Old 09-30-2012, 03:02 AM   #31
flipflopdog
Oddometer: 39
Cool2 k75 rear wheel frustration..!!
Hi there Muddy3, I stumbled across your thread and hopefully you can enlighten me somewhat. I need to resolve the same issue that you have already done. Had my project bike for some time now but only started to look into the rear wheel issue earlier this year. Work is draining all my time at present but I need to push forward now. To keep the rear disc and drive from my k75 doner bike which rear wheel or hub will fit straight on with or without machining.?? I have read many many threads on this issue but it still leaves me spinning, which hub is on your bike..?? Could you also tell me what calliper and rotor were fitted by Woody etc..??
Thanks in advance, Mez/UK
flipflopdog is offline   Reply With Quote
Old 10-03-2012, 01:56 PM   #32
Itgetsnobetter
Oddometer: 10
Rear wheel woes.
Apologies for hijacking the thread on my first post, poor form I know
Hi Mez, .I am starting the same conversion, but its early days yet. I have gone for GS1150 rear wheel, looks a little wide and there could be problems with the caliper hitting the spokes. I will have a little play this weekend.
I also have some DRZ 400 front forks, and going to look at a K1100 paralever final drive set up tomorrow night, that is in a poor state.
I will start a thread on SAR, when I'm ready.
Mike
Itgetsnobetter is offline   Reply With Quote
Old 10-04-2012, 02:28 PM   #33
flipflopdog
Oddometer: 39
K75 rear wheel frustration..!!
Hi Mike, I've just bid on a 1150 rear wheel so fingers crossed...!!! I had an email back from Zach at woody's wheels and the 1150 wheel will fit with some machining etc... the 1150 disc, calliper and carrier has to be used also. The rim will have to be relaced and offset or the wheel itself spaced. Would be great to share a thread with you mate for comparisons etc etc... Keep me upto date ok..
Mez
Old 10-05-2012, 11:51 AM   #34
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 26,102
That bike looks really great! How are you liking the Shivers?
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 10-08-2012, 08:24 PM   #35
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 37
K75GS rear wheel
Sorry guys for the slow reply. I've been out of town shooting speed goats in Wyo. for the last week.
flipflopdog has it exactly correct...the parts are all 1150 with the wheel re-laced w/ offset.
The Shiver forks are fine although I've gone with KYB forks from a YZ450F reworked by RG3 for my next project. The new project is a fleebay/homebuilt version of a HPN boxer. Rolling chassis is done, need engine and 11 gallon HPN tank...photos to follow!
Muddy3 is offline   Reply With Quote
Old 10-08-2012, 08:25 PM   #36
Motorfiets
Motorfiets's Avatar
Location: North of Jack Daniel's, South of Country Music
Oddometer: 2,997
Motorfiets is offline   Reply With Quote
Old 10-11-2012, 10:39 AM   #37
Muddy3 OP
Muddy
Muddy3's Avatar
Oddometer: 37
Here you go:
...and with the adapter to make the forks/triples fit.
Old 10-13-2012, 11:15 PM   #38
Throttlemeister
Oddometer: 3,760
Here you go:
www.throttlemeister.net
Throttlemeister is offline   Reply With Quote
Old 08-30-2013, 05:28 AM   #39
wildwestrider
Pack-Mule Hooligan
wildwestrider's Avatar
Oddometer: 273
Nice build!
Can you tell us what you did for a seat?
I looked at the Baja Designs Driving lights thinking I could do 1 for a more traditional look,.............but...........looks like these do not come in a dual filament HI/LO configuration. Wondering if that kind of a bulb/socket could be fitted?
Brian in Austin
"Where ignorance is bliss,..tis folly to be wise".
Thomas Gray
wildwestrider is offline   Reply With Quote
Old 09-01-2013, 08:06 AM   #40
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Originally Posted by wildwestrider View Post
I looked at the Baja Designs Driving lights thinking I could do 1 for a more traditional look, but looks like these do not come in a dual filament HI/LO configuration. Wondering if that kind of a bulb/socket could be fitted?
Yes, Boatman does a conversion ring. Here's the result.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 09-02-2013, 07:01 AM   #41
wildwestrider
Pack-Mule Hooligan
Oddometer: 273
And how about the seat. A modified OE saddle? or something you fabbed up. Thinking I see a tag on the left side,....possibly a Corbin tag?
Thomas Gray
wildwestrider screwed with this post 09-02-2013 at 07:06 AM
Old 09-02-2013, 07:11 AM   #42
wildwestrider
Pack-Mule Hooligan
Oddometer: 273
I know nothing about fork exchanges. Can you educate us a bit on what criteria you used for selecting a fork/wheel assembly,...........or.....can any dirt bike fork and wheel assembly be adapted? If so, how is a non-bolt on fork assembly modified to fit the K75?
Do you mod the new fork assembly triple clamp to fit the K75,....or somehow shim the new forks to fit the BMW triple clamp?? (assuming the new fork tubes are smaller in diameter).
Brian
Thomas Gray
Old 02-14-2014, 09:25 PM   #43
brick rider
brick rider's Avatar
Oddometer: 21
Adventure bike?????............ I don't need no freakin poncy adventure bike!!!!
brick rider is offline   Reply With Quote
Old 06-01-2014, 09:00 AM   #44
euromotorcycles
Oddometer: 168
North of the border
Here's one from Quebec , Canada.
2 configurations, two-up or Adventure with a modified 30 liter gas tank. It takes 45 minutes to do the switch over . Tank, seat, tail part & rack, bags are modular sections for quick on and off.
TWO-UP
euromotorcycles screwed with this post 06-01-2014 at 09:08 AM
euromotorcycles is offline   Reply With Quote
Old 06-01-2014, 09:05 AM   #45
euromotorcycles
Oddometer: 168
Adv 30l fuel tank
ADV configuration w/30l tank
Times are GMT -7.   It's 06:26 PM.
