10-02-2012, 08:25 AM
#13231 |
Oddometer: 226
I have seen plenty of street legal dual sport bikes in California that people for some reason or another decided to make into off-road only dirtbikes (green sticker). It can be difficult to get them converted back to street legal, but not impossible.
Buncha dirt bikes with license plates. |
10-02-2012, 06:44 PM
#13232 |
wandering the desert
Oddometer: 680
Not sure how many of you have been following my build thread
The NM DR350 dirt bike but I decided to build my own panniers to hold some ammo cans. I know this has been plenty of times before, but for those of you who don't want to spend more than $30, this is the way to go. I wanted something along the lines of this: ![]() And this is what I ended up with: ![]() ![]() The cans I used are a little larger than your standard .50 cal cans ![]() ![]() I was going to add some extra braces for the ammo can brackets, but I started thinking about it. When the bike gets laid over, I'd rather have the cans collapse or the bracket deform before the subframe get damaged. The other good thing about my design is that I can easily switch out to smaller/larger cans if need be. The whole assembly is getting painted as I post this.
Many 'a hand began to scan around for the next plateau. Some say it was Greenland, and some say Mexico. Others decided it was nowhere except for where they stood. Border Road 100 Border Road Rally Raid '13 Husky Terra 650 , '08 Kawasaki Meanstreak 1600, '95 DR350S
10-02-2012, 07:20 PM
#13233 |
Oddometer: 201
That setup looks awesome. Very inspiring. How much weight does it add?
___________________ 1999 DR350X 1982 GS750T |
10-02-2012, 07:27 PM
#13234 | |
Oddometer: 680
Good question. I'll weigh it when I get done painting.
10-02-2012, 07:57 PM
#13235 |
Oddometer: 680
Ok here is the weigh in:
Rack, cans, and paint come out to 7.6 lbs. Not bad considering that the rack is solid steel, not tubing.
10-02-2012, 09:02 PM
#13236 | |
Oddometer: 201
. Making one like this for myself has a high priority now. I turned a ATV side bag into a tank bag but I'm getting tired of having to ride with a backpack too.
10-03-2012, 03:47 AM
#13237 |
-Devo
Oddometer: 2,905
It looks like a good setup, but do you really want something that unforgiving and pointy when you low side? I just twist fractured my right leg while my toe was stuck a rut going down last week. It may have prevented the bike going down close enough to the ground to prevent my heel from swinging around until crunch crunch, but more likely looks like it would have dug into my back only complicating the situation. Nearly everything on the bike would just crush you and is generally blunt, but those cans would puncture you
06' Wee 99' DR350 devo2002 screwed with this post 10-03-2012 at 03:55 AM |
10-03-2012, 06:53 AM
#13238 | |
Oddometer: 680
Considering that this setup cost me less than $30 (metal, cans, welding supplies), and a similar pannier setup would be about $400, and I'm more than likely going to lay this over a few times, I'm going to take the risk. Yes it does make the bike more prone for biting me when I biff it, but so would a regular set of hard panniers. You're right that the ammo cans have pointier edges than some pannier setups, but I doubt they could cause any arterial bleeding. Maybe a decent puncture wound that a pressure dressing would patch up.
10-03-2012, 07:04 AM
#13239 |
-Devo
Oddometer: 2,905
Hey I certainly understand and wish you the best of luck.
![]() Wolfman Enduro bags weigh less than a pound and are just over $100, less if used. Sitting here with my leg in a boot for the past week I guess I'm hesitant to add something potentially hazardous because of lack of funds, one bad spill and it could be 100 fold.
06' Wee 99' DR350 |
10-03-2012, 07:08 AM
#13240 | |
Oddometer: 680
Starting next year this bike will be my primary commuter (100mi/day, 30mi ranch roads) and I will be commuting day and night. Cattle is going to be my main concern, hence the big honkin headlight, and its open range most of the way.
10-03-2012, 08:06 AM
#13241 |
Oddometer: 680
Ah ha! I've just found the solution to how to mount a holster to the tank! Has anyone else used this setup yet? http://www.tankvest.com/ This looks perfect for keeping a .45 in quick reach.
10-03-2012, 09:55 AM
#13242 |
Oddometer: 144
Hey RuggedExposure,
Nice work on the rack and .50 cal panniers. I wish I had the skills to build something like that. Food-for-thought/suggestion: maybe putting some gussets in the 90 degree corners where the rack is welded together for the side mounts moving down off the main horizontal rack. This would cut down on the vibration/cracking/breaking possibilities down the (washboard) road. Still, nice job. Can you duplicate/build one for me? Trent |
10-03-2012, 10:01 AM
#13243 | |
Oddometer: 144
10-03-2012, 10:04 AM
#13244 | |
Oddometer: 581
Regards, Gregory Bender |
10-03-2012, 10:20 AM
#13245 |
Oddometer: 144
Ooh. Obviously that didn't occur to me? While I would like to know how those would work on a long overlander trip, I'm not likely to be the guinea pig and spend the money on it, only to come to the same conclusion as you Greg. Thanks.
