Old 10-05-2012, 01:46 PM   #69826
Bronco638
Nobody Home
Bronco638's Avatar
Oddometer: 3,791
BergDonk (Steve) is making counter-shaft seal retainers. His first production run is complete and already spoken for. I would like one and if (at least) 5 others are interested, I'll be point man for another 6 units (or more).
I am not going to require any up-front money as long as your word is good. I have this posted in three different places. So, if you're interested, please send a PM to me. Common sense says to create a new "group buy" thread where I'll keep a running tally of who's in. Once we have (at least) 6, I'll place an order with Steve.
The price will be $40 for the retainer plus a portion of what it costs to get them from Oz to the US and then from me to you. I would imagine ~$50 each?
There are some simple thruths......and dogs know what they are - Joseph Duemer
Andy holds the lead. And he will, all the way to the Highway. Today is his day.
Bronco638 is offline   Reply With Quote
Old 10-05-2012, 05:14 PM   #69827
Lil' Steve
PussyWagon™ Chauffer
Lil' Steve's Avatar
Oddometer: 3,949
Originally Posted by NC Rick View Post
If anyone has a nice condition set of stock DR650 forks available, we would really like to have a set. Cash or trade for suspension work...
Rick
Cogent Dynamics Inc
(828) 628 9025
raceparts (at) motocd (dot) com
e-mail sent
Steve
13 PCX150, 07 KLX250S w/300 kit, 05 DR650SE, 01 FZ-1
99 VFR800 w/870 kit, 96 GPz1100, 87 CH250
Lil' Steve is offline   Reply With Quote
Old 10-05-2012, 05:33 PM   #69828
Rusty Rocket
Life behind "Bars"
Rusty Rocket's Avatar
Oddometer: 8,990
Originally Posted by vfr870 View Post
e-mail sent
I thought of you right away. New seat is the bomb. Did 110 miles with Viverid today You are the used parts guru.
on one side the sign it said "Private Road", but on the other side it didn't say nothin'
2009 DR650
..1972 Penton Six-Days ..1971 Suzuki TS185.. 2005 KTM 400exc
Member of: AMA, NETRA, Blue Ribbon Coalition, CCCofVT, Berkshire TR, CT Ramblers
Rusty Rocket is offline   Reply With Quote
Old 10-05-2012, 07:37 PM   #69829
Lil' Steve
Lil' Steve's Avatar
Oddometer: 3,949
I really should start getting rid of stuff. I've collected way too much over the years.
Nice day for a ride, hope you and Vince had fun.
Steve
Old 10-05-2012, 07:54 PM   #69830
FuzzyNugs
Oddometer: 78
Originally Posted by letskeepriding View Post
anyone used a Dirtracks.com rack & side crash bars ?
I just got mine in the mail tonight and they look very well made. Should be sturdy enough to withstand crashes and the finish is a glossy black. I'll be mounting them up in the morning with 720 seahorse cases and will post a pic tomorrow.
Did a quick bathroom scale check and the racks, crossbar, and mounting hardware come out to 8lbs even. Not terrible in my opinion.
FuzzyNugs is offline   Reply With Quote
Old 10-05-2012, 08:33 PM   #69831
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 9,469
Originally Posted by 805gregg View Post
Except put any weight on the XR and the subframe fails, and the 690, bad vibrations, and anyone like lots of and hard maintance? Get a DR and put a 790 kit it, it will blow the rest away.
Regarding the 690. Where did you get that from ? I own a DR and love it and my buddy owns a 690 that I ride from time to time. The fact is it vibrates no more or less then our DR's and maintenance is stupid simple. It's not the 950 adventure. I could buy a 690 tomorrow if I wished but I don't because the DR does it for me. Now if you said the DR was more reliable then I could agree with you. But the vibe and maintenance comments are just incorrect. keep it real eh ?
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
DockingPilot is offline   Reply With Quote
Old 10-05-2012, 09:01 PM   #69832
isaac004
isaac004's Avatar
Oddometer: 821
Originally Posted by isaac004 View Post
THIS! This is exactly the weird thing I think I am chasing down.
I just got off the phone with Ricor and explained my problem, and what they told me was the first round of Ricor's (mine were probably installed by the original owner around 2007-2009) had a slight issue with the seal ring being slightly too large. This is also exasperated by the fact that once it soaks and swells slightly from the fork oil, it becomes even bigger (Pro Tip: Belray sends to cause more swelling, even in regular fork seals). This makes sense with what I saw last year when I "rebuilt" the forks with new oil and new seals....it took a bit of force to get the Intiminator's out, as in I had to turn the fork leg upside down and compress it until the Intiminator shot out with force into my plastic oil collection pan. Likewise during installation, I simply could not just "drop them in"...I had to use the fork spring to help them slide in the fork.
So the guy from Ricor confirmed that I will need to trim down this seal ring. I just pop it off the Intiminator like a piston ring, remove some material either by filing or cutting with diagonal cutters, and reinstall. Once that ring is back on the body of the Intiminator, it should drop right down the fork tube with no resistance. Ricor confirmed that it is OK if it's slightly loose, the effects are not very noticeable.
Hopefully I will get to this in the next half week or so...I will post my results. Thanks everyone for contributing ideas and thoughts.
ER70S-2, thanks for mentioning this crucial bit of info!
planemanx15, this may fix your problem!
So yesterday I got around to making the modification described above. After draining some oil and pulling the spring out, I had to compress the fork while it was upside down in a oil pan, and slowly compress the fork to get the Intiminators out. Well not once but TWICE did I end up spraying oil all over the floor as it shot down with force into the oil pan. I should have built a little cardboard wall/fort around the pan so I did not have to spent half a hour wiping off of everything.
I removed about 1mm from each oil ring, and as I put everything back together it was MUCH easier to slide the Intiminators back in the forks. Now I had hopes. After finishing off the re-assembly with Maxima 5wt oil, I bolted everything back together. Time for the moment of truth...
..and no dice. It feels and sounds exactly the same as before.
Not sure what to do at this point. Might be a good time to upgrade to Gold Valves for slightly better off road performance!
isaac004 is offline   Reply With Quote
Old 10-05-2012, 09:49 PM   #69833
Paddle007
Oddometer: 312
Rick
Cogent Dynamics Inc
(828) 628 9025
Email sent
Paddle007 is offline   Reply With Quote
Old 10-05-2012, 10:01 PM   #69834
ER70S-2
ER70S-2's Avatar
Oddometer: 6,115
This takes me back many years. Short story: I had a 65 pound black standard poodle, he was my best bud (got me thru my divorce). One day I had to do an oil change and I used an 18" diameter open top drain pan with 4" sides. So I got the oil drained and wondered "Where do I put this where I won't trip over it?" Aha, I'll just slide it under the boat trailer tongue (in the garage). Bear was allowed to wander the house and yard thru his dog door. I went in to watch football. During half time, I went to check on him and wandered into the garage. There must have been 1000 dog prints on the concrete floor. How my best buddy managed to get both his front feet into that oil pan is beyond me. Spent an hour with toxic chemicals cleaning the garage floor. At least he didn't come in the house.
No, he did not get yelled at, nor blamed.
Crap. I was tempted to try the Intiminators, just 'cause. Now, not so much. I do like my emulators.
2004 DR650: 62,402 miles
2013 WR250R
SUZUKI DR650SE INFORMATION INDEX
Originally Posted by Threewheelbonnie View Post
"BTW, I don't do style. It's a dirt bike, not some girlie dress-up thing." -
ER70S-2 is online now   Reply With Quote
Old 10-05-2012, 10:10 PM   #69835
planemanx15
planemanx15's Avatar
Oddometer: 1,007
Probably not intimidators, I don't have them and I'm still having this issue.
2000 Suzuki DR650-790 - 790cc Big bore build thread
1985 Yamaha CA50 - The little scooter that Could
2009 Piaggio BV-250 - Escusi, Babba be bo-bee
planemanx15 is offline   Reply With Quote
Old 10-05-2012, 10:27 PM   #69836
ER70S-2
ER70S-2's Avatar
Oddometer: 6,115
Originally Posted by planemanx15 View Post
When I start to brake for a light, my forks move quickly through the first 2 inches, then slow. When I stop, they don't spring back until I start to throttle up and take off. Strange issue, not sure where to start so I'm just "observing" for now lol
Stock springs? If so, what do you weigh? I'm about 205 ready to ride (boots, coat, pants, etc). I shimmed my fork preload; started with 1/2", which was too much. So I tried 1/4", but it wasn't enough. I would have been happy at 3/8" but decided to go with Eibach .45 springs and RT emulators. Adding preload is free.
2013 WR250R
Old 10-05-2012, 11:01 PM   #69837
Feelers
Oddometer: 187
Did you fill the forks with fork oil to above the damping rods and cycle the shock several times before dropping in the intiminators and completing the filling?
Did you fill while the forks were fully compressed?
Are your caliper bolts tight?
Is your steering head nut torqued to spec?
If you are sure you installed everything right, I'd experiment with these suggestions:
First, open the caps , take out the spacers, put in new spaces 2x the length of the old ones, screw the caps on and try the bounce test.
If no difference, open the caps, and add some extra oil, screw the caps down and give it the bounce test.
If no difference, open the caps and remove the oil you just poured in and remove some additional oil - a turkey baster might work great if it's long enough. Give it the bounce test again.
Let us know the results.
Feelers is offline   Reply With Quote
Old 10-05-2012, 11:17 PM   #69838
ER70S-2
ER70S-2's Avatar
Oddometer: 6,115
Originally Posted by eakins View Post
What oil height have people settled on?
I was happy with the stock oil volume (19.1 oz). I believe that's 6.5". That was with .45 Eibach's + emulators. But when I installed Procycle's Magic, way more stronger 320mm rotor, the fork dive was almost as bad as the stock springs.
I've never been happy with having to measure fork oil height with the springs out; what a PITA. Clear back when I had my DT-1B air forks were being experimented with. It was one of the mods available to us back then (Fred Flintstone was my buddy). Maybe it was Dirt Bike magazine that did an article on completely removing the fork springs and using air to suspend the bike. It was an easy and cheap experiment; drill and tap the fork caps, install schrader(?) valves, add air. Even back then, I had to farkle (35 years before I ever heard the word farkle).
This is what I ended up with, it's over in the DR Index, but WTF; now it's here again.
Use a 1/8 NPT tap. Ignore the forks being slipped up in the triple, it's just an experiment.
Copied and pasted from the Index; Suspension / Chassis:
Then I use one of these with a zip tie loose enough to slide up-n-down. Now I can adjust my oil level without disassembly, which came in handy when I put a 320mm rotor on the front. The brake works so much better that the fork dive with .45 Eibachs, was too much for my liking. Stock oil level is 16-1/8" (forks fully extended, with springs and caps installed), I added 20ml and ended up at 14-7/8". That's 1 1/4" or 5/8" per 10ml. You don't even have to move your handi-bars, way better than removing the springs and collapsing the forks everytime you want to experiment with oil levels.
More info here: http://www.advrider.com/forums/showp...2&postcount=19
But in your case (Intiminators and heavier springs), fork dive isn't an issue. So none of this matters. If you aren't bottoming out frequently and you're ok with whatever fork dive, I'm thinking the stock 19.1oz (for accuracy) is good.
My turkey baster:
2013 WR250R
ER70S-2 screwed with this post 10-05-2012 at 11:25 PM
Old 10-06-2012, 01:27 AM   #69839
Rugby4life
Rugby4life's Avatar
Oddometer: 706
Come And Get It
OK folks, due to old age and old knees I'm selling my DR. I'm going to move it in the next couple of weeks to get something new so this is your last chance.
http://advrider.com/forums/showthread.php?t=822901
Thanks for looking.
"Before attempting to beat the odds, first determine if you can survive the odds beating you."
Rugby4life is offline   Reply With Quote
Old 10-06-2012, 02:56 AM   #69840
NordieBoy
Armature speller
NordieBoy's Avatar
Oddometer: 7,139
Did you add a spacer after removing the Intiminators?
DR650 Wiki
NordieBoy is offline   Reply With Quote
Times are GMT -7.   It's 09:25 PM.
