Old 10-05-2012, 07:15 PM   #1
kentnothstine OP
kentnothstine's Avatar
Oddometer: 615
Multiple battery tender?
What is the best system to charge multiple batteries while still in the bike? I have 4 I want to be able to put on a tender for the winter. What do you guys use, I am looking on the cheap side but I don't want to move the tender. I plan on packing the bikes close together to keep the garage clear... ish.
Kent
2008 XT250(the new one for her to use)
2003 KLX400SR (the new one)
1997 Ural 650cc (SOLD)
Originally Posted by Thanantos View Post
Once your crotch gets wet it's all over.
kentnothstine screwed with this post 10-05-2012 at 10:13 PM
kentnothstine is offline   Reply With Quote
Old 10-05-2012, 07:22 PM   #2
Reddog*
^ "Look up"
Reddog*'s Avatar
Oddometer: 2,805
Hook the batteries in parallel using jumper wires and use one battery tender.
That said you will need to check that all the batteries when fully charged have the same voltage reading. Other wise the weakest one will draw the rest down to its level, shorting the life on the other three.
In reality using four battery tenders will be easier.
Reddog* is offline   Reply With Quote
Old 10-05-2012, 10:46 PM   #3
kentnothstine OP
Oddometer: 615
Anybody use one of these? More then I want to spend though.
http://www.amazon.com/Battery-Tender...+tender+4+bank
Old 10-05-2012, 11:36 PM   #4
squish
Out of the office.
Oddometer: 6,371
I just have mine on a retractable cord dangling from the ceiling, with the long cord and pigtail leads on the bikes
I move it from bike to bike after a couple days of being on the charger.
I'm not a fan of super long term battery tender use, I tend to use it for no more then a couple of weeks at a time.
On vacation for a spell
squish is offline   Reply With Quote
Old 10-06-2012, 08:09 AM   #5
yukonjon
yukonjon's Avatar
Oddometer: 150
[QUOTE=kentnothstine;19759252]Anybody use one of these? More then I want to spend though.
I have one and love it. Hasn't let me down yet. Ive seen some reviews that a certain side or bank will stop working but that hasn't happened to me yet (going on a year now). The cords aren't very long so I had to buy some extensions for the further away bikes.
Before I bought this I just had two regular tenders and would swap to different bikes every other week or so. Worked fine if you looking for a cheaper route.
yukonjon is online now   Reply With Quote
Old 10-06-2012, 09:27 AM   #6
kentnothstine OP
Oddometer: 615
I may end up doing this instead, buy 4 of these.
http://www.amazon.com/gp/product/B00...o_cart_title_1
It ends up being cheaper, but the they wouldn't have the temp compensation, I don't know if that is needed any how.
Kent
Old 10-06-2012, 12:04 PM   #7
Reddog*
^ "Look up"
Reddog*'s Avatar
Oddometer: 2,805
Kent
That is what I use all winter in an unheated garage on my Aprilia.
Old 10-07-2012, 05:38 AM   #8
mikesova
mikesova's Avatar
Oddometer: 1,954
Or, you could charge one of the batteries one day, charge one the next day, charge the other, the day after that, and then the last one, the day after that. Do it again in a month. Preferably out of the bikes, in your basement, since your garage isn't heated.
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 10-07-2012, 05:48 AM   #9
jules083
jules083's Avatar
Oddometer: 4,058
I have killed a few batteries with battery tenders. I've never heard of this happening to anyone else, ever, so I'm not too sure what went wrong.
Here's the long story of how it happened, if anyone can make sense of what went wrong be my guest. Skip over this if you don't want to read a story:
ZX-14, killed 3 batteries. Road King, killed 2. GSX-R 600, Aprilia Mille, and ATV killed one each. Every one of these instances the batteries were put on a tender at all times, and they didn't last over a year. The ninja was the worst, killed a battery every 6 to 8 months. I used the same tenders as my dad, actually we switched tenders a few times thinking that may be the problem. I quit using tenders and haven't had a battery problem since. He still uses them, and hasn't had a problem.
What I do now, is nothing. When I park the bike for the winter I act like they don't even have batteries. Next spring when it's time to ride I start them and ride away. The ATV gets ridden all winter, the rest of them just sit in the garage waiting for a warm day.
COBDR and UTBDR on my klx250:
http://advrider.com/forums/showthread.php?t=1003485
jules083 is online now   Reply With Quote
Old 10-07-2012, 01:48 PM   #10
kobudo28
kobudo28's Avatar
Oddometer: 5,888
I have seven of them in my QA Dept for charging lead acid batteries. They work well, no problems.
kobudo28 is offline   Reply With Quote
Old 10-07-2012, 06:01 PM   #11
bob393
bob393's Avatar
Oddometer: 389
Kent
I think most of us use these. I have 4 also one for the tractor, one for each bike, and one for the generator. I also have the next larger model for the truck. Love them!
2007 R1200GS almost farkeled to perfection!
bob393 is offline   Reply With Quote
Old 10-08-2012, 12:25 PM   #12
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,801
My suggestions are already mentioned here...
they make the multiple-output chargers, linked above. $$ though, designed for bigger vehicle batteries.
Or get a handful of the Batt Tender Jr's and a power strip, mount to the wall/ceiling. The cables are plenty long enough.
Spewer of the poignant non sequitur
#155 | Mule's Photos | BackCountryRebels | ThumperTalk | Tekrider | TylersBA
SnowMule is offline   Reply With Quote
Old 10-08-2012, 04:23 PM   #13
kobudo28
kobudo28's Avatar
Oddometer: 5,888
I didn't go with the Jr version, I went with the bigger version of the Battery Tender. One for the bike, one for the Kubota and one for the S2. I've had zero problems.
Old 10-08-2012, 04:45 PM   #14
SnowMule
[angry moth noises]
SnowMule's Avatar
Oddometer: 18,801
I've got the bigger 5-amp charger/tender on my trailer's battery. Works great, but it's about $100.
Old 10-09-2012, 06:02 AM   #15
jon_l
jon_l's Avatar
Oddometer: 3,380
Was your issue with the genuine Deltran Battery Tender? Or a generic trickle charger?
I have never heard of issues with the genuine article. To have 4 issues in one garage is bizarre.
CBF1000 & PCX150
jon_l is offline   Reply With Quote
Times are GMT -7.   It's 04:03 PM.
