Old 10-01-2012, 05:30 PM   #9
guzzimike
guzzimike's Avatar
Oddometer: 1,396
Originally Posted by runnin4melife View Post
What front fender did you use? Also did you have to make that bracket so it did not interfere with your horn etc...?
Fender is an aftermarket (Polisport?) for a KTM 450exc.
The mounting bracket is made from a piece of plastic cutting board, (tough stuff that shit) I meant to paint it black but tried a fit up before painting and then couldn't be arsed taking it apart again.
It is mounted by the 2 bolts (6mm) that hold the semi circular plastic bit to the bottom triple, spaced out with 20mmOD, 6mm ID x 15mm ally spacers (home made) and a replaced longer (60mm) horn bolt, again with spacer.
This all gives spanner access to the 4 x 6mm bolts that mount the fender to the cutting board, again with spacers, you can see 'em in the pic.
The long horn bolt is accessed through a hole drilled in the guard large enough for the socket spanner, it is locked by a nut above the horn.
I hope all this makes sense, it's a lot harder to explain than to do.
IT has just been across Oz on the dirt with no problems, in fact there is less crap comes off the front wheel into your face than with the stock guard.
My design is not original, thanks go to Dan (WW Ronin) for the inspiration, you can find his detailed build on this forum.
I don't like the Wunderlich "beak" either. (and the $$$!)
Armageddon Was Yesterday, Today We Have a Problem
East is East & West is West 2008
http://www.advrider.com/forums/ad.php?t=400050
A Long Weekend 2009
http://www.advrider.com/forums/showthread.php?t=523893
All the Way to Nowhere & Back Again. 2010
http://www.advrider.com/forums/showthread.php?t=619683
Save 5 bucks on your Smugmug, use my discount code
hQo9Atub1N9jg
guzzimike screwed with this post 10-01-2012 at 05:37 PM
guzzimike is offline   Reply With Quote
Times are GMT -7.   It's 01:58 PM.
