Old 05-24-2012, 03:13 PM   #16
crashmaster
ow, my balls!
crashmaster's Avatar
Oddometer: 5,298
Originally Posted by Cyclops Motorsports View Post
I did cartwheel the bike at 60 or so. I don't remember it being near this bad before.
I would start tearing it apart to have a better look. Man that had to hurt.
Riding the Americas: No Fumar Español
_____________________________________________
crashmaster is offline   Reply With Quote
Old 05-24-2012, 03:36 PM   #17
bigdave-gs
Explorer
bigdave-gs's Avatar
Oddometer: 2,621
Originally Posted by kirb View Post
Filling the bars with lead shot made a slight change in amplitude, but the vibes are still there.
Don't fill the bars all the way with lead shot, just get some flat lead plumbers tape, roll up a 3" long taper and hammer it into the bar ends, put your grips back on and ride. Acts just like bar end weights.
I'd be unstoppable if not for Law Enforcement and Physics !
When your 6'8" with a 40" inseam, the bikes that fit you are limited ! ! !
2004 BMW R1150GS Adventure for street work / KTM 950 Super Enduro for Dirt work !
bigdave-gs is offline   Reply With Quote
Old 10-04-2012, 10:04 AM   #18
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
Originally Posted by Uller View Post
I believe that they are very similar (if not exactly like) the Vibranators you mentioned however, these (http://www.highwaydirtbikes.com/HDB_...f=Th_insert_av) are what I use on the 690 to keep the handle bar vibes down. The come with a guide and the tap for an easy install. As an added bonus, you really get to crank down the hand guards so they won't move in an off.
Just be forewarned, the tap guide needs to go over the handle bar a ways to work correctly so you will need to take off your old grips to install properly. You might be able to "roll back" the edge of the grip but it would be a pain IMO.
PM sent
modeselector is offline   Reply With Quote
Old 10-04-2012, 01:00 PM   #19
rburkat
rburkat's Avatar
Oddometer: 293
I just was looking at these today. Have not tried them but apparently its "The best kept secret in the pro pits"
http://www.fasstco.com/shop/anti-vibration-inserts
rburkat is offline   Reply With Quote
Old 10-04-2012, 02:03 PM   #20
Uller
Uller's Avatar
Oddometer: 1,689
Originally Posted by modeselector View Post
PM sent
And replied to.....
rburkat, take a look at the HDB set in my link above. They thread into the bars making the most secure barkbuster mount one could imagine. I would bet that your handlebars would break before the barkbuster gets moved in an off.
If anyone can't tell, I hate it when a simple fall results in needing to break out the tools to rearrange your handlebars because the barkbuster rotated.
Uller is online now   Reply With Quote
Old 10-04-2012, 04:28 PM   #21
mountain eagle
terrorist
mountain eagle's Avatar
Oddometer: 2,926
+1 for the HDB inserts as I said on the similar thread in thumpers....
I've had a little wear and tear over the years and sometimes the vibes on the 610 and the 950 would get to me. I added the Highway Dirtbikes anti-vibe insert and found that it made a difference, and of course still allows for the HDB guards
mountain eagle
08'Husky TE610 x 2 TE/SM
KTM 950SE
my smugmug gallery
How can it be fun if there's not at least an outside chance of dying?
mountain eagle is offline   Reply With Quote
Old 10-04-2012, 06:02 PM   #22
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,030
Laugh Bzzz...
try Cycra Pro-Bend barkbusters, or tighten your old ones...
my bike has fallen down more than Chevy Chase in nasty mountain action on my Cycra's and they haven't budged a millimeter- nevermind an inch!
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-04-2012, 06:16 PM   #23
Uller
Uller's Avatar
Oddometer: 1,689
I do have them......They rock! (except for the wedge style bar insert)
It was the cheap, aluminum inserts that would pull out or twist. I've slightly flared the end of a set of bars because of it. The aluminum of the insert was crushed and the bolt put all the pressure on one point inside the bar.
I now only use the threaded inserts by BRP: http://www.brpmoto.com/index.php?pag...mart&Itemid=49
or the threaded anti-vibe inserts as mentioned above.
All problems solved.
Old 10-04-2012, 06:52 PM   #24
Off Road Ryder OP
Off Road Ryder's Avatar
Oddometer: 2,738
I determined I was just a wimp.The answer is to just ride more, throttle seams to cure most everything. I also think there also might be a direct relation to how much alcohol was consumed the night before
When Quality matters,Its all about choices.
Cyclops Performance LED Vendors thread
http://advrider.com/forums/showthread.php?t=839163
www.cyclopsadventuresports.com
1-800-624-0278
Off Road Ryder is offline   Reply With Quote
Times are GMT -7.   It's 03:13 PM.
