10-05-2012, 11:32 AM
#61 | |
Duel
Oddometer: 2,197
Then you need to get out more.... http://swampscooters.net/wp/
10-05-2012, 12:19 PM
#62 |
Oddometer: 104
Now that I know your budget I would get a DRZ400S and adv farkle the crap out of it. If you put a scott dampner, small wind screen, racks, luggage, etc on there than you would have the best of both worlds. I wouldn't want to take a KLR on some of the trails I go on. Like others have posted if your doing a ton of road riding you already have the Ninja for that. Don't get so concerned with the slab that you choose a turd for the dirt.
10-05-2012, 12:39 PM
#63 |
Veteran n00b
Oddometer: 1,335
Sig line material right there
F800GS Grin Machine KTM690E Grrr Machine XR600R Oakey Mtn in the mud http://www.youtube.com/watch?v=bzoU2NpkaoA www.hoofrehab.com |
10-05-2012, 01:58 PM
#64 | |
Oddometer: 229
The KLR didn't feel topheavy because it didn't have any fuel in it.
-Robert 2010 Ural Patrol (mine) 2009 KLX250SF (hers) 2006 DR650 (???) |
10-05-2012, 02:21 PM
#65 |
Oddometer: 112
At 6'2" how are you having troubles with the height of the KLR? I'm 6' with a 34" inseam and am able to rest comfortable on the balls of my feet, darn near flat-footed.
If your requirements didn't involve so much highway or two-up I would recommend the DRZ400S. At right around 300lbs it isn't much of a challenge to throw around on a trail and won't throw out you back when you have to pick it up. The downside is that it is taller than the KLR by at least an inch. I've ridden a DR650 on and off road, and while it is better than the KLR on the trails it is no better than the DRZ400S on the highway, and the DRZ will easily outperform either the DR or the KLR when the pavement runs out. If I had to choose all over again I would still go with the KLR650 modified to be better for dirt riding. Any shock/fork work you would do to a KLR would still need to be done to a DR650.
2009 Kawasaki KLR 650 /// 2000 Suzuki DRZ400S |
10-05-2012, 02:47 PM
#66 | |
Southern Ontario
Oddometer: 1,990
I bet you are in the very small minority who thinks the DR-Z400 is as highway capable as the DR650. That said, it is a nuanced distinction. Leaning a little more dirt, def. prefer the DR-Z, a little more street, the DR. Both are cheap, reliable, and good tools for their niche. I think the DR650 is one of the best, all-rounders out there; if I could have only 1, it would make the short list along with the KTM690R. Fortunately, I have a street bike, so I downsized the DR650 to a WR250R. I wonder if the OP should consider the WRR too. Smaller than the others being discussed, but surprising, for 250cc |
10-05-2012, 03:26 PM
#67 | |||||||
Grumpy Young Man
Oddometer: 3,754
Some people can't handle a bike this size/weight on anything more technical than a gravel road. Some people can ride an R1200GS through mud and sand. Again, YMMV. Quote:
Kommando screwed with this post 10-06-2012 at 12:21 PM |
10-05-2012, 03:56 PM
#68 | |
Oddometer: 112
Perhaps I should clarify my second point. The gearing on the 650 is a bit better for highway, but the seat is still seemingly made of plywood. I wouldn't want to sit on the DR650 or DRZ400S for more than an hour going down the road, but even with the stock seat I can manage 2+ hours without too much discomfort on my KLR. Maybe a Gen1 KLR would be the best compromise? Still better road manners than a DR650, not as much plastic to break, more robust than the Gen2 KLR in the off road category, lighter weight, and still KLR simple.
10-05-2012, 04:23 PM
#69 |
Oddometer: 29
Installed the Sargent Low on the KLR....
.......and if I slide to the front I can damn near flat foot.....again, at 5'8" and 30" inseam. I just don't see the problem here.....but again, I haven't yet taken it off road.
10-05-2012, 04:40 PM
#70 | |||
Grumpy Young Man
Oddometer: 3,754
There are wide-ratio gearsets available for the DR-Z now as well. I've really enjoyed my DR650, as well as a few other peoples' DR650s , but if I can have a dirtier DR-Z with the same or better gearspread for dual duty, I'm likely adding one to the garage sooner or later.With a durable and lightweight 220-mile+ tank, and a comfy aftermarket seat (maybe a windscreen for some people too), long-distance travel capability is no longer an issue on a DR or a wide-ratio DR-Z. DIRT capability still is though, and there's already a streetbike in the stable, hence my lean towards the dirtier Zooks. |
10-05-2012, 04:42 PM
#71 |
Grumpy Young Man
Oddometer: 3,754
10-05-2012, 05:03 PM
#72 | ||
Oddometer: 112
![]() For the OP I still feel that the decision is between the DR650 or a Gen1 KLR650. Both are good bikes with enough aftermarket support to make them whatever you want them to be.
10-05-2012, 05:23 PM
#73 |
Oddometer: 54
Get a smaller dirt oriented ds bike.
If your goal is to travel a day, then ride trails for a couple of days...well, I'd rather have fun off-road and suffer a little to get there. Any 250/350 will travel highway speed for a day (it might be screaming, but it'll do it), then when it comes time to turn onto a trail...you have a manageable sized bike to throw around.
There are used bikes showing up all the time. Patience will pay off. I ride a KLX250, bought it to commute, but ride the snot out of it in the dirt. No matter how good a rider I become in the dirt, I will never try and muscle a KLR on a trail, it'll never be as fun as a little bike. Maybe the KLX650 but not a KLR. Almost bought a DR350 a couple of times. Good bikes. Fun on the trails is where you should be focusing your bike search. As someone else said - a 125 will get you there. CC's in the dirt are not as important to the fun factor as on the road. And bigger is definitely not better as a beginner in the dirt. I ride a 900 racebike on the street if I feel the need to go fast. My 250 goes plenty fast in the dirt. And is way too heavy after a long trail day with multiple dirt naps. My KLX650 will be interesting to try in the dirt(if I get it running before the snow). If it can have a kick start, you have a million used options. Cruise all the bike specific threads, look at the flea market. All of this is flavored with the belief that a KLR is not a DS bike, nor is any BMW. Round the world, while carrying the kitchen sink, you bet. Can you ride them like a DS, you bet. Singletrack, sure. Fun in the woods, not as much. And I know nothing about the DRZ, but that seems the best bet from your list. Weight on the trails is only a penalty when you drop it, not if, when. If I had to, I could haul my bike out of almost any situation I might get it into. A KLR, not w/o a winch. I look forward to being confident enough to take the 650 instead of the 250 onto singletrack, but will I? Only if I start hitting the weights. |
10-05-2012, 06:24 PM
#74 | |
Oddometer: 641
Each machine has its purpose......for me, when I'm in the dirt I want a dirt bike, when I'm strictly street I want a street bike. My ds does an awesome job of comfortably getting me to the dirt, then acts like a real dirt bike when I get there ![]() |
10-05-2012, 08:34 PM
#75 | |
Oddometer: 183
Trust your instincts. The KLR is exactly as you found it, huge and heavy. Be aware of anybody claiming the KLR is as good as a DR or DRZ off road . Its not. I owned and '08 KLR and traded up to a DR650. As a noob off road rider the DR650 and DRZ400 will be much more forgiving and 3 times as crash worthy. The DR and DRZ are also easier to work on than the 08+ KLR. Look at it this way. If you are looking at Hiway and gravel roads the KLR is fine. If you are planning on any offroad trails at all go DR650 or smaller. Maybe just look for a good used 250 dual purpose or DRZ400 and flog it for a year. You will know right away if you are an offroad guy or not. |
