Old 10-07-2012, 12:46 PM   #1
lenny6753 OP
Oddometer: 88
Dielectric Grease?
Is it advisable to place dielectric grease in the electrical connections on the main relay where the adapters connect together? I am troubleshooting the electrics from when the bike died earlier in the week on the way to work. I haven't found anything yet but I really don't know what I am looking for other than loose connections or worn through wires.
lenny6753 is offline   Reply With Quote
Old 10-07-2012, 06:26 PM   #2
Groundhog
Groundhog's Avatar
Oddometer: 188
Dielectric grease is an insulator and should only be used on the housing / sealing areas of connectors. Although it is usually pushed aside by the pressure of the contactors and will still conduct electricity, that is not its purpose (and can interfere with current flow if used on the contacts).
If you want a conductive grease to protect, lubricate and insure current flow use a conductive grease like "NO-OX-ID". Be careful though since this grease is conductive, too much can cause shorts.
Ideally use a conductive grease (very sparingly) on the contacts and a dielectric grease on the housing.
Groundhog
Horsepower determines how fast you hit the wall. Torque determines the size of the hole you make.
Groundhog is offline   Reply With Quote
Old 10-07-2012, 06:38 PM   #3
lenny6753 OP
Oddometer: 88
Groundhog,
Thanks for the info. I am new to this whole troubleshooting the electrical system thing.
Old 10-07-2012, 08:49 PM   #4
Scott Baja
el semental negro
Scott Baja's Avatar
Oddometer: 232
Please help me understand... I just bought replacement plug wires for my Toyota 4-Runner, and it came with a packet of dielectric grease to be used at every plug end connection. Sorry, but I might not get it.
Scott Baja is offline   Reply With Quote
Old 10-07-2012, 11:05 PM   #5
K2m
....58....
K2m's Avatar
Oddometer: 2,242
As the grease gets pushed aside it forms a waterproof barier
I use Lanolin grease for this, with good results. It dose conduct.
The News, those who are trying to control what we think, do not want us to see.
http://www.presstv.ir/live.html So good the British Gov. Banned it !!!
http://rt.com/on-air/rt-america-air/
K2m is offline   Reply With Quote
Old 10-08-2012, 01:13 AM   #6
Groundhog
Groundhog's Avatar
Oddometer: 188
I think this is a very popular misconception.
The instructions probably say to apply to the spark plug boot. It helps seal, insulate, prevent sticking, etc. It does not promote electrical current flow.
For more info go to http://en.wikipedia.org/wiki/Silicone_grease and scroll down to dielectric. Pay particular attention to the third paragraph, "It is not recommended to be applied to the actual electrical conductive contacts of the connector".
Go to http://http://www.sanchem.com/aSpecialE.html for their description of electrical contact grease.
Groundhog
Groundhog screwed with this post 10-08-2012 at 01:22 AM
Old 10-08-2012, 02:12 AM   #7
Wy'east
Dust in the wind...
Wy'east's Avatar
Oddometer: 128
Groundhog is right.
As a side note, we use a specially designed dielectric grease at work on our aircraft. It is also good for a variety of other uses being silicon based. I personally prefer this type to others as its usage is a little broader.
This is what we use (Dow Corning 4 Electrical Insulating Compound) and a tube for home use will last quite a while...
http://www.dowcorning.com/applicatio...3128&type=prod. A 5.3 oz tube (about large toothpaste tube amount) will run you about $15.00 from various on-line retailers. Look for "Dow Corning DC-4".
The above specific compound of "DC-4"
could be used on the connections as it is designed for that, but only use a thin film of it.
I tell you, we are here on Earth to fart around, and don't let anybody tell you different. ― Kurt Vonnegut Jr.
Wy'east is offline   Reply With Quote
Old 10-08-2012, 09:12 AM   #8
geometrician
let's keep going...
geometrician's Avatar
Oddometer: 1,026
Some Thoughts
I like Permatex's product #81153 Dialectric Grease that comes in a pressurized can with a handy nozzle applicator that puts you in mind of "Cheese Whiz". It costs less than $10 and I've been keeping a fleet of vehicles happy for some time now with the same can. I got it at the local auto store, they can order it for you if they don't have any in stock. I like it to inject the female ends of mulit-connectors.
Before that it was black molybdenum grease for ALL bolts & electrical connections!
Keep in mind several connectors on our bikes have a weatherseal gasket in them (such as main relay/master fuse). If you put too much in you'll have problems getting the connectors pushed together enough to click-lock them in place- in extreme cases the gasket will push out of place & you'll have to remove some grease, which is a messy procedure... DAMHIK!
Using an aluminum-based "Never Seez" product will conduct electricity & prevent corrosion but as mentioned above it can make some un-wanted connections for you! I use a toothpick to apply it sparingly and it works well. I've rescued many corroded turn/tail/brake light sockets over the decades...
Also keep in mind dialectric grease is silicone-based and is poison- as well as messy to clean off
Britt
'06 KTM 950 Adv 'S'
'03 KTM 250 EXC
'87 KLR650 - <200K miles "Like the Energizer Bunny, just keeps going & going..."
geometrician is offline   Reply With Quote
Old 10-08-2012, 09:25 AM   #9
sonoran
you already know
sonoran's Avatar
Oddometer: 24,312
I like this stuff... it's dielectric and goes on a lot cleaner.
http://www.corrosionx.com/corrosionx.html
sonoran is offline   Reply With Quote
Old 10-08-2012, 09:47 AM   #10
BillyD
BillyD's Avatar
Oddometer: 635
Old Dog, New Tricks...?
You guys are proof indeed that an old dog can learn new tricks...
I have for years used liberal amounts of dielectric grease on all my off-road bike electrical connectors, but I never realized that it should NOT be used on the contacts themselves.
With that said, I usually ride the dirt bikes during the winter months in wet, muddy conditions and the resulting corrosion associated with having nothing on the contacts has historically been much worse than having dielectric grease liberally applied. I can't remember any connector on which I used dielectric grease failing, but I have had failures with connectors on which nothing was used.
I'm going to get me some of that NO-OX-ID or DC-4 stuff.
Bill
KTM '08 690 RFR, '08 990Adv S (carbs), '07 640Adv, '03 540EXC, Ducati 851, Moto Guzzi 850 Lemans, Ercole & 2VT and Yamaha RD350.
BillyD is offline   Reply With Quote
Old 10-08-2012, 12:09 PM   #11
Groundhog
Groundhog's Avatar
Oddometer: 188
I can't remember any connector on which I used dielectric grease failing, but I have had failures with connectors on which nothing was used.]
Before I learned the difference I had several failures on the ski lifts that I work on. Having 300 pissed off, frozen people yelling at you because they were suspended 50' in a blizzard while you try to find a bad connection makes you do some research!
Groundhog
Old 10-08-2012, 09:13 PM   #12
knobie
knobie's Avatar
Oddometer: 33
Which fuses if any are blown? Start there. That can tell you which way to look. If it's like mine you are looking for the wrong source. So far I had a shorted cooling fan manifested by blown fuses on power relay and cooling fan and a second power relay blown fuse due to a somewhat mysterious source.I suspect the fuel pump strained due to a kinked fuel tank breather hose which created vacuum in the tanks. This latter one is a bit of a stretch but it's so far the only explanation I could come up with. No wire and connections issue that I could find but maybe your's is different.
If you suspect a device is blown open or shorted try to figure out how to take it out of the circuit. In the fan's case, it was as simple as unplugging it and replacing the fuse to get the bike running. Of course I later replaced the fan.
Yes, the use of dielectric grease on electrical connections is good practice.
knobie is offline   Reply With Quote
Old 10-09-2012, 12:42 AM   #13
Wy'east
Dust in the wind...
Wy'east's Avatar
Oddometer: 128
Originally Posted by geometrician View Post
... I like it to inject the female ends of mulit-connectors...
Me too!
Old 10-09-2012, 09:03 PM   #14
skopiec
Oddometer: 68
+1. Had good results using NO OX ID on my Aprilia and it's charismatic electrical system...
Sent from my Nexus 7 using Tapatalk 2
skopiec is offline   Reply With Quote
Old 10-11-2012, 09:23 PM   #15
BillyD
BillyD's Avatar
Oddometer: 635
Well, to my point about connections without any dielectric grease...here's one that I missed on my 640.
The 640 developed a miss and, ultimately, I traced it to where the ignition wire connects with the plug boot.
Bill
Times are GMT -7.   It's 11:09 PM.
