Old 09-28-2012, 02:32 PM   #31
snowhawk jockey
Slack Jaw Gaper
snowhawk jockey's Avatar
Location: The other Center of the Universe: Bend, Oregon
Oddometer: 1,115
Originally Posted by PowerCell View Post
The stock frame only weighs 23lbs...
It gonna be difficult peeling the other 400lbs off to feel that stock frame's "agility".
snowhawk jockey is offline   Reply With Quote
Old 09-28-2012, 02:58 PM   #32
zooomgovroom
hooligan-esque
zooomgovroom's Avatar
Oddometer: 68
Ti weighs 2/3rds...
Nothing says "why is there a hole in the wall, and where did i hide my pants?" like a couple bottles of 20% bum wine. (referencing Wild Irish Rose, Nighttrain, Thunderbird, MD 20/20, etc.)
-12/19/07-zarn02 on the DML
zooomgovroom is offline   Reply With Quote
Old 09-28-2012, 06:00 PM   #33
AdventureDave
MMMMM Bundy!
AdventureDave's Avatar
Oddometer: 710
light battery
If you do want to go lighter battery, I would suggest you try Antigravity batteries
http://antigravitybatteries.com/
I have had one on my 625SXC for 18months and it is excellent. In the cold weather the starting warms the battery up so by 2nd or 3rd try they turn over normally. mine will start down to about 5 degrees C easily.
he is an inmate here as well. (usual disclaimer - no connection just happy customer yadayada)
David
AdventureDave is offline   Reply With Quote
Old 09-29-2012, 03:20 AM   #34
LukasM
Oddometer: 5,386
Here are the best cost/weight mods:
- LiFePo4 battery - even if you take a big one to properly crank the bike even in cold temps it it will still save lots of weight
- Single disc conversion - sell the unused parts and you can make even some money!
- Remove crash bars and fit carbon/kevlar tank protectors instead
- 2-into-1 exhaust with titanium muffler
- 1.6"x21" front wheel with A60 rim and 2.5"x18" rear wheel with DID Dirt Star rim from the SE (slightly stronger than stock Excel IMO), both fitted with Tubliss inserts (these are made for 2.15" rims but fit ok with a thick sidewall tire)
The above all make the bike better handling and more reliable for off road riding (battery is arguable, although the Anti Gravities have a very good track record).
Going beyond this is going to require some really fancy materials and PowerCell like fabrication skills, or big $$, or a trade-off in strength or functionality (removing stuff or replacing with lighter).
Old 09-29-2012, 11:10 AM   #35
Uller
Uller's Avatar
Oddometer: 1,672
Gas Caps
I've been following this one and haven't seen the gas caps mentioned yet.
I have recently painted my tanks and had the gas caps out. Holy shit, those things are heavy!!!!
If you replace them with the billet ones you will save over a pound up high on the bike.
http://www.ebay.com/itm/KTM-BLACK-CN...5cf4d4&vxp=mtr
They (SSR) also have these trick, new push button caps. (I haven't seen them before....)
http://www.ebay.com/itm/KTM-QUICK-RE...2f7c37&vxp=mtr
Uller is offline   Reply With Quote
Old 09-29-2012, 12:23 PM   #36
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,009
Talking
Have you ever had a set of those?
I put one on my Triumph Speed Triple and found it to be a pain in the butt. Unscrewing and screwing in was the first step, all the time putting tiny aluminum shavings in the tank as the threads we not perfect. Then you have to have a clean place to put the cap since its not attached. A strong enough wind will toss the cap off of the tank bag. Then of course you can't lock it up. If I did any touring, especially out side the country, I'd always be concerned someone may have stolen my fuel.
06 KTM 950 Adventure(The Fainting Goat)
02 KTM 520 EXC
04 KTM 351 EXC
Xtremjeepn is offline   Reply With Quote
Old 09-29-2012, 01:23 PM   #37
Uller
Uller's Avatar
Oddometer: 1,672
I do. Haven't ridden much with them. Filled gas through them a couple times though. (My head gasket went and I've been down a couple of months trying to buy parts/find time )
They rest in the slot on my handle bar clamp perfectly. I think they are easier than a key on either side.
I don't really road travel in other countries so, that one isn't really a concern of mine. (But, then again, I have completely removed my keyed ignition from my 690 so, maybe I'm not the person anyone should pay attention to when it comes to security )
I was looking at a relativley cheap, easy way to lighten the load once I felt how much the stock ones weighed.
I always back turn the caps to find the correct starting point and they screw on smoothly with no metal shavings.
However, the OP wanted weight savings for single track and other challenging conditions and this is another easy option. Ok, out to the garage to put my LC8 into a frame so I can post in the "What have you done today" thread.....
Uller screwed with this post 09-29-2012 at 01:30 PM
Old 09-29-2012, 02:06 PM   #38
Xtremjeepn
Motorhead!
Xtremjeepn's Avatar
Oddometer: 2,009
Talking
Fwiw, I didn't hate the caps, just pointing out that they were a bit of a pain.
02 KTM 520 EXC
04 KTM 351 EXC
Old 09-29-2012, 03:36 PM   #39
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 931
Ok Clearly there a number of things that can be done at a resonable price to reduce the weight of the bike possibly of some 15 kg (33lbs)...that means to equal a 950SE:
Remove rear footpeg
Remove rear rack and hand holder
2 in 1 with titaium pipe
Lighter battery
single front disk
CPR air box
Lighter rims
Gas caps
What we forgot to say though is that for off road use everyone would add a decent skid plate, a damper, handle riser and a brake pump protector...that add some good weight
Nic
Explore Alps Off Road: www.over2000riders.com
2012 Ducati Multistrada 1200
2008 KTM LC8 990 ADV S
2003 KTM LC8 950 ADV
Trips:Europe,Africa,Asia
Dr LC8 is offline   Reply With Quote
Old 10-06-2012, 12:52 PM   #40
rburkat
rburkat's Avatar
Oddometer: 281
I just changed my 990 to a single rotor. Here are the actual weights...
This is the two calipers. So you save half of that which is 1.13 Kg
This is one stock rotor. 1.38 Kg
If you go with the Galfer rotor you save an additional 0.5 Kg
So total removed unsprung weight is 3Kg or 6.6 lbs
You decide if you think thats worth it.
rburkat is offline   Reply With Quote
Old 10-06-2012, 04:48 PM   #41
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 931
Hi,
I did the same calculation for the exhausts last weekend.
Each original are 4.8 kgs. An Akra aluminium is 2.2 kg. If you from stock to a two in one Akra you go from 9.6 to 2.2 kg! Saving 7.4 kgs placed in a high position. There mght be an other little bit saved using the 2 in 1 connection.
Also the two passangers foot pegs are 1kg together.
Passenger arms holder are another 1 kg together.
So if you do a rough calculation you'll see that:
- 2 in 1 +
- Front single brake +
- Remove foot and holder for passanger +
- Light battery
You save some 15kg from stock that match a SE if you start from a 950 Adventure. These are not expensive mods.
You can probably save more with lighter rims.
I guess if these mods are joint by good suspension setting it should improve by far performance off road
Nic
Old 10-06-2012, 08:37 PM   #42
sakurama
on an endless build
sakurama's Avatar
Oddometer: 1,458
Originally Posted by Dr LC8 View Post
The question is just: how I can get a lighter 950 that will help me riding better off road...or at leat easier for an avarage rider as I am????
You've gotten a lot of good advice so I'll offer some you didn't ask for.
If you're really truly trying to ride better off road take a school. I can pretty much promise you that there is no part you can add or replace that will do more for you than a single day of professional instruction. It's not cool because its not something you can point to but what's so great about it is its the one thing you can keep transferring to every new bike you own. It works on any bike and unlike parts it gets better with use. When I road raced I took every school I could find and it made a huge difference. Same with dirt. Even at the Bend rally I skipped a ride to do Jimmy's class and the simple skills and exercises were great - even if I knew them.
The 950 is a pig. As Navin says there's nothing you'll be able to do to "fix" the weight so learning to ride it better will pay more dividends. But as others have said suspension (I've used Super Plush for years on my bikes) and tires goes a long ways.
Gregor
sakurama is offline   Reply With Quote
Old 10-06-2012, 09:05 PM   #43
Vicks
I love sand !!!
Vicks's Avatar
Oddometer: 3,129
what brake hose did u use ?
GO !!! Berglund brothers #148 #149
GO !!! CS Santosh #59
Vicks is offline   Reply With Quote
Old 10-06-2012, 10:12 PM   #44
rburkat
rburkat's Avatar
Oddometer: 281
I bought new banjo bolts and a length of Russell hose.
http://www.russellperformance.com/mc...ses/main.shtml
Old 10-07-2012, 04:08 PM   #45
Dr LC8 OP
...soon or later
Dr LC8's Avatar
Oddometer: 931
Gregor
Gregor,
Thatnks for that. You are 100% right. I thought about it but I have never done. You see I am one of that rider that with the bike has slowly slowly learned to do a bit everything at accetable level...I have just been to lazy to become a champion...
...but you are right, I will look into this, as hard off road is my weakest point!
Now a couple of things more. Your website is so cool! You are a lucky man dealing for work,with bike at such quality level...reformulating having made of your passion such high quality job.
And that is why in this picture capture me last week...
Ciao
Nic
Times are GMT -7.   It's 04:19 PM.
