Old 10-05-2012, 05:30 AM   #2776
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Originally Posted by max384 View Post
Thanks for a great product Sanjoh.
Thanks for testing em out Hope you get that bigger kickstand pad! I hate finding my bike on its side in the am, just doesn't get the day started on good note.
Originally Posted by tallguy-09 View Post
John: Some nice OEM LED's from BMW. If you were to sell a lens front with yours they could be considered street legal and would be super usefull also on the street.
Interesting, have you seen these in person?
Originally Posted by FYYFF View Post
Hi Sandjoh,
I sent you an e-mail. Can you please check.
Replied
Old 10-05-2012, 05:38 AM   #2777
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Originally Posted by DinX View Post
A quick question about the ST dimmer.
I plan on buying the 60's with the ST dimmer.
I have a Off/Lo/High handlebar switch.
I plan on wiring the dimmer to LO en wiring the HI (and maybe my high beam switch too) to the wire behind the dimmer. Will that work ?
And the ST dimmer, does it have a memory or not ? So if I switch to "Off", will it remember what state it was in? I plan on dimming the lights on 25% or something by default (on Lo setting) and not engaging some 100% strobe function after starting my bike again
The wiring will not work the way you have drawn. You need to add a relay that routes power around the dimmer, activated with the high beam.
The ST dimmer has a memory function, it will come on at the last setting, even if power is removed.
Old 10-05-2012, 07:55 AM   #2778
DinX
DinX's Avatar
Oddometer: 137
Thank you for the excellent support via mail
DinX is offline   Reply With Quote
Old 10-06-2012, 05:56 AM   #2779
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Thanks for your business! Let me know if you need any support for the install.
Old 10-08-2012, 02:37 PM   #2780
ShimrMoon
ShimrMoon's Avatar
Oddometer: 341
Another happy customer
Any chance of a pic or two of these lights from the cockpit? I'm thinking of mounting my 30" down low like this on my 2010 RT.
"I don't like repeat offenders, I like dead offenders.." Ted Nugent
13 BMW GTL, 10 BMW RT, 09 Suz Vstrom 650A,
02 BMW LTc, 92 BMW R100R (wish I still had it)
ShimrMoon is offline   Reply With Quote
Old 10-09-2012, 08:22 AM   #2781
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Don't have any cockpit pics. You can see beam pattern on the model 30 on the detailed tab on our webpage here.
Old 10-09-2012, 07:54 PM   #2782
porschepatrick912
Location: San Luis Obispohwait.....Fresno..how'd that happen
Oddometer: 42
Im very excited right now! I placed an order for a pair of the Black Model 44 off road floods and a round dimmer to mount on my 02' FZ1. Thanks for inmate rate on my order, ill do a write up with pics once I get them mounted.
There is no gain without risk.
porschepatrick912 is offline   Reply With Quote
Old 10-10-2012, 09:41 AM   #2783
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Let me know if you have any questions during the install.
Old 10-11-2012, 08:48 AM   #2784
michigan400
Oddometer: 90
Model 60 question
I see the M60 uses Cree led's. Are these at the same kelvin as the M30 spot and 44 flood? What is the K of each, all 5500k?
michigan400 is offline   Reply With Quote
Old 10-11-2012, 10:38 AM   #2785
cpayne5
Oddometer: 54
I have one of the flashlights. It is awesome. My wife and I went for a short, nighttime hike last night and used it. It worked great. I have a Fenix TK40 and I prefer the ADVMonster light. It is smaller (lighter) and brighter.
I just ordered 2 more.
cpayne5 is offline   Reply With Quote
Old 10-11-2012, 10:49 AM   #2786
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
The model 44 and 30 are 5000k
Thanks for your business! Glad to hear you are happy with the flashlight.
Old 10-11-2012, 05:22 PM   #2787
pfdskipper
Westside Trash
pfdskipper's Avatar
Oddometer: 1,045
Anxious to get an "in person" look at these lights John, ordered up a pair of the Model 60's this morning. Any Idea when I can expect to have them in my hands?
pfdskipper is offline   Reply With Quote
Old 10-12-2012, 01:50 PM   #2788
Bokrijder
Soyez sans que peur
Oddometer: 319
Based on Sanjoh's track record, check your post box.
Bokrijder
KTM525EXC
KLR650
Bokrijder is offline   Reply With Quote
Old 10-12-2012, 04:50 PM   #2789
sanjoh OP
Purveyor of Light
sanjoh's Avatar
Oddometer: 5,040
Should be right around the corner. You can check the tracking number received in your email.
Old 10-15-2012, 12:35 AM   #2790
NormanH
Oddometer: 4
Originally Posted by Goti View Post
I'm not sure I'm gonna install the on/off switch, it was just an idea to keep a clean install on the handlebar and having the chance of turning the lights off easily.
Like I said earlier in the thread - I installed them with the dimmer, and a switch to the "high beam bypass" lead rather than actually tying into the HBB. I'd intended to do the setup you described, but I haven't changed it out a month or so later. The dimmed setting, I have no good reason to ever turn off when the bike's on, and the brights setting is blinding. So having extra control on a switch for "I really want off-road/off-traffic lights" is very nice.
NormanH is offline   Reply With Quote
Times are GMT -7.   It's 12:45 PM.
