10-06-2012, 07:42 AM
#31 |
Oddometer: 488
What picture are you referring to? I have definitely seen some slap together mods that are functional but not aesthetically pleasing. I was tooling around on a trail about a month ago and was going slow enough that it didn't snap my front fender but the TKC picked up a rock and sucked it up, it left a good 1-2 cm gash all through the inside of the fender and I felt the bike slow down like I was hitting the brakes before I heard a slight pop and watched it spit out the rock about 15 ft in front of me. After that I was determined to complete the mod for my safety. Seeing as I usually only drive on the road to get off road it is highly beneficial for me. That and since I am running the TKCs I do not go over 80mph so I am not too worried about the wind issues from the modification.
"You got me started thinking again about the eliminating of the low fender, with the addition of the SM fender.... But every time I see someone doing this.... I'm scarred from one inmates picture of Gonzo.... ![]() .... It's terrible.... I'm scarred for life.... It is a fantastic solution, but I don't feel I am there yet...."
10-06-2012, 08:08 AM
#32 | |
Ridgerunner
Oddometer: 44
![]() But I think the difference in the way the two look (stock vs raised fender) is that the beak goes more or less straight out where the raised fender has that "hooked" look to it because it's curved not straight. I would guess that it's a matter of taste as to which one looks better.
Steve One out of four people is insane - check your three best friends - if they're normal then it must be you! SDDinNH screwed with this post 10-06-2012 at 08:19 AM |
10-06-2012, 01:04 PM
#33 | |
Oddometer: 2,773
Erling |
10-06-2012, 01:08 PM
#34 |
Oddometer: 2,773
I do offer my deepest apologies....as my earlier comment really was meant as a compliment, because of the fact that your setup got me thinking about this....again, as I dropped it last time,,,,because of,,,the ,,,ehhhhh.... Puppet thing....
I know better than to critique someone else taste.....and if you took it as such.....for that I am sorry. It is absolutely each own individuals taste..... nothing else.... I just shot my toe off.... by mentioning mine.
Erling |
10-07-2012, 07:02 AM
#35 |
Oddometer: 488
Didn't offend me haha and if you did I didn't notice. I cut down the "wedge" that may suffice for the snub nosed section. Will play with it on Friday!!!!!
I will also be working on the CF, I am curious after watching your videos/stalking everything you published about CF fabbing in regards to the vacuum method to remove bubbles from your resin etc... is this necessary? Also I have seen a video published by Polymer products regarding the use of acetone sprayed on the surface after it has set for a while to get a good bubble free piece. Besides the aesthetics should I be concerned about bubbles? Also would this be a good way to get a nice finish, I imagine this only works on completely flat surfaces to self level. http://www.youtube.com/watch?v=2PKn-59pHNM <--- Acetone at 6:28 |
10-07-2012, 08:13 AM
#36 | |
Oddometer: 2,773
Erling |
10-07-2012, 08:34 AM
#37 | |
Oddometer: 488
Ohhhhh this is going to be awesome, love learning new stuff. Just hope my garage trial and error schooling does not cost toooooo much haha! Also since I am using the Max Clear HP should I heat cure it a bit, I havent quite gotten to the big instruction booklet they sent with it yet. |
10-07-2012, 09:37 AM
#38 | |
Oddometer: 2,773
Erling |
10-07-2012, 09:49 AM
#39 | |
Oddometer: 488
Last pressing question I have, as far as the foam mold I am utilizing. Once I have it sanded down it is still fairly porous, do I still apply wax/parrafin to get it to release or should I first coat it with resin and let it cure then use that as the base for the mold before proceeding to the CF? Sorry for so many questions I just don't want to waste a lot of time or material learning simple things I could avoid. |
10-07-2012, 11:02 AM
#40 |
Insurgent Squirrel
Oddometer: 18
Awesome! Motorcycle rhinoplasty! So you're still in med school but you're already a "practicing" plastic surgeon!
10-07-2012, 11:36 AM
#41 | |
Oddometer: 2,773
... I do not use the wax anymore.... extra cost, and labor, not a necessity.... as it ensures better release of the uhhmmmm... release agent.... . If you are making a foam plug to make a high utilization mold,then yes coat with epoxy/sand, and repeat as necessary. If you are trashing the foam after use....Don't waste your time.....with the epoxy.
Erling |
10-07-2012, 11:48 AM
#43 | |
Oddometer: 488
10-07-2012, 11:55 AM
#44 |
Oddometer: 488
Thanks for the video, I already watched all of yours on youtube hahaha! If I come up with a design I REALLY like for the snub nose I may make a mold of it for anyone that chooses to go this route as opposed to making a whole new front cowling like you have suggested.
I picked up an awesome table sander like the one in your video via craigslist. If I was back in Missouri I would have access to way to many nifty tools. I am making a bunch of machined parts when I go on leave after next weekend such as spacers, and brackets for the bike. |
10-07-2012, 01:14 PM
#45 |
Insurgent Squirrel
Oddometer: 18
Another possibility might be to fab a piece that at least somewhat filled that space but that attached to the forks or fender and turned when you turn the bars. Maybe you already considered this and decided against it. Nice work. The Beemer's reduced shnoz has already given it a prettier face.
