Old 10-04-2012, 03:28 PM   #1
jrsride2002 OP
jrsride2002's Avatar
Oddometer: 82
Bluhduh SOLVED: XR650L Not starting, no cranking
OK, so I took a trail ride up in Yosemite. Woke up, rode for about 45 mins, I crashed. Brushed myself off, picked up the bike, fired up and continued on. I rode for about another 10 minutes when I stopped to verify if I was on the correct trail, via a map. I was, I hop on the bike, nothing. No cranking, no clicking from the relay(which I never heard before, but read about it). Bump started the bike, and everything was back to normal.
I stop again for lunch. Eat, finish, jump on the bike, NOTHING Bumb started again, bailed out to camp, no stops, just made it to camp.
Now im home, working on it....... Working on it.......................Working on it........
I pulled the seat, checked to wire to the start for breaks/cuts. Its good, a little wornout but shouldn't effect it yet. All the fuses are in good shape. Took a hammer and tapped the starter. The turn sigs work just fine in the garage. Headlights(aftermarket) no issues. My grounds look good. Bypassed safeties years ago.
WHAT COULD IT BE?!?!?!
Im at a total loss, please help, thanks,
~Junior
'02 XR650L: Accerbis tank, motor mods, suspension mods, electronics mods
'02 DR650: Yamaha Raptor 660 petcock, everything else stock
jrsride2002 screwed with this post 10-05-2012 at 05:08 AM Reason: Solved
jrsride2002 is offline   Reply With Quote
Old 10-04-2012, 03:41 PM   #2
mcma111
mcma111's Avatar
Oddometer: 12,593
Sounds like the right handle bar switch assembly.
Steve in SF
BMW's
58 R26
79 R100s
91 R100gs
Old 10-04-2012, 04:18 PM   #3
jrsride2002 OP
Oddometer: 82
I tested with a completely new/separate starter switch setup(I have a spare)
~Junior
Old 10-04-2012, 04:21 PM   #4
smokeeater495
smokeeater495's Avatar
Oddometer: 605
Kick stand switch?
Harley, been there done that. Don't want to be a pirate.
smokeeater495 is offline   Reply With Quote
Old 10-04-2012, 04:24 PM   #5
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
I had this happen to me. For me it was a relay located in the head light fairing/ shroud. I don't know what its called but take off the shroud and fallow the wires from starter switch down to where it meets the harness. It will be sitting around that spot. Its black it looks like a relay/sensor. I bet you it has a crack in it or a wire pulled out of it. Ben
Ben99r1 is offline   Reply With Quote
Old 10-04-2012, 05:20 PM   #6
AZ TOM
Oddometer: 4,079
Battery almost gone??
AZ TOM is offline   Reply With Quote
Old 10-04-2012, 06:02 PM   #7
Wattner
Wattner's Avatar
Oddometer: 5,450
Ground wire under the seat on top of the air box?
Wattner is online now   Reply With Quote
Old 10-04-2012, 06:24 PM   #8
Hurricane Bob
formerly: Bomber1965
Hurricane Bob's Avatar
Oddometer: 2,944
~Junior
recheck them, they may have corroded or come loose.
Hurricane Bob is offline   Reply With Quote
Old 10-04-2012, 10:32 PM   #9
jrsride2002 OP
Oddometer: 82
Do you mean the turn signal relay? Or the diode?? The turn sig(stock) was the larger black one with two spade connectors. The diode is buried in a black boot with the turn signal connectors and cluster connectors and is noticeably smaller then the turn sig relay. Diode has never been fiddled around with.
Fresh and new. Not even half a season on it. Bought it in May-ish....
Though I doubt it, I havent confirmed just cause EVERYTHING else works just perfectly. So the sigs are grounded and the batt is grounded. Plus whatever else that ground right their.
....................................... ..... Yer on............
Called my Uncle, said he'd be here tomorrow with his fluke. He's an electrician by trade, so I will also love to hear what he has to say.....
Thanks dudes for reading and helping!!!!!!
~Junior
Old 10-05-2012, 05:17 AM   #10
jrsride2002 OP
Oddometer: 82
Bluhduh Ok! I solved it!!!
Im an ass...... Really... Im just going to hang my head in shame... Such an idiot.....
OK so I honestly couldn't sleep over this issue. So here I was at 3:30am, chasing my wiring harness for loose connections, pinched wires, and checking my safeties..... After in depth review of the switch. They're 3 wires coming from it:
1.) To the relay in the battery box
2.) To the headlight High/Low beam switch
3.) To the headlight fuse
Turns out it was the headlight fuse.......I would have NEVER thought the starter button was based on the headlight fuse, seriously.... Here I knew I didn't know everything about this bike. But that to me is not 2+2=4.... Something else in my opinion...
Thanks for all the input guys!!!!
~Junior
P.S. How do I change the posting title to Solved??? I thought by editing the first post it would have done it, but no. I wrong again.....
Old 10-05-2012, 01:10 PM   #11
Ben99r1
Ben99r1's Avatar
Oddometer: 3,081
HUH.. I would of not figured that either. Congrats on figuring it out.
Old 10-05-2012, 02:27 PM   #12
XR650L_Dave
Oddometer: 3,761
The schematic tells all
---->>Thanks for the rotor, guys!<<----
XR650L_Dave is offline   Reply With Quote
Old 10-05-2012, 02:50 PM   #13
Hurricane Bob
Oddometer: 2,944
All the fuses are in good shape....... Headlights(aftermarket) no issues.
Put Down the Wrenches and Step Away from the Keyboard!!
Old 10-05-2012, 03:08 PM   #14
High Country Herb
Adventure Connoiseur
High Country Herb's Avatar
Oddometer: 9,321
...I honestly couldn't sleep over this issue...So here I was at 3:30am, chasing my wiring harness for loose connections...
True dedicated adventurer...
High Country Herb is offline   Reply With Quote
Old 10-05-2012, 07:57 PM   #15
jrsride2002 OP
Oddometer: 82
I have the Baja Designs dual Fuego lights, which have their own fuse direct to the batt... Should've pointed that out.... oops
~Junior
Times are GMT -7.   It's 08:07 PM.
