10-04-2012, 07:52 AM
#2761 |
pass the catnip
Oddometer: 7,580
10-04-2012, 08:03 AM
#2762 | |
Breaking Wind
Oddometer: 8,436
Crusader of Slack |
10-04-2012, 08:05 AM
#2763 |
Breaking Wind
Oddometer: 8,436
So what, that's not unusual. Can you not clearly see the water flow in the illustration
Crusader of Slack |
#2764 |
Sure, why not?
Oddometer: 16,150
Do we know BMW's internal name, number, or other designator for this new engine? That might help to suggest a name we use.
2005 R12GS SOHC4 208 DoD 2032 BMWMOA BMWRA Proud walking jingle in the midnight sun. Smugmug Coupon: mStnWv71mNkjo Help preserve civil liberty; join the NRA: http://www.nrahq.org/nrabonus/ |
10-04-2012, 08:10 AM
#2765 |
Oddometer: 6,262
10-04-2012, 08:23 AM
#2766 |
Oddometer: 165
10-04-2012, 08:37 AM
#2767 | |
SUV hater
Oddometer: 941
![]() WHERE?? |
10-04-2012, 08:38 AM
#2768 |
Mod Squad
Oddometer: 53,466
The high beam is on the left cluster, at the front, you pull it in with your index finger to flash or push it out to keep it on. It's not visible in the picture, as it faces the front of the bike.
ADV decals, patches & flag? Here GB screwed with this post 10-04-2012 at 08:44 AM |
10-04-2012, 08:50 AM
#2769 |
Smile 4 Miles
Oddometer: 1,375
#2770 | |
Oddometer: 808
So while it may be true that there are more meshes in the new tranny than the old one, this factor doesn't necessarily guarantee increased fuel consumption. Factors that suggest better economy : no separate chain drive for balance shaft, gear driven rather than belt driven alternator, water cooling. |
10-04-2012, 09:01 AM
#2771 | |
Corporate slave
Oddometer: 1,558
![]() The electronic suspension on the 2010-2012 Duc is by Ohlins. For 2013, both BMW and Ducati have gone with Sachs to get their "semi-active" technology. And FWIW, the Sachs system does NOT have electronic pre-load, which was the source of the troubles with the Ohlins units (with the Ohlins, the pre-load servo fails, not the damping bits). -SM
aka NoVector Current: 2012 Moto Guzzi Stelvio NTX, 2008 Yamaha WR250R, 2010 Ducati Multistrada 1200 S Sport - FOR SALE - PM me since they keep deleting my Flea Market ad ![]() Gone: Moto Guzzi Norge, BMW R1200GS, BMW F650 GS Dakar, KTM 520 EXC, Suzuki DRZ400E, and the list goes on....... |
10-04-2012, 09:10 AM
#2772 | |
Corporate slave
Oddometer: 1,558
-sm
10-04-2012, 09:18 AM
#2773 | |
Corporate slave
Oddometer: 1,558
-SM
10-04-2012, 09:19 AM
#2774 |
Oddometer: 528
After looking at the pictures and let it all sink in I must say I like the looks of the new GS as the new engine is as good of a design for a motorcycle engine as it gets !
The 2 cylinder boxer was always a perfect motorcycle engine for everything but roadracing purposes with it's balance,low center of gravity,no crankshaft gyro to affect handling in a negative way,ease of maintenance and unique ability to protect bike and rider in case of mishap. Now they made the intake runners straighter to get more power and put the clutch where it doesn't cause expensive bills anymore if it needs to be replaced. No alternator belt anymore that can break or needs to be replaced. As for accessability it sits under a cover that should beeasy to access after the tank is taken off. As for the valve adjustment it looks like the cams have to come off because the followers don't slide to the side anymore like in the camheads.But even this should be easy as no timing chain has to come of with the gears driving the cams. Should be a great engine powering a 135hp/nm R1200RS in the near future... My guess is that a water-boxer R1200RT and R1200GS-ADV are next for 2014 out in autumn of 2013... |
10-04-2012, 09:34 AM
#2775 |
poser
Oddometer: 2,494
Sure there is. look at the diagram, water flows around the valves
As mentioned, Honda did this with the VFR, RC51 and superhawk. They had limited success (i've owned 2 VFRs), mainly due to them orienting the radiators sideways and the way the fan pulled air (causing no airflow to the radiator when moving while the fan was on). BMW had a similar setup on the K1200RS/GT, although they had 2 small fans (1 on each radiator). I think some of the KTMs run a similar setup to this (2 rads, 1 fan) and some people upgrade to a second fan.
Current: 2001 R1150GS 1981 CB650 Custom 2011 Golf TDI - New tow rig |
