10-01-2012, 04:30 PM
#16 | |
Oddometer: 1,321
The mounting bracket is made from a piece of plastic cutting board, (tough stuff that shit) I meant to paint it black but tried a fit up before painting and then couldn't be arsed taking it apart again. It is mounted by the 2 bolts (6mm) that hold the semi circular plastic bit to the bottom triple, spaced out with 20mmOD, 6mm ID x 15mm ally spacers (home made) and a replaced longer (60mm) horn bolt, again with spacer. This all gives spanner access to the 4 x 6mm bolts that mount the fender to the cutting board, again with spacers, you can see 'em in the pic. The long horn bolt is accessed through a hole drilled in the guard large enough for the socket spanner, it is locked by a nut above the horn. I hope all this makes sense, it's a lot harder to explain than to do. IT has just been across Oz on the dirt with no problems, in fact there is less crap comes off the front wheel into your face than with the stock guard. My design is not original, thanks go to Dan (WW Ronin) for the inspiration, you can find his detailed build on this forum. I don't like the Wunderlich "beak" either. (and the $$$!)
Armageddon Was Yesterday, Today We Have a Problem East is East & West is West 2008 http://www.advrider.com/forums/ad.php?t=400050 A Long Weekend 2009 http://www.advrider.com/forums/showthread.php?t=523893 All the Way to Nowhere & Back Again. 2010 http://www.advrider.com/forums/showthread.php?t=619683 Save 5 bucks on your Smugmug, use my discount code hQo9Atub1N9jg guzzimike screwed with this post 10-01-2012 at 04:37 PM |
10-01-2012, 04:49 PM
#17 |
Oddometer: 481
Yeah it looked very similar to the setup I had seen before. I am rolling with the KTM 690 fender (which hopefully will be here soon). Since I am relocating the horn I plan on bringing it right up on the lower triple so I am hoping I do not need to make much if any form of spacers. If so I will probably make it out of CF. Waiting for now and will see once I get the fender in. Motorfiets has the 690 on his which looks great but he also has the KTM front suspension which makes hookup easy.
10-02-2012, 03:50 PM
#18 |
Oddometer: 481
Fender
As soon as I get the KTM fender in and fit it I will come up with the final design, if anyone has suggestions etc... please let me know, especially if you have attempted to do something similar.
10-03-2012, 03:45 AM
#19 | |
Oddometer: 1,119
I figure if you've had both, and ridden both with decent loads on on those roads, then you'll probably come the closest to understanding the issues I have with riding fire trails 2 up. It'd be interesting to hear what you think. Sorry for the hi-jack. The high fender option is something I'm still planning for the F800. I have the alloy plate and a mud guard. I just lost the will power somewhere along the line. |
10-03-2012, 06:43 AM
#20 | |
Oddometer: 1,321
PM sent
Armageddon Was Yesterday, Today We Have a Problem East is East & West is West 2008 http://www.advrider.com/forums/ad.php?t=400050 A Long Weekend 2009 http://www.advrider.com/forums/showthread.php?t=523893 All the Way to Nowhere & Back Again. 2010 http://www.advrider.com/forums/showthread.php?t=619683 Save 5 bucks on your Smugmug, use my discount code hQo9Atub1N9jg |
10-05-2012, 01:21 PM
#21 |
Oddometer: 481
Snafu
The best laid plans of mice and men often go awry, Because I am placing the KTM fender directly on the lower triple, with a small piece of 10 gauge galvanized steel as a mounting bracket (which lowers the fender 3/16 of an inch from the triple). I do not have much is any room to really accentuate the beak. It is looking now like I will bring it out just a bit and have a rather short section due to space. This picture shows how close the fender sits ![]() The bolt pattern on the lower triple does not mesh with a 4 bolt (square pattern) on the KTM 690 fender. This was remedied with a piece of steal, I have to track down proper bolts and will show this setup when it is complete. ![]() Once I get the bracket complete etc... I will complete the front fender and begin the necessary brake line routing. I have already acquired another fork clamp like the one on the stock setup to aid in routing the brake lines. I will also be doing a slightly different setup from what I have seen. That will be posted when I get to it. I am in the R&D phase right now. ![]() Now I did something slightly different than what other people have done, in stead of buying MX fork guards I opted to modify the front fender (I had a spare), I lopped off the extra stuff and will be using the stock plastic as a mold for the carbonfiber guards. This alleviates the use of trying to fabricate a bracket to match the stock bolt pattern as well as retains some of the aesthetics. They will have a CF piece coming from the other bolt hole that the back part of the stock fender attached for inc stability. ![]() ![]() ![]() I will post pictures as I work through the phases. |
10-05-2012, 01:41 PM
#22 |
Ridgerunner
Oddometer: 44
Looks like you could fab a wedge shaped piece between the fender and the cowl and have a nice smooth curve with the fender forming the new "beak" without too much effort. I think it would look great.
Steve One out of four people is insane - check your three best friends - if they're normal then it must be you! |
10-05-2012, 01:51 PM
#23 | |
Oddometer: 481
10-05-2012, 03:36 PM
#24 |
Oddometer: 481
10-05-2012, 04:03 PM
#25 |
Oddometer: 173
For safety sake - you will need to put your original low front fender back on or reroute the brake lines. The brakeline crossover hose has been known to snag the front tire and cause a crash when the fender is missing.
10-05-2012, 04:17 PM
#26 | |
Oddometer: 481
The whole mod is to remove the risk of snapping the front fender and eating dirt. Brake lines will be routed solo down each fork to their respective caliper. I haven't picked them up yet as I am still determining how they will be routed. The bike is static until I complete everything anyways.
runnin4melife screwed with this post 10-05-2012 at 04:25 PM |
10-06-2012, 02:41 AM
#27 | |
Oddometer: 173
Now that I read your previous posts - I see that you were planning to reroute the brake lines. Your fender conversion is looking good!
![]() Quote:
10-06-2012, 06:14 AM
#28 |
Oddometer: 481
Ebrabaek, I was considering making a CF chain guard using the stock one as a mold, any thoughts? I guess the biggest concern is whether or not any of the lubricant can mess with the resin?
10-06-2012, 07:10 AM
#29 | |
Oddometer: 2,855
![]() .... It's terrible.... I'm scarred for life.... It is a fantastic solution, but I don't feel I am there yet....in breaking the natural lines with the beak. The more I look at it, the snorkels have to go CF..... When you see them from riders perspective, the sharp top corner is hideous, and has to go at some point. My plan is to tie in a new set of CF snorkels Flow that into a new CF piece replacing the top plastic that goes fwd to the beak.... to break that line. So pieces removes, will be beak.... top plastic leading to the beak..... snorkels. Then a one piece CF will replace that.....with out the beak...of course. Sort of like a small .....less intrusive rally fairing.... with an adjustable see thru shield..... I'm exited.Good work.
Erling |
10-06-2012, 07:27 AM
#30 | |
Oddometer: 481
Wow that would be sweet
it is a bit beyond my skill-set I believe but none the less it would be awesome. The vacuum sealing will have to wait for now but I like your idea of the custom mold etc... It would def have a market, as we cannot stop it with the farkle. I have seen quite a few of the custom high fenders and am trying to make mine look like it was intended to be that way, the issue like you said is following the lines of the body work and that will be difficult unless you fab a completely new upper panel. If you go that route will you just eliminate the need for a high front fender and absorb all the stuff flying into your face? Quote:
