Old 10-02-2012, 01:45 PM   #1
bob393 OP
bob393's Avatar
Oddometer: 389
Rattle in the front
I haven't taken the front of my GS apart to look for it yet but I have a dash, windshield,
or beak rattle at low RPM's. It's been down a few time and I'm on my second windshield
so something defiantly could be tweaked. Where would you look first?
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 10-02-2012, 01:52 PM   #2
JAB
Unsprung Weight
JAB's Avatar
Oddometer: 1,286
Don't know the first thing about GS's but find your self a big rubber mallet and start (carefully) thumping your front tire and the ends of your bars. Could be something pushed into another thing making the rattle. Keep tapping/thumping things 'til you find and eliminate the source. Good luck.
1991 Honda XR628R
1978 Yamaha XT500
JAB is offline   Reply With Quote
Old 10-02-2012, 03:20 PM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 53,776
Bob,
There is a pretty good chance your speedo cluster is loose. You might have lost one of the jesus clips, or a rubber isolator is worn out.
Also, check your windshield lower mounts. One of them could have sheared, but you can't tell by looking.
Jim
PS Rattles are hard to diagnose on the internet.
Old 10-02-2012, 04:52 PM   #4
Nacho911
Nacho911's Avatar
Oddometer: 463
The internal springs have a rattle in them. Most refer to it as a "clack". Bestrest products sell a $7.00 set of rubber stoppers clack "clack stoppers". This might be what you hear. You will only hear it in rougher terrain. I fkn hate the sound. Bought the Bestrest stuff a while ago just no time to install.
Nacho911
Nacho911 is offline   Reply With Quote
Old 10-05-2012, 05:08 AM   #5
bob393 OP
bob393's Avatar
Oddometer: 389
Originally Posted by JimVonBaden View Post
Bob,
Jim
Your being nice, rattles are impossible to diagnose over the internet.
I will look into the mounts and clips, I'm only sure that the lower windshield mounts are tight.
I can't find those "clack stoppers" on the Bestrest site?
And yes I hate the sound also!
It only occurs at the lower lugging rpm. My first thought was the adventure windshield winglets were hitting the windshield but that's not it. It sure sounds like something inside or under the dash. It's not a heavy suspension type clunk just a fiberglass kind of rattle.
Old 10-05-2012, 07:06 PM   #6
bob393 OP
bob393's Avatar
Oddometer: 389
OK So I banged on it, shook it wiggled it and I can't get it to make any noise except
when I lug the engine in first or second gear.
Old 10-05-2012, 08:30 PM   #7
FBB
FBB's Avatar
Oddometer: 154
Noise
Looked at the spacing on the beak? You said it had been down and maybe tweaked.
I had taken the beak off to install a oil cooler guard and apparently didn't get it quite right when I re installed it.,
Close, but not quite right even though everything looked OK and I got the same sort of sound. This was especially true when it was cold and I first started out for the day.
Pulled the beak back off and put it back on and the sound was gone.
Mine is a 2011 so not sure if my experience applies here so take it with a grain of salt. And maybe some Tequila...
FBB is offline   Reply With Quote
Old 10-06-2012, 05:33 PM   #8
bob393 OP
bob393's Avatar
Oddometer: 389
Yes. When cold first thing in the morning. Yes.
I'll pull it off and look. Thanks
Old 10-08-2012, 12:36 PM   #9
hahmule
Balding Gloriously
hahmule's Avatar
Oddometer: 636
funny noises....
My rattle turned out to be the front of my engine guards. Givi bars on Wee Strom though.
What a lovely bunch of coconuts.
Better to be a fast mule than a slow race horse.
hahmule is offline   Reply With Quote
Old 10-11-2012, 03:06 AM   #10
bob393 OP
bob393's Avatar
Oddometer: 389
Thanks but that was the first thing I checked was the engine guard. Solid as a rock.
Old 10-21-2012, 10:59 AM   #11
bob393 OP
bob393's Avatar
Oddometer: 389
I fixed it in a ghetto way.
I placed two hard rubber wedges between the dash/windshield mounting tube and the beak plastics to the outside. Now its quiet as a pin drop.
Times are GMT -7.   It's 12:25 AM.
