Old 10-04-2012, 09:09 PM   #1
bens109 OP
Oddometer: 47
Can an unbalanced wheel blow the shock?
I recently picked up a second hand BMW G60X-Challenge with a brand new Hagon coil shock installed (the bike previously had an Ohlins but the guy I bought it off wanted to hang on to it). Since then I have put less than 30Km on the bike before the shock blew - leaking oil and no dampening.
As the shock was new I rang up the Hagon distributer about having the shock repaired under warranty. The Hagon rep has asked me to send the unit to him to be inspected but also told me that the most likely cause was running a unbalanced rear wheel which may not be covered under warranty. The only time I've ever seen a rear shock blow has been under extreme riding or on a vintage bike so this all seems a bit strange to me.
Has anyone here ever had a similar situation?
bens109 screwed with this post 10-04-2012 at 09:10 PM Reason: Can't Spell
bens109 is offline   Reply With Quote
Old 10-04-2012, 09:42 PM   #2
whisperquiet
whisperquiet's Avatar
Location: 62298 in lovely corrupt/bankrupt Southern Illinois
Oddometer: 937
I guess anything is possible, but sounds like BS to me. A sizeable number of people probably never ever balance the rear tire/wheel on their dual dsport/dirt bike and don't have shock leakage. I've been riding over 41 years and have never experienced a blown shock.............and not always easy on the bikes when ridden.
whisperquiet is online now   Reply With Quote
Old 10-04-2012, 10:04 PM   #3
JimVonBaden
"Cool" Aid!
JimVonBaden's Avatar
Oddometer: 52,234
BS. No way that will cause a shock to blow without the wheel being so unbalanced that the bike nearly rattled itself apart!
Jim
JimVonBaden screwed with this post 10-04-2012 at 10:14 PM
Old 10-04-2012, 11:47 PM   #4
beemerkid
Do you ADV
Oddometer: 930
No way, JVB is right. If wheel vibration was strong enough to blow the shock, you would KNOW it.
Originally Posted by Mr.Grumpy View Post
I swear to God that I will beat you senless with a Sanka can before I die.
beemerkid is offline   Reply With Quote
Old 10-05-2012, 06:29 AM   #5
anotherguy
anotherguy's Avatar
Oddometer: 6,207
Both my off road bikes run rim locks. Severely unbalanced condition. I am crowding 300 lbs. geared up and never blown a seal. Ask the gentleman how that works. I'm calling BS.
Old 10-05-2012, 06:42 AM   #6
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 11,220
Sigh. Where the fuck do reps come up with this horseshit? Warranties are so fucking useless because they damn manufacturer ALWAYS weasels out of repairing anything.
Sounds like your seller installed a botched shock or damaged it installing it. My guess it the shock shaft got nicked during the install (or already was) or the shock was misaligned during the install and tweaked the shaft.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Badasses might screw with another badass. Nobody screws with a nut job. -- Plaka
LuciferMutt is offline   Reply With Quote
Old 10-05-2012, 06:45 AM   #7
Twilight Error
Going nowhere slowly
Twilight Error's Avatar
Oddometer: 22,692
That explanation works *maybe* if you've got a square or triangular wheel, and I'm fairly certain you'd notice that condition.
No, the shock failure is likely a bad assembly job. If Hagon jerks you around, simply take your business elsewhere.
Twilight Error is offline   Reply With Quote
Old 10-11-2012, 12:56 PM   #8
Mangle
Oddometer: 42
So this rep is claiming that the minor vibration of an imbalanced wheel (must be minor if you didn't notice it) does more damage than the abuse of everyday riding, braking, rough roads, speed bumps, etc?
I call bull. Don't let him weasel out -- how is he going to claim the tire out 'out of balance?'
Mangle is offline   Reply With Quote
Old 10-14-2012, 05:56 PM   #9
SNAPGADGET
SNAPGADGET's Avatar
Oddometer: 151
BS...now I have heard it all. Make them PAY!!!
SNAPGADGET is offline   Reply With Quote
Old 10-14-2012, 07:06 PM   #10
baloneyskin daddy
bikaholic
Oddometer: 2,100
Better check the muffler bearings while you're at it.
baloneyskin daddy is offline   Reply With Quote
Old 10-14-2012, 07:46 PM   #11
Truckin_Thumper
low profile
Truckin_Thumper's Avatar
Oddometer: 28,873
Jim
I bet a Hawgley Furgeson could
Truckin_Thumper is offline   Reply With Quote
Old 10-15-2012, 08:03 AM   #12
buls4evr
No Marks....
buls4evr's Avatar
Oddometer: 2,318
Total nonsense. Likely a bad shock when it was installed and now oil is going past seal. OR.... You weigh a lot more than the original owner, the spring is way light and you just smashed the upper and lower units together so hard they are now distorted and ruined. It does not take long to destroy a shock with a way too soft spring!
buls4evr is offline   Reply With Quote
Old 10-15-2012, 09:06 AM   #13
H96669
A proud pragmatist.
H96669's Avatar
Oddometer: 4,611
A little Googleing.....brought me to some links where it looks like some had to wait for their Hagons, they were replacing the seals in all of them prior to shipping as they were blowing out in field tests.
Have tools, will travel!
Times are GMT -7.   It's 04:51 PM.
