Old 10-03-2012, 07:17 AM   #2611
GB
Mod Squad
GB's Avatar
Oddometer: 56,898
Thanks for the embedded high res pics.. When I have time, I think I'm going to copy them to a closed pics thread.
Old 10-03-2012, 07:21 AM   #2612
RL Lemke
RL Lemke's Avatar
Oddometer: 1,586
RL Lemke
Dallas, Texas
RL Lemke is offline   Reply With Quote
Old 10-03-2012, 07:21 AM   #2613
RL Lemke
RL Lemke's Avatar
Oddometer: 1,586
Follow the link back to my SmugMug account for the real full sized photos. +- 5mb each.
RL Lemke
Dallas, Texas
Old 10-03-2012, 07:26 AM   #2614
GSMarc
GSMarc's Avatar
Oddometer: 1,121
If you consider "weight" as the ennemy, more kg is not the way to go...
but the ratio power/weight is good.
Consider the new model WC being +9 kg from the actual DOHC one
(also in wet weight)
HP2E : 105 hp/175 kg ==> 0,60 hp/kg
WC....: 125 hp/212 kg ==> 0,59 hp/kg
DOHC : 110 hp/203 kg ==> 0,54 hp/kg
2014 KTM EXC450 6Days
2008 HP2/MM ABS
2008 HP2/MM
2005 HP2E
2005 HP2E SM Prototype
GSMarc is offline   Reply With Quote
Old 10-03-2012, 07:33 AM   #2615
GB
Mod Squad
GB's Avatar
Oddometer: 56,898
Thanks RL, I think I"m going to do just that.. this way all the pics are easily accessible.
Old 10-03-2012, 07:34 AM   #2616
RL Lemke
RL Lemke's Avatar
Oddometer: 1,586
RL Lemke
Dallas, Texas
Old 10-03-2012, 07:37 AM   #2617
RL Lemke
RL Lemke's Avatar
Oddometer: 1,586
An overview of highlights of the new BMW R 1200 GS.
• Completely newly designed engine for top-level riding dynamics within the travel enduro segment.
• Capacity 1170 cc, rated output 92 kW (125 bhp) at 7700 rpm and a maximum torque of 125 Nm at 6500 rpm.
• Cylinder heads with vertical through-flow for increased efficiency and performance.
• Compact air/water cooling for optimum heat management.
• Basic engine with compact, light and yet rigidity-optimised crankshaft.
• Vertically separated case in open deck construction.
• 6-speed gearbox integrated in engine housing, including wet clutch with anti-hopping function and reduced lever operation force.
• New intake system for optimum output and torque with 52 mm throttle valve diameter.
• E-gas for improved ridability, running smoothness and special functions.
• Innovative exhaust gas system with electronically controlled exhaust flap for optimum performance characteristics and an earthy boxer sound.
• Freely selectable riding modes “Rain”, “Road”, “Dynamic”, “Enduro” and “Enduro Pro” with three different electromotive throttle actuator settings in conjunction with ASC (Automatic Stability Control), ABS and ASC settings for off-road riding as well as different mode-specific Dynamic ESA settings (option ex works).
• New suspension with torsionally stiff tubular steel bridge frame and bolt-on rear frame.
• Optimised lightweight cardan shaft drive now running on the left-hand side.
• Newly developed and optimised Telelever at front and EVO Paralever at rear for an even more precise ride feel.
• Refined master chassis geometry data and long swingarm for excellent traction.
• Optimised seating width and position, and adjustable handlebars for even greater comfort.
• Optimised ground reach for rider (inner leg length).
• Tyre/wheel dimensions of 120/70 R19 at front and 170/60 R17 at rear as a world first, tailored specially to the R 1200 GS.
• Revised BMW Motorrad brake system with radially mounted Brembo Monobloc brake calipers at front and 2-piston floating caliper with enlarged brake disc at rear (Ψ 276mm, previously 265mm).
• BMW Motorrad Integral ABS as standard.
• Semiactive suspension Dynamic ESA (ex works option).
• Main headlight with optimised light efficiency and LED daytime running light (ex works option).
• World’s first motorcycle with LED main headlight featuring integrated daytime running light (ex works option).
• New vehicle electrical system with partitioning of functions.
• Extended electric switch units.
• Electronic cruise control (ex works option).
• Preparation for navigation unit with Multi-Controller to operate the BMW Motorrad Navigator IV (ex works option).
• Windshield with one-hand operation for excellent wind and weather protection.
• Seat with multiple adjustment functions for perfect ergonomics.
• Number plate carriers quick to dismount for off-road riding.
• Increased ground clearance (+ 8 mm)
• New instrument cluster with on-board computer as standard. PRO on-board computer as an option.
• Four main paint finishes to choose from:
Alpine White, Racing Red, Blue Fire and Thunder Grey Metallic.
 Extensive range of special accessories and rider equipment
Options and special accessories for a wide range of customisation opportunities.
An even more comprehensive BMW Motorrad program of options and special accessories will be available for further customisation of the new R 1200 GS in future.
Options are supplied directly ex works and are integrated in the production process. Special accessories are installed by the BMW Motorrad dealer or by customers themselves. These are features which can also be retrofitted.
Options.
• ASC (Automatic Stability Control) and ride modes.
• Tyre pressure control (RDC).
• Semiactive suspension Dynamic ESA.
• Preparation for navigation unit.
• Alarm system.
• Heated grips.
• White LED white turn indicators.
• Exhaust system, chrome-plated.
• Rider’s seat, low (820 mm).
• Lowered suspension.
• Cross-spoke wheels.
• LED headlight with daytime running light.
• Daytime running light.
• On-board computer PRO.
• Case holder left/right.
• Hand protector
• Cruise control.
Active package.
• ASC and ride modes.
• Cruise control.
Comfort package.
• White LED turn indicators.
• Hand protectors.
• RDC.
Touring package.
• Dynamic ESA.
• Exhaust system chrome-plated.
• Heated grips.
• Hand protectors.
Dynamic package.
• Dynamic ESA.
• ASC.
• Ride modes.
• LED headlight.
• LED white turn indicators.
Special accessories.
Safety.
• Enduro crash bars.
• Enduro engine guard.
• Safety screw for oil filler neck.
• Alarm system.
• Headlight guard (for off-road use only).
• Hand protectors.
Storage program.
• Vario case left/right.
• Vario topcase.
• Topcase holder for luggage carrier.
• Luggage carrier instead of passenger seat.
• Liners for Vario case.
• Liner for Vario topcase.
• Back pads for Vario topcase.
• Case holder for Vario case.
• Tank rucksack large, waterproof.
• Tank rucksack small, waterproof.
Design.
• LED additional headlight.
Sound.
• Akrapović sports silencer .
Ergonomics and comfort.
• Rallye seat with luggage panel (890 mm, not adjustable).
• Rider’s seat (850 / 870 mm).
• Rider’s seat, (830 / 850 mm).
• Rider’s seat high (870mm / 890 mm).
• Footbrake lever, adjustable.
• Rider footrests with sprung interior panel, adjustable.
• Wide footrests.
• Windshield, tinted.
• Heated grips.
Navigation and communication.
• BMW Motorrad Navigator IV.
• Function Navigator pouch.
Maintenance and technology.
• Additional power socket.
• LED lamp for charging socket.
• On-board toolkit.
• Paddock stand.
• Battery charger.
• Lock barrel repair kit.
RL Lemke
Dallas, Texas
Old 10-03-2012, 07:50 AM   #2618
tattewell
Mad Poser
tattewell's Avatar
Oddometer: 786
Nice looking, but not interested until there is an over priced adventure.
tattewell is offline   Reply With Quote
Old 10-03-2012, 07:53 AM   #2619
Starkebogen
Oddometer: 18
First Impressions
Hello Fellow Inmates
I've just returned from a few hours at Intermot. I can't add anything to the technical stuiff that other inmates have kindly produced for us all. What I can say is that in my view it looks better in real life than in the photographs. Of course, beauty is in the eye of the beholder. I'm now eagerly for the Adventure version.
Max
Life should NOT be a journey to the grave with the intention of arriving safely in an attractive and well preserved body, but rather to skid in sideways, a glass of Sekt in one hand and an open bottle in the other, body thoroughly used up and totally worn out, screaming "WOO HOO, WHAT A RIDE!"
2008 R1200 Gelδnde Straίe Abenteuer (Stella Noviomagi)
1995 K1100RS
Starkebogen is offline   Reply With Quote
Old 10-03-2012, 08:12 AM   #2620
sphyrnidus
born to ride
sphyrnidus's Avatar
Oddometer: 133
And The GSA will take quite a while to arrive. People who know say it will be in 2015.... !
If your destination is unknown, you'll always arrive
sphyrnidus is offline   Reply With Quote
Old 10-03-2012, 08:15 AM   #2621
DrunkWombat
GS and Proud
DrunkWombat's Avatar
Oddometer: 2,270
Colour me impressed, I really likes it!
Scenery: That blurry stuff on the side of the road.
DrunkWombat is offline   Reply With Quote
Old 10-03-2012, 08:21 AM   #2622
pauljr
pauljr's Avatar
Oddometer: 90
I'm sure they will sell a boatload, but I can't believe this is the same company that designed my R100S or R100RS. I just can't decide if it is in fact uglier than the R1200ST, which I loved to ride but just could not bear to buy when looking at it.
Paul
pauljr is offline   Reply With Quote
Old 10-03-2012, 08:29 AM   #2623
ricochet
ricochet's Avatar
Oddometer: 113
With the design direction BMW took for the 2013 GS, I believe they are targetting the below 40 year old market which I believe comprise the majority of GS owners at present. The above 40 crowd, I surmise, wish that the Adventure version looks a little more tame than the mechanical look of its smaller sibling.
Originally Posted by SocalRob View Post
If I want pretty, I will buy Italian.
Me, I wanted it reliable and pretty at the same time, and from an 1150 and 1200GS Adventures, I went Japanese
12 Honda VFR 1200X Crosstourer
07 R1200GS Adventure(SOLD)
04 1150GS Adventure(SOLD)
04 1200C Montauk (SOLD)
03 Piaggio X9 Amalfi(SOLD)
ricochet screwed with this post 10-03-2012 at 10:03 AM
ricochet is offline   Reply With Quote
Old 10-03-2012, 08:35 AM   #2624
TuonoBiker
Oddometer: 809
Great info - that adds good perspective. In this class of bike, I don't see shedding 10's of pounds to be a huge priority. I'm not saying I want it to gain weight either...we don't need a big pig bike...that's what my Harley is for.
I think the advancement in the engine and the suspension system are going to produce a very nimble, athletic ride from this bike. The current model is already nimble for what its designed to do: carry 1 or 2 people and luggage/gear across a wide range of road surfaces.
I still say if you want handling to the be the first and foremost selling point, you need to look at the Multistrada. I'll take my GSA over it any day for long-haul comfort, two-up capability, ability to handle all sorts of camping equipment, etc.
This bike has been well thought out and designed to be robust. I'm pretty sure that BMW has felt the competition to some extent and knew they couldn't just throw some spit polish at the current GS and call it good. Maybe I'm a Kool-aid drinker, I don't know.
Anxious for road reviews, though.
'12 R1200GS Adventure
'06 Ducati 999S
'11 Harley Street Glide - gone and mostly forgotten
'07 Tuono Factory - gone but not forgotten
TuonoBiker is offline   Reply With Quote
Old 10-03-2012, 08:36 AM   #2625
simoneau
Biker/Adventurer/Retiree
simoneau's Avatar
Oddometer: 203
Interesting note: No oil cooler that I can see. Not even finned oil pan. Water and oil must pass by each other internal to the engine plus the finning on the cylinders to the extent the oil is cooled. The transmission also becomes an extra heat sink/source.
Randy
2014 BMW R1200GSA (OLIVE)
Ride it like you stole it, care for it like you'll keep it, never let it cool down and it'll last forever!
simoneau is offline   Reply With Quote
Times are GMT -7.   It's 08:42 AM.
