! Yikes!!!! ![]() ![]()
Matto |
09-29-2012, 12:17 PM
#9261 | |
2 wheels rule
Oddometer: 862
One deployed, one in (old photo):
Matto mattomoto screwed with this post 09-29-2012 at 06:32 PM |
09-29-2012, 03:06 PM
#9262 | |
865+652
Oddometer: 769
Next winter I might use it as a template to make a new fiberglass one piece headlight/dash/screen unit to suit the twin Hella lights globe access at the moment is a pain requiring dismantling the whole setup, not helpful when your out n about.
09-29-2012, 05:05 PM
#9263 | |
Oddometer: 11
Ah, I see. The twin lights threw me off. Are they the touratech one or something else? I'm bummed that Britannia doesn't make something for the 3 screw 650s. The lynx is awesome looking. Aside from the mounting problems and bulb access do you like the sliding screen design?
09-29-2012, 05:13 PM
#9264 |
Oddometer: 736
Water temp sensor
Anyone know if theres a port available to put a water temp sensor?? Was going to use an inline hose adapter but would rather have it in the engine if possible.
All that is gold does not glitter, Not all those who wander are lost J.R.R. Tolkien 01 F650GS Dakar 04 KLR 650 (Need to sell) |
09-29-2012, 05:58 PM
#9265 | |
865+652
Oddometer: 769
Low beam 1029-12v ![]() High beam 1030-12v
09-29-2012, 09:47 PM
#9266 | |
A Serious Man
Oddometer: 2,347
Looks like Brian Head this time of year. |
09-29-2012, 11:53 PM
#9267 |
Oddometer: 349
No idea on a port but if you're measuring water temp you really want to know the temp coming out of the radiator. It'll always be hot in and coming out of the engine, you only need to worry if it's still hot going back in.
09-30-2012, 12:09 AM
#9268 | |
Thomas
Oddometer: 3,432
I should perhaps add that my bike was super laden with camping gear and since the bolt sheared at the RHS it was still pretty taut on the LHS so only flexed on the one side which is probably why I noticed. This happened in the middle of the Victorian high country and I fixed it by buying a meter long (8 or 10mm ?) threaded rod which I sawed down to the proper lenght (about a foot ?) and added two nuts that I could lock against each other to lock it (It threads into a welded on nut on the LHS). The temporary fix is still on there 6 years later. In my mind at least that bolt is what keeps the whole frame from flexing at the top engine/ frame mount (where the castle nut is)
09-30-2012, 01:15 AM
#9269 |
Oddometer: 836
You won the jackpot lottery when we let you into Oz to litter the high country with broken bolts and the outback with all the other bits that fell off so no more lottery wins for you. I notice you still have that gift we gave you too, that red coloured dye sure hangs around for life, gets under the skin as well
09-30-2012, 06:28 AM
#9270 | |
Thomas
Oddometer: 3,432
