10-04-2012, 09:16 AM
#69961 | |
Butler Maps
Oddometer: 14,425
Butler Maps - motorcycle maps for riders by riders - Ozarks , Nor Cal , COBDR shipping, AZBDR scouting http://www.advrider.com/forums/showthread.php?t=598717 Facebook: http://www.facebook.com/butlermaps |
10-04-2012, 10:09 AM
#69962 | |
Oddometer: 2,538
![]() Several users have mentioned clicking when riding. |
10-04-2012, 10:24 AM
#69963 | |
Oddometer: 73
Well, I did re-torque the motor mounts and I must say that there definitely is some improvement. Do not get me wrong, it is still nowhere nearly as smooth as my buddy's DR, but some improvement exists. At least now it seems OK-ish at 70km/h in 3rd and 90km/h in 4th gear, previously it wasn't. It seems that the engine mounts were tightened to well over 100Nm. At least they required over 100Nm to break loose. I re-tightened them in criss cross pattern to the specified torque of 65Nm. |
10-04-2012, 10:37 AM
#69964 | |
Oddometer: 1,597
Clarke's second law of Egodynamics: "For every expert, there is an equal and opposite expert." - Jasper Fforde www.procycle.us - Everything for your DR650 and lots of other great stuff! DR900 Big Bore Stroker buildup |
#69965 |
Life behind "Bars"
Oddometer: 6,242
Did you also check the head-stay bolts?
1996 DR 650 (a big girl that likes it dirty) 1973 Penton Six-Days (mint) 1971 Suzuki TS185 (needs restoration) 2005 KTM 400exc w/ BajaDesigns D/S light kit |
10-04-2012, 10:49 AM
#69966 | |
Oddometer: 73
Definitely not, but it is not clear to me exactly to which bolts are you referring. Are you referring to the bolts that hold the small engine support "plates" to the frame? If I recall correctly 3 engine mounts hold directly to the frame and 2 to some adapter plates. |
10-04-2012, 11:15 AM
#69967 |
Oddometer: 1,597
3 bolts under the tank. Connect the top of the motor to the frame with 2 triangular plates. These would be the most important ones for transmitting vibrations.
10-04-2012, 11:25 AM
#69968 | |
Life behind "Bars"
Oddometer: 6,242
part # 29 is the bolt through the head http://www.ronayers.com/Fiche/TypeID.../CYLINDER_HEAD and the plates shown here as #5: http://www.ronayers.com/Fiche/TypeID..._MODEL_T_V_W_X
10-04-2012, 02:33 PM
#69969 | |
Oddometer: 402
![]() I just got off the phone with Ricor and explained my problem, and what they told me was the first round of Ricor's (mine were probably installed by the original owner around 2007-2009) had a slight issue with the seal ring being slightly too large. This is also exasperated by the fact that once it soaks and swells slightly from the fork oil, it becomes even bigger (Pro Tip: Belray sends to cause more swelling, even in regular fork seals). This makes sense with what I saw last year when I "rebuilt" the forks with new oil and new seals....it took a bit of force to get the Intiminator's out, as in I had to turn the fork leg upside down and compress it until the Intiminator shot out with force into my plastic oil collection pan. Likewise during installation, I simply could not just "drop them in"...I had to use the fork spring to help them slide in the fork. So the guy from Ricor confirmed that I will need to trim down this seal ring. I just pop it off the Intiminator like a piston ring, remove some material either by filing or cutting with diagonal cutters, and reinstall. Once that ring is back on the body of the Intiminator, it should drop right down the fork tube with no resistance. Ricor confirmed that it is OK if it's slightly loose, the effects are not very noticeable. Hopefully I will get to this in the next half week or so...I will post my results. Thanks everyone for contributing ideas and thoughts. ER70S-2, thanks for mentioning this crucial bit of info! planemanx15, this may fix your problem!
A Father and Son Trip Down the Great Divide: http://www.advrider.com/forums/showthread.php?t=606301 A Father and Son Trip Through Death Valley: http://www.advrider.com/forums/showthread.php?t=869090 BMW F800GS, Yamaha WR250R, Suzuki DR650 isaac004 screwed with this post 10-04-2012 at 09:44 PM |
10-04-2012, 03:29 PM
#69970 | |
Armature speller
Oddometer: 6,763
The internals of the fork legs are not completely true and the tighter tolerances of the sealing ring can cause problems. Try swapping the Intiminators around and see if they still make the noise. They should slide down the fork tube with the weight of the spring and only a tiny bit of pushing. Trim a couple of mm off one end of the rings and you'll be sweet. When I was looking for some for my TT350, Ricor wouldn't just supply some for 41mm forks as the internal measurements (wall thickness) is different with different forks. They wanted the internal measurement down to the 1/10th of a mm. |
10-04-2012, 03:31 PM
#69971 | ||
Oddometer: 2,538
Now I wonder if the clicking is an audible signal that the Intiminator ring is swelling and starting to stick? ![]() Eakins, I hadn't read your Intiminator thread for awhile and had forgotten how well it was explained and photo'd. Quote:
10-04-2012, 03:50 PM
#69972 |
ultra runner
Oddometer: 5,857
Hi Gang, I used the Search function and found some tid-bits. My DR has the stock tires still and they are pretty warn out. I am looking for some 50/50 tires, what rides well with the DR? I am considering the TKC and Maybe the Kenda Big Block. What type of miles do you guys get from these and what else do you suggest. Mainly for dirt roads, paved commuting and maybe some light singletrack.
greg
10-04-2012, 03:52 PM
#69973 | |
ADV in training
Oddometer: 610
_________________________ Ride videos '01 DR650 "The impossible often has a kind of integrity which the merely improbable lacks." |
10-04-2012, 04:05 PM
#69974 |
ultra runner
Oddometer: 5,857
Great, Thanks, I was going to look up the T63, since the search function found those in my previous search!. :)
greg
10-04-2012, 05:34 PM
#69975 |
Oddometer: 792
T63 is pretty awesome for the offroad bits, but they wear quickly, cup, and run hot on pavement. They are my tire of choice for the KLR, but it doesn't see much dry pavement.
If you aren't playing in the mud, I'd look at the Shinko 705 and Full Bore Adv tires. Smoother on the pavement, enough tread for everything else, and better wear. If it helps, I've run BT003s in the conditions you listed on my 'tarded DR, the muddy sections were, ummm, fun(?), but otherwise, they offered a tolerable level of traction offroad. |
