Old 10-02-2012, 01:54 PM   #13756
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,225
Originally Posted by pretbek View Post
You must not be from the US, land of the free, home of the most lawyers per capita on earth.
I know where you are from, and I agree with you.
You're right. I should shut up or they will remove the TC options. Leave us trying how to
find away around all the netuering of gears, rpm and TC. Let alone braking. Suddenly
vintage bikes don't sound so bad.
Part of the problem with all this reliable new electric stuff is it makes it too easy for the factory
to put a party killing bug in everything.
pluric is offline   Reply With Quote
Old 10-02-2012, 02:03 PM   #13757
Mikef5000
Oddometer: 2,031
Originally Posted by pluric View Post
I've always thought TC off should be the default setting. I'm always
forgetting to reset it after stopping.
I've been looking into a method to cause it to automatically switch it to TC2 upon start-up. I'll be doing some playing around, but I think it can be done once you've tapped into the switch in the gauge cluster (as if to add a handlebar mounted switch).
This wiring diagram (stolen from here) should turn constant power into a pulse. So, in theory, turning on the headlights (like starting the bike) will also press the TC button, switching it to TC2. Again, in theory, you could change the value of the resistor to create a longer pulse, such as that needed to turn the TC completely off. You could even make it wait 10 seconds before switching with a time delay relay, but then it wouldn't work if you started moving to soon.
2008 990 Adventure
2008 WR250R
www.Mikef5000.com
Mikef5000 is offline   Reply With Quote
Old 10-02-2012, 02:33 PM   #13758
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,225
You are light years ahead of me. I'm still pleased at myself to be able to reset the trip meter.
Now they tell me there are two. I'm screwed.
Old 10-02-2012, 02:44 PM   #13759
GrahamD
GrahamD's Avatar
Oddometer: 5,399
Originally Posted by Cykel View Post
On the topic of normal center-stand behaviors, could anyone give input on the TCS system? I believe mine to be non-functional given that I never see it intervene and can get the rear wheel to spin up in any mode.
Here are the tests I've done:
1 - Tested ABS functionality via the test connector under the seat. All is good.
2 - Tested ABS on the road and it worked
3 - Bike on center stand, TC1, running, throttle slowly to 20 mph...ABS light flashes but nothing else.
4 - Above test in TC2 with same result, except a few seconds after I brake the rear to a stop the TC shuts itself off and throws a code as expected.
I checked the sensors and rings for excessive dirt or buildup but all quite clean.
Never had any intervention in any mode, road or dirt.
I expected some TC intervention when on the throttle on the center-stand. Talked with a shop on Friday and taking it in later this week, but wanted more data from others if possible.
This may help..
Start at 5:20..
Cheers
Graham
"It's better to ride a boring bike than push an interesting one" ... Canuman
"I just may as well admit that my other bikes are toast. I don't ride them. Plain and simple. I didn't want this. It wasn't the plan." - snakebitten
GrahamD is offline   Reply With Quote
Old 10-02-2012, 03:26 PM   #13760
wolftrax
wolftrax's Avatar
Oddometer: 463
The trip meter can be reset?
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
wolftrax is offline   Reply With Quote
Old 10-02-2012, 03:56 PM   #13761
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,225
Yup, every 1,000 miles. Automatic.
Old 10-02-2012, 05:43 PM   #13762
wolftrax
wolftrax's Avatar
Oddometer: 463
WOW, this bike has it all. I'll bet the clock resets automatically for daylight savings time as well, once a year.
2014 Honda CRF250L
2013 Husky TR 650
1990 KLR650
Old 10-02-2012, 05:58 PM   #13763
GrahamD
GrahamD's Avatar
Oddometer: 5,399
Obviously all those nasty porky bike comments have upset the engineers at YAMAHA and they are hitting back at the critics..
Welcome the new cross plane YAMAHA triple..Is this the new X-XJ-750?
http://blog.motorcycle.com/2012/10/0...riple-concept/
Don't know how the new 750 Tenere will hold up in the rough though.
Old 10-02-2012, 06:18 PM   #13764
RED CAT
Bumpy Backroader
RED CAT's Avatar
Oddometer: 3,001
Giggle!
Yea, these new high tech bikes are just so boring compared to the old banana boats we used to ride. Hate the fact that they are faster, more reliable, get better gas milage and handle better too. Give me the old shit any day!
RED CAT is offline   Reply With Quote
Old 10-02-2012, 07:20 PM   #13765
gmsnowball
Black Bear Pass
gmsnowball's Avatar
Oddometer: 901
Wicked Right
Snowball
Ride Hard, Fast and Often
Super Tenere
KLR 650
gmsnowball is offline   Reply With Quote
Old 10-02-2012, 07:23 PM   #13766
pluric
Gimpy Adventurer
pluric's Avatar
Oddometer: 17,225
Great. Now we can't buy anything else until the "New Model" may possibly some time
in the future not yet to be announced suffer endless speculation and many threads of what
it could, should of been and how Yamaha missed the target. Was Triumph in it's sights?
A resurection of the old XS 750 triple? (I owned one).
Old 10-03-2012, 07:18 AM   #13767
Paulvt1
Paulvt1's Avatar
Oddometer: 3,595
A new TDM with a Yamaha Triple motor? Oh yes...
Paulvt1 is offline   Reply With Quote
Old 10-03-2012, 08:03 AM   #13768
Wreckchecker
Ungeneer to broked stuff.
Oddometer: 2,860
That could be the case.
When in TCS1 I hit the gas hard in loose gravel and the rear end swings around everywhere...no intervention. Haven't really tested TCS2 in the same fashion...just ridden without worrying about it.
I think there needs to be some definition of the above, because you and others may have different thoughts. To somebody experienced on dirt on this bike, especially standing on the pegs as is normal for off road, this phrase means the rear wheel is trying to pass the front and keeping the bike vertical is a challenge. It's bucking like a wild-ass bronco, going up a rutted loose gravel or loose dirt section.
For somebody used to the street, especially if their butt is on the seat, the above could mean the tire broke traction and stepped out left a few inches, reconnected, then broke loose to the right for a few inches. It'd be scary as heck the first times, but the traction control would allow it.
Super Tenere & WR250R, AMA, IBA
Wreckchecker is offline   Reply With Quote
Old 10-03-2012, 08:17 AM   #13769
Wreckchecker
Oddometer: 2,860
Cool way to show off a new motor and triples are great! This really could be the basis for a mid-size, too.
It sure oughta get Triumph's attention.
Old 10-03-2012, 12:58 PM   #13770
GrahamD
GrahamD's Avatar
Oddometer: 5,399
MCN UK won't think its any good or am I just being cynical
Times are GMT -7.   It's 12:57 PM.
