Old 10-04-2012, 08:30 AM   #69796
isaac004
isaac004's Avatar
Oddometer: 862
Thanks all for posting and verifying the correct orientation of the Intiminators. I did install them in the correct position, so I am still puzzled and confused on why my fork is making the sounds that it makes, and moves slowly.
I think at this point I just need to disassemble it again and inspect.
isaac004 is online now   Reply With Quote
Old 10-04-2012, 08:35 AM   #69797
planemanx15
planemanx15's Avatar
Oddometer: 1,009
I don t have a noise, but have the same issue with my forks. When I start to brake for a light, my forks move quickly through the first 2 inches, then slow. When I stop, they don't spring back until I start to throttle up and take off. Strange issue, not sure where to start so I'm just "observing" for now lol
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-04-2012, 08:44 AM   #69798
Mongle
Knuckle dragger
Mongle's Avatar
Oddometer: 3,272
Sounds to me like there isn't any preload on the spring. Maybe hearing it rattle inside? Which would also make the fork rebound slowly. Just a thought.
Mongle is online now   Reply With Quote
Old 10-04-2012, 09:16 AM   #69799
eakins
Butler Maps
eakins's Avatar
Oddometer: 19,395
Originally Posted by Escaped View Post
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 10-04-2012, 10:09 AM   #69800
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
Someone else was having problems with his Intiminator front suspension. When he took them apart he found the outer fiber/plastic? ring was distorted. I think it had expanded slightly and was sticking in the fork tube a bit. One fix was to file the ring ends a bit (just like on an engine piston ring). It seems RICOR was helping and working with him.
Several users have mentioned clicking when riding.
2004 DR650: 62,605 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is offline   Reply With Quote
Old 10-04-2012, 10:24 AM   #69801
deathu
deathu's Avatar
Oddometer: 77
Originally Posted by Adv Grifter View Post
As noted in above post. In A&P school we learned to do criss cross or star patterns on most assemblies, and doing 3 stages of tightening to ensure
even pressure and alignment. No idea if Suzuki provide more detail on this. I've never seen any specifics ... just following standard practices.
One thing to add: Once everything is loose ... make certain motor is fully seated correctly and not hung up anywhere. Basically, just wiggle it around a bit and look at motor mounts to see if all looks OK. Then tighten back up. Look specifically for cracked mounts, bolts or frame bosses.
The more I read, more I feel its a counter balancer issue. But just a guess.
Well, I did re-torque the motor mounts and I must say that there definitely is some improvement. Do not get me wrong, it is still nowhere nearly as smooth as my buddy's DR, but some improvement exists. At least now it seems OK-ish at 70km/h in 3rd and 90km/h in 4th gear, previously it wasn't.
It seems that the engine mounts were tightened to well over 100Nm. At least they required over 100Nm to break loose. I re-tightened them in criss cross pattern to the specified torque of 65Nm.
deathu is offline   Reply With Quote
Old 10-04-2012, 10:37 AM   #69802
procycle
procycle's Avatar
Oddometer: 2,455
I don't know if this was mentioned but sometimes it helps to tighten up the motor mounts with the motor at full operating temperature.
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde
www.procycle.us - Everything for your DR650 and lots of other great stuff!
DR900 Big Bore Stroker buildup
TurboDiesel Corvette - go to the end to start at the beginning
procycle is offline   Reply With Quote
Old 10-04-2012, 10:37 AM   #69803
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 9,727
Did you also check the head-stay bolts?
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-04-2012, 10:49 AM   #69804
deathu
deathu's Avatar
Oddometer: 77
Thanks, I will try that as well.
Definitely not, but it is not clear to me exactly to which bolts are you referring. Are you referring to the bolts that hold the small engine support "plates" to the frame? If I recall correctly 3 engine mounts hold directly to the frame and 2 to some adapter plates.
Old 10-04-2012, 11:15 AM   #69805
procycle
procycle's Avatar
Oddometer: 2,455
3 bolts under the tank. Connect the top of the motor to the frame with 2 triangular plates. These would be the most important ones for transmitting vibrations.
Old 10-04-2012, 11:25 AM   #69806
Rusty Rocket
Life behind "Bars"
Oddometer: 9,727
part # 29 is the bolt through the head
http://www.ronayers.com/Fiche/TypeID.../CYLINDER_HEAD
and the plates shown here as #5:
http://www.ronayers.com/Fiche/TypeID..._MODEL_T_V_W_X
2009 DR650
Old 10-04-2012, 02:33 PM   #69807
isaac004
isaac004's Avatar
Oddometer: 862
THIS! This is exactly the weird thing I think I am chasing down.
I just got off the phone with Ricor and explained my problem, and what they told me was the first round of Ricor's (mine were probably installed by the original owner around 2007-2009) had a slight issue with the seal ring being slightly too large. This is also exasperated by the fact that once it soaks and swells slightly from the fork oil, it becomes even bigger (Pro Tip: Belray sends to cause more swelling, even in regular fork seals). This makes sense with what I saw last year when I "rebuilt" the forks with new oil and new seals....it took a bit of force to get the Intiminator's out, as in I had to turn the fork leg upside down and compress it until the Intiminator shot out with force into my plastic oil collection pan. Likewise during installation, I simply could not just "drop them in"...I had to use the fork spring to help them slide in the fork.
So the guy from Ricor confirmed that I will need to trim down this seal ring. I just pop it off the Intiminator like a piston ring, remove some material either by filing or cutting with diagonal cutters, and reinstall. Once that ring is back on the body of the Intiminator, it should drop right down the fork tube with no resistance. Ricor confirmed that it is OK if it's slightly loose, the effects are not very noticeable.
Hopefully I will get to this in the next half week or so...I will post my results. Thanks everyone for contributing ideas and thoughts.
ER70S-2, thanks for mentioning this crucial bit of info!
planemanx15, this may fix your problem!
isaac004 screwed with this post 10-04-2012 at 09:44 PM
Old 10-04-2012, 03:29 PM   #69808
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,147
Quite often, the sealing ring is a little too large for a fork leg.
The internals of the fork legs are not completely true and the tighter tolerances of the sealing ring can cause problems.
Try swapping the Intiminators around and see if they still make the noise.
They should slide down the fork tube with the weight of the spring and only a tiny bit of pushing.
Trim a couple of mm off one end of the rings and you'll be sweet.
When I was looking for some for my TT350, Ricor wouldn't just supply some for 41mm forks as the internal measurements (wall thickness) is different with different forks.
They wanted the internal measurement down to the 1/10th of a mm.
NordieBoy is offline   Reply With Quote
Old 10-04-2012, 03:31 PM   #69809
ER70S-2
ER70S-2's Avatar
Oddometer: 7,225
Cool2
I love it when a Wild A$$ Guess makes me look good.
Now I wonder if the clicking is an audible signal that the Intiminator ring is swelling and starting to stick?
Eakins, I hadn't read your Intiminator thread for awhile and had forgotten how well it was explained and photo'd.
2013 WR250R
Old 10-04-2012, 03:50 PM   #69810
disconnected
rider
disconnected's Avatar
Oddometer: 7,453
Hi Gang, I used the Search function and found some tid-bits. My DR has the stock tires still and they are pretty warn out. I am looking for some 50/50 tires, what rides well with the DR? I am considering the TKC and Maybe the Kenda Big Block. What type of miles do you guys get from these and what else do you suggest. Mainly for dirt roads, paved commuting and maybe some light singletrack.
greg
IBA # 47004
disconnected is online now   Reply With Quote
Times are GMT -7.   It's 06:53 PM.
