Old 09-29-2012, 01:27 PM   #46
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,860
Did you incorporate an anti-crush sleeve in the drilled opening?
Hurricane Bob is offline   Reply With Quote
Old 09-30-2012, 11:14 PM   #47
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
I assume, you are talking about the hole drilled for the exhaust hangar. And the answer is no. How would you put an anti-crush sleeve on an existing piece of tubing that's welded closed on both ends?? I'm interested. But in this case, I don't know if it's needed. Seems to be pretty strong on it's own.
Minnesota North Shore Shindig 10-13 September 2015 -- Finland, MN
Proliferator of Farkles of Mass Percussion
jwalters is offline   Reply With Quote
Old 10-01-2012, 02:02 PM   #48
Hurricane Bob
Oddometer: 2,860
Ahh...your thinking it looks like this.....No.
Both the bolt and anti-crush sleeve go clear through the bike rack tubing wall....and any amount of tighting the muffler to the rack will be stopped by the sleeve.
I also assumed the rack tubing wall thickness could be thin for weight savings and add in the abuse dirt bikes hand out, an anti-crush sleeve seemed appropriate.
Hurricane Bob screwed with this post 10-01-2012 at 02:14 PM
Old 10-02-2012, 01:32 AM   #49
Sean-0
straya carnt
Sean-0's Avatar
Oddometer: 4,320
nice 1 bomber ....was looking for pics the help on this but you nailed it
def use a crush sleeve ..better job of it
Sean-0 is offline   Reply With Quote
Old 10-02-2012, 08:03 AM   #50
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
EDIT:
Gotcha! I like it! Thanks for the tip. I'm off to find some small diamater steel tubing, maby some brake line at the parts store.
PS. Yes, I was thinking of the first example you have above in PVC.
Old 10-04-2012, 01:11 PM   #51
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Progress progress. I installed the new right footpeg today. I had to drill out the front hole using the 7/16th drill bit. Never like drilling into an aluminum frame, but it was an easy job. 10 minutes later, I had a stronger footpeg. Job done!
Old 10-04-2012, 01:12 PM   #52
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Next on the docket was to install the new compression relief, clutch and push/pull throttle cables. These cables were ordered from Motion Pro with an extra 3 inches of length for my aftermarket triple tree and bar risers.
Job done!
Old 10-04-2012, 01:17 PM   #53
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
It might be considered sacrilege by some, but I've had a Cycra front fender thrown away by the factory Yamaha super moto team at Road America about 5 years ago. Absolutely no damage to it, other than some stressed plastic markets on the edge.
What do you think, can an XRR have a blue beak? I can already see the confusion on peoples faces....
Old 10-04-2012, 02:57 PM   #54
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
Cycra hand-guards installed! Unfortunately, the Yamaha front fender was not a good fit, I'd have to cut it up pretty good. I suppose I'll keep the stocker on for the time being.
I forgot to mention I replaced all the fluids yesterday and fired the bike up. I put the Acerbis tank on and ran the bike in the yard a bit. Fired up on the 3rd kick! Not bad for completely replacing the wiring!
Old 10-06-2012, 09:10 AM   #55
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
More progress today. I got the Baja Designs LaPaz 8inch light installed! This sucker rocks! I'm still figuring out what I want to do for the front fender....
I also had to spend some time sanding down the throttle tube, there were some sharp bits left over after I removed the end cap so I could install the Cycra handguards. The sharp bits were causing friction in my throttle, prohibiting the carb springs from returning back to idle once you let off the throttle. Rule #1 at any tech inspection. Anyways, a little finesse and sand paper and she's smooooooth....
Old 10-06-2012, 01:48 PM   #56
Cumbacheech
XRated
Cumbacheech's Avatar
Oddometer: 823
Looking good!! I put a CRF fender on my XRL and I really like it. I also have a KTM fender for my sumo setup, both fenders bolted up with no real big issues...
Cheers,
Cumbacheech
2001 XR650L - Done for now...!!
Pics: Adventure setup, SUMO setup, Dirt setup
Cumbacheech is offline   Reply With Quote
Old 10-06-2012, 03:22 PM   #57
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
That's great to hear because I just ordred one of these for a CRF450:
Thanks again for the input.
-jw
Cheers,
Cumbacheech
Old 10-06-2012, 03:31 PM   #58
jwalters OP
Farkle Proliferator
jwalters's Avatar
Oddometer: 2,271
I spent my Saturday morning feeding the hungry wood stove and installing my Baja Designs rear tail light while it snowed outside! I spliced up some ends to feed into my brake light switches both on my front and rear brake levers. Then I wired the running light up to the 12 volt source as well. All fused of course!
And with the completion of the rear taillight assembly, my wiring is done! I'm just waiting on some sprocket bolts, then I can install my new chain and sprockets, then finally sneak in a ride before winter decides to really hit. I'll still be installing a Trail Tech speedo which I've ran 12VDC to the front of the bike already, so that will be a quick install. I also have a skid plate ready to bolt on, but I'll wait till I'm done wrenching on the BRP.
Old 10-06-2012, 03:38 PM   #59
rpmwfo
Oddometer: 133
Job done!
Do you have the part #'s for the longer motion pro compression release and clutch cables? I re-routed mine, but it would be nice to have longer cables.
2007 XR650R Plated
2004 KX500 Plated
2007 KTM 450 EXC w/540 kit.
2003 ZX12R
2013 KTM RC8R
rpmwfo is offline   Reply With Quote
Old 10-06-2012, 03:41 PM   #60
Honkylicious
sup?
Honkylicious's Avatar
Oddometer: 1,202
Many a man fails as an original thinker simply because his memory is too good.
Honkylicious is offline   Reply With Quote
Times are GMT -7.   It's 02:21 PM.
