Old 10-05-2012, 06:40 AM   #16
Yossarian™
Deputy Cultural Attaché
Yossarian™'s Avatar
Oddometer: 9,657
Originally Posted by Dubl-A View Post
What connection type is your heated gear? Also, is the control unit specific to the gear?
I use a powerlet-to-coax adapter plugged into the power outlet on the left underseat side of the bike, going directly into the heated gear controller in a Warm-n-Safe jacket. The remote control unit (dual channel wireless heattroller) goes on top a RAM base that I quickly mount on one of the RAM balls I have on my handlebar clamp.
Old 10-05-2012, 11:18 AM   #17
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Originally Posted by crazyman View Post
Standard cockpit with the Garmin mounted on the left.
Nice HDR pic! What power controls do you have there?? Lamps/Grips? Details please
Dubl-A is offline   Reply With Quote
Old 10-05-2012, 11:22 AM   #18
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Got any pics?
Old 10-05-2012, 11:45 AM   #19
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,657
Got any pics?
I will see what I can work up for you this weekend.
Old 10-05-2012, 12:12 PM   #20
crazyman
Exiled to the swamp
crazyman's Avatar
Oddometer: 1,143
Triumph Aux Lights and Triumph Heated Grips - switches right next to the mirror mount. To the right of that is another light switch for the MotoLights I have mounted on the calipers in front. Then the Garmin mount.
'13 Triumph Trophy SE
Just keep ridin'
crazyman is offline   Reply With Quote
Old 10-06-2012, 11:52 AM   #21
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,657
Got any pics?
Here you go.
Montana on the left hand side, dual wireless heat controller on the center/right. I position it leftward of the RAM mount so that it's closer to my left hand.
Old 10-07-2012, 09:03 AM   #22
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
With the grips, are they directly wired or have a connector? if so What type?
Does anyone know if you can have numerous heated products operated by one controller. I'm wondering how they "daisy-chain" if any.
Old 10-07-2012, 09:05 AM   #23
Dubl-A OP
SuckerDucker
Dubl-A's Avatar
Oddometer: 1,808
Here you go.
Hey that's clean! How do you like the Montana screen while riding? Also, can you elaborate on the wireless setup?? Thanks for the info
Old 10-07-2012, 06:24 PM   #24
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,657
So far, I love the Montana. A true track-capable GPS that is readable in full sunlight. I usually run it at 80% brightness during the day and it's just about perfect. 50% at night gives me good readability without too much light output. I use the Garmin rugged mount and wire it to the front accessory socket for power.
As to the heated gear controller, here's the site that has a pretty good description of it:
http://www.warmnsafe.com/dual-remote...-heat-troller/
In essence, the receiver lives in the jacket in a little pocket designed especially for it. The controller is paired to the receiver and uses a CR2032 battery as its power source. It allows 0-100% control of two independent channels. I have run the two channels as jacket+gloves and pants+socks, or jacket+pants+socks and gloves separate. It all works great.
Old 10-07-2012, 08:10 PM   #25
TriTi
Oddometer: 66
I'm interested to know what you end up going with to mount your phone. I am thinking of mounting my HTC Evo 3d on my tiger 955i, I can't afford any of these crazy freaking expensive motorcycle GPS units.
TriTi is offline   Reply With Quote
Old 10-07-2012, 09:21 PM   #26
Yossarian™
Yossarian™'s Avatar
Oddometer: 9,657
The power connector will be problematic. It is not designed for the excessive amount of vibration that it will see on a bike.
Old 10-08-2012, 06:09 AM   #27
crazyman
Exiled to the swamp
crazyman's Avatar
Oddometer: 1,143
The Triumph Heated Grips and Auxiliary Lights are pre wired with connectors to the bike's wiring harness. I had them installed by my dealer / shop, but they aren't too difficult to do from what I've read.
I don't have much experience with heated gear / accessories being attached to one controller.
Just keep ridin'
Old 10-08-2012, 07:07 AM   #28
IL8APEX
Oddometer: 89
OEM Fog Switch
I keep looking at the cool LED illuminated Triumph switch for my heated grips and lamenting that I didn't also get the fog lights. I'm waiting to install a set of LED fogs and would like to hook it up to the OEM Triumph fog switch. Anyone tried this yet?
-Tom
IL8APEX is offline   Reply With Quote
Old 10-08-2012, 11:03 AM   #29
Rob Dirt
More or less in line
Rob Dirt's Avatar
Oddometer: 2,567
Yes. Not me, but I read where a guy bought the Triumph light switch & wiring to use with some other fog lights. It looks stock. He just looked up the part #s & got his dealer to order the parts.
Heart of Dixie
Rob Dirt is offline   Reply With Quote
Old 10-08-2012, 11:51 AM   #30
IL8APEX
Oddometer: 89
^^^ Eeeeeexcellent.
Parts ren't too bad: I already have the heated grips, so the switch, mount, and screws are less than $40.
-Tom
Times are GMT -7.   It's 05:45 PM.
